Billy G's, YJ to CJ conversion, Trips and General BS - Page 148 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Billy G's, YJ to CJ conversion, Trips and General BS
Jeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineIncome tax season is upon us. We got what u need
Unread 09-11-2013, 10:28 PM   #2206
W_A_Watson_II
Originally Posted by lucdog View Post
One advantage of this is first gear engine brakeing on downhills. MoC would be the first to tell you, this is a huge plus on steep down hill trails.
It doesn't work as well if you don't have a manual lockup capability on the Torque Converter.
It also functions as a shift kit to really firm up the shifts between gears ( read fast solid shifts, to the point of barking the tires when shifting on fast take off's.
Barking tires, how about breaking axles and other parts?
Will Watson
1993 Jeep YJ 4.6L Stroker (jeep.wawii.com)
1946 & 49 Dodge Power Wagon, 1953 Dodge M37
W_A_Watson_II is offline   Reply With Quote Quick reply to this message
Unread 09-11-2013, 10:47 PM   #2207
lucdog
lucdog's Avatar
1980 CJ5
I'll let you know how it works. I doubt any TC locks up the converter in first, ( with the exception of using a switch. like i have in the Super Duty. I don't believe a Th400 ever had a lock up, just like a 727. The guy who helped me with the install would know how and why, I didn't ask him.
If I have the time on Friday I'll call TCI, the makers of the part and ask them. My feeble mind tells me it's about the direction or restriction of fluid,
All of our Fire engines had a trans retarder, worked pretty good, not as good as the Exhaust brakes we have now. Both of them worked good enought to warrant a warning on the dash saying not to use them in wet or slippery conditions.
Second, you forget, I don't have a heavy foot like a certain member of or club, ;-). Charlie did tell me it won't bang into gear, and I did ask about that, he didnt for see a problem.
Bill
Edit, the TH400 ended production around '87. About the same time the TH700r4/ 4L60 and 4L80 came about, with overdrive and the lock up TC . I do know one thing for sure, like the 727 it's one darn tough tranny.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 09-12-2013, 06:59 PM   #2208
lucdog
lucdog's Avatar
1980 CJ5
The transmission vent tube on the TH400 was broken. Not a big deal, it was plastic anyway. I wanted to drill and tap the hole for a brass fitting, problem was, we didnt have a NPT tap. So, I used a 1/4" grease zerk and drilled out the center with a 1/8" bit,( this took care of the little spring) then knocked the ball out with a punch, the threads on the zerk are self tapping. I used a socket with a screw for a stop. Using inward pressure ran the zerk into the hole , a little loctite was used on the threads. Some fuel line and a clamp and I was done.
Started the tranny swap today, but first I helped a friend ( the guy that broke his pinion) remove some bearings.
I pulled the drive shafts, Qtrac supply lines, Low range unit and the transfer case itself.
The tranny comes out Saturday morning, and the built one goes in.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 09-12-2013, 07:03 PM   #2209
W_A_Watson_II
Looking good Bill! I did a little work on my, um, yj. I install a great set of 5" Boomerang Shackles I bought from Jim at Crabtree Tool & Die.
Will Watson
Unread 09-12-2013, 07:10 PM   #2210
gmakra
Hey that orange thinga magigy look familiar
gmakra is online now   Reply With Quote Quick reply to this message
Unread 09-12-2013, 08:05 PM   #2211
lucdog
lucdog's Avatar
1980 CJ5
Why do you think I posted the picture? :-)
I haven't forgot I owe you a gas can, I think I'll just send you a check, or a gift card.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 09-12-2013, 08:08 PM   #2212
lucdog
lucdog's Avatar
1980 CJ5
Those are the best!!! Ya know, the 2a that Dr. Dirt has would make a nice addition to your fleet! Word is its darn fast, John told me it would break the tires loose in 4th gear.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 09-12-2013, 08:41 PM   #2213
VACJ7
Hockey Rules!
VACJ7's Avatar
You got a safety belt and cup holder to go along with the hospital rails on your creeper? Kinda makes me want to take a nap in it.
