Billy G's, YJ to CJ conversion, Trips and General BS - Page 17 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Billy G's, YJ to CJ conversion, Trips and General BS
Unread 02-03-2012, 05:13 PM   #241
243
1978 FSJ Cherokee
I had a Quicksilver on my Nova, I loved it!
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 02-05-2012, 03:45 PM   #242
lucdog
lucdog's Avatar
1980 CJ5
Topped off the transfer case, and rear diff with fluid, and connected the bottom of the rear shocks.
Took the Jeep for a test drive, HEY! Whats that noise.
And now that loud clunk and grinding. I look under the Jeep, 80w-90 is running out of the diff. Between the yoke and seal. Whoops not a driver yet.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 02-05-2012, 04:35 PM   #243
lucdog
lucdog's Avatar
1980 CJ5
It's never a good sign when all the bolts are off the differential cover, you pry if off and hear a clunk in the oil catch pan. Looks like the inner pinion bearing.
Ring and pinion teeth look ok on first inspection. I'm broken enough for today. I'm done!
Looks like I'm in 243's club.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-05-2012, 04:40 PM   #244
John87
damn!
-John
°llllll° 1985 CJ-7
[url]www.jeepforum.com/forum/f8/85-cj-7-frame-resto-1311807/[/url]
John87 is offline   Reply With Quote Quick reply to this message
Unread 02-05-2012, 04:53 PM   #245
Jim1611
Jim1611's Avatar
Those are just spare parts Bill. Zip her back up and move on.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 02-05-2012, 05:13 PM   #246
lucdog
lucdog's Avatar
1980 CJ5
Yea, after all it's just a YJ. (Sorry Will & Tom)
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-05-2012, 05:53 PM   #247
Jim1611
Jim1611's Avatar
Bill
My build thread
Unread 02-06-2012, 06:07 PM   #248
lucdog
lucdog's Avatar
1980 CJ5
Here's something I've never seen before. Its a mini toilet. A coworkers wife works in a day care, he told me I have to see it. So I'm shareing it with you.
I had him stand next to it for perspective.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-06-2012, 10:59 PM   #249
Skerr
Alrighty then...
So what did you do wrong with the diff? How'd it happen?
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 02-06-2012, 11:13 PM   #250
lucdog
lucdog's Avatar
1980 CJ5
My best guess it was the PO. I didn't do anything to the rear axle, just added fluid.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-07-2012, 04:28 AM   #251
gmakra
Well Bill it sounds like you are the MBP of your wheeling club. Yes I did say MBP or Most Broken Pieces. Do you get the throphy back for this?
I ran into one of them mini crappers before and it threw me for a loop too.
gmakra is online now   Reply With Quote Quick reply to this message
Unread 02-07-2012, 05:51 AM   #252
243
1978 FSJ Cherokee
Just drop the rear driveshaft and drive it in 4HI, if front wheel drive vehicles are not quite your thang, drive in reverse
Unread 02-07-2012, 06:43 AM   #253
lucdog
lucdog's Avatar
1980 CJ5
Yep, first time for me. I also did more trips than everyone else.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-07-2012, 06:50 AM   #254
lucdog
lucdog's Avatar
1980 CJ5
That would work if I had a front shaft. Goes foward won't move in reverse. In reverse the pinion moves down and away from the ring gear, doesn't even touch it.
That toilet was funny I LOL'ed.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-07-2012, 09:00 AM   #255
lucdog
lucdog's Avatar
1980 CJ5
Ok, I have some options that are $ generated for the rear axle fix.
1. Fix the Dana 35, with just bearings.
2. I have a wide track set, Dana 30/AMC20 3.31 gears, put both in.
3. Also have a narrow track 30 and 20. The 20 has 1 piece shafts neither has gears.
4. Hunt down a Ford 8.8, they can be found with 4.10's and a decent trac-lock.
Pro and cons of each
1. Its a 35, bearings and possible ring and pinion needed, also a SYE for the TC ($300) Pro's are, I'm not sure there any, besides the wheel lug pattern.
2. Mostly pros, very little cost, can use a Dana 300 (I have one, and it should bolt to the 700r4 by moving 1 hole. The slip yoke is there, and less drive shaft issues. Front lock out hubs and In a couple months I will have 4.10 gears that will bolt right in.
Cons are moving spring perches, and 2 pc. Axles. I also have a lot more CJ axle parts than YJ (basically none)
3. Pros, 1 piece axles. Cons, a lot more work.
4. Pro's, its a stout axle, with the same wheel lug pattern as the current front, and rear disc brakes. Cons, cost, more work, I would need to change from coil springs to leafs.
Thoughts, opinions, possible problems.
Help me out please, Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