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 09-12-2013, 09:17 PM   #2214
W_A_Watson_II
Ya know, the 2a that Dr. Dirt has would make a nice addition to your fleet! Word is its darn fast, John told me it would break the tires loose in 4th gear.B
Yea, I'd like to build/have a nice fast street machine to play with.
Will Watson
Unread 09-12-2013, 09:41 PM   #2215
lucdog
lucdog's Avatar
1980 CJ5
:-). Good one Paul. I do believe I have taken a nap or 2 on the creeper. One time I had a dream. It was about YJ tubs, and why it's so difficult to get the floor pans welded in.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 09-12-2013, 10:35 PM   #2216
lucdog
lucdog's Avatar
1980 CJ5
Went a little further after my post. Tranny jack in place.
3 bolts hold the converter to the flex plate. I rotated the flexplate 1 tooth at a time to gain access to them.
With a couple long extensions removing the bolts is next. Removing them is way easier than putting them back in.
Billy G.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 09-12-2013, 11:50 PM   #2217
WNC-84CJ7
I'll call Friday if I can. I have a deadline Sunday night at 10PM, and I get most of my writing done between 10PM and 2AM- only time I can get peace and quiet around here. In the meantime, I'll run the risk of public ridicule and paste my PM here!
Hey Bill! Hope you're doing well. Alas, school has started again, and the Jeep sits in the garage patiently awaiting my return. Just wanted to drop you a "hello". I am pretty busy with three classes, the house, some work, and the full time job of dad. I have to kinda stay away from JF while I work and write, or I will get nothing done. I check it every so often, but I have a pretty heavy load this semester. I have already produced about 60 pages of material, and I'm less than a month into it. Grad school sux a little. I am looking forward to a break already! CJ still needs some carb work, seats and a windshield, but it ain't goin' nowhere. Should I put some StaBil in the tank? I have about 3 gallons in there that probably won't be burned for a bit. I have another question about the idle on the J truck, but I'll call you for that one- it'll be much easier over the phone. I don't know when I'll get around to it, but I won't call too late, and ignore it if it isn't a good time! See ya Billy G.
Chris
UPDATE: Found out the J truck problem. When I let off the gas pedal, the engine would continue to idle high. If I gently bumped the gas, it would drop off. The throttle return spring rusted and busted. Had a few in the garage from experimenting with the CJ, and had the perfect fit. Done!
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline   Reply With Quote Quick reply to this message
Unread 09-13-2013, 04:27 AM   #2218
SKT
1981 CJ7
...I can't delete PM's from my phone.
Bill,
If you have an iPhone, try these doing this to delete PM's:
1. While in the main PM inbox screen, identify the PM for deletion.
2. Swipe your right finger over the intended PM (start about an inch from the right side of the screen and exaggerate the swipe as if your going off the screen.
3. A red in color pop up 'DELETE' feature should appear where you just swiped your finger.
4. Press 'DELETE' and the PM will disappear.
Note: this swiping process also works to delete text messages, etc.
Click here to see thousands of 'Abandoned and Neglected' Jeeps rotting away...
SKT is offline   Reply With Quote Quick reply to this message
Unread 09-13-2013, 05:48 AM   #2219
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by SKT
Bill,
Works great!!! Thank you
Since your up in goods country, just a little north of me check this out. http://www.shotguneddy.com/Welcome.html
We've only been once and had a great time. The rafts wernt anything sepctular, in fact all but one of the handles were broke off.
I have a great story about the trip, it's best told in person. Everytime my wife told it see couldn't finish telling it without busting out laughing. It was 15 years ago. It still causes her to LOL when I tell someone.
Basically what happened is, I ended up floating down the river in sun glasses, and life jacket, Nothing else!!!
So if you happen to go, tie the little string that holds up your swim trunks. LOL
with a smile on my face, Billy G.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 09-13-2013, 06:07 AM   #2220
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Basically what happened is, I ended up floating down the river in sun glasses, life jacket, and flip flops. Nothing else!!! Billy G.
Ah man, that's not a visual I needed this morning!!
Did you tinker with that Q-jet yet, Bill?
Matt
Matt1981CJ7 is online now   Reply With Quote Quick reply to this message
