Billy G's, YJ to CJ conversion, Trips and General BS - Page 142 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Billy G's, YJ to CJ conversion, Trips and General BS
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 08-16-2013, 09:20 PM   #2116
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by VACJ7
Why is there an Acetelyne regulator sitting on the console? Water bottle holder???? My guess is if it ain't stapped in it won't stay in his Jeep.
That would be the regulator for my air bottle. You are correct about being strapped down.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 08-16-2013, 09:35 PM   #2117
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by WNC-84CJ7
Hey Bill, what kind of seats are those?
What is this? 50 questions. I feel like I just got home from a date and my Mom wants to know all about it ,hahaha :-)
Chris, the seats were in the Jeep when I bought it. They are Leon Rosser. I believe he was a big Jeep/Eagle dealer back in the day.
And here's your water bottle holder MoC, it will also hold Diet Dr. Pepper.
If your to tall and gangley to reach around to get the bottle. I have a Coozie with a strap , you can hang it around your neck.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 08-16-2013, 09:54 PM   #2118
lucdog
lucdog's Avatar
1980 CJ5
See.
Here's a closer look at the regulator.
Billy G. aka J Truck Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 08-16-2013, 10:16 PM   #2119
MoC
Really looking foward to meeting you in person Bill and riding.
MoC is offline   Reply With Quote Quick reply to this message
Unread 08-16-2013, 11:05 PM   #2120
kw89425
Take alot of pictures as I live life vicariously through the lucdog adventures
86 cj7 496 powered 465/205 ton axles 38.5 boggers
http://www.jeepforum.com/forum/f8/my...oject-1019388/
kw89425 is offline   Reply With Quote Quick reply to this message
Unread 08-18-2013, 08:25 PM   #2121
Skerr
WOOHOO! I am IN!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 08-18-2013, 09:32 PM   #2122
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by Skerr
WOOHOO! I am IN!
Pack your stuff, leave now, bring the truck and your trailer, pick up my Q-trac Jeep, and meet me in Little Rock.
Your choice, bring Beth, or stop and pick up Jim.
:-). Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 08-20-2013, 07:00 AM   #2123
lucdog
lucdog's Avatar
1980 CJ5
A couple random pictures. I saw this 1/2 pickup on the road the other day, what's up with the dual stacks in the bed, diesel wannabe I guess.
And, my buddy KW89425 sent me this one.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 08-20-2013, 08:13 AM   #2124
243
1978 FSJ Cherokee
Stacks on a 1/2T are pathetic...but what about this?
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 08-20-2013, 08:50 AM   #2125
lucdog
lucdog's Avatar
1980 CJ5
It don't happen very often, but' I'm at a loss for words.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 08-20-2013, 08:55 AM   #2126
roboto65
1976 CJ5
That proves my point right there the Gene Pool needs to be cleaned every once and a while
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline   Reply With Quote Quick reply to this message
Unread 08-20-2013, 07:24 PM   #2127
lucdog
lucdog's Avatar
1980 CJ5
Changed some tires around today. I took off the 35/12:50/15 tires from these 6x5.5 rims.
On to these rims 5x5.5" for use at Silver Lake Sand dunes at the end of September.
They are going on this Jeep with only a 3" spring lift. I imagine the rear wheel wells will need cut, and the flares removed.
There are 33" super Swamper's on it now. I counting on the used All Terrains are closer to 33.5"/34, while I know the SS's are a little over 33".
The reason for this is I feel like radials will be better in the sand. And the TA's are a "C" rated tire, vs a D rated on the Swampers. So I should get a little more flex out of the tire at the same 12 psi.
Also, I had some problems last year at the dunes on long hill climbs. The engine was cutting out near the top , I believe I've found out why, I think I was running out of fuel, ( float bowl not being big enough on the q-Jet carb.)
I read this here--> http://bosshosshelp.com/Menu%20Items.../quadrajet.htm
As best memory serves, the biggest climb took about 20 seconds. This was also at 4000 + or - rpm.
So, you might ask, why not just back out of the skinny pedal. Here's why. Loss of momentum and wheel speed. So when you get back into the gas ( plenty of power with the 360) the tires start spinning, and you slow down and dig a hole. This also means backing down a 300' hill and trying again. It took me 4 attempts on the first try. I made it within 15' of the top. One fix for the fuel issue is go FI. The other as I see it is a Holley 670 TA. I don't have the time for FI, so I'm going with the 670. After I bent the front axle I rode in a CJ with a built SBC 383. He was running a 670, and didnt have a problem.
As far as the Quadrajet I still feel its the best all around carb. Except for sand dunes.
Bill
Should be interesting.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 08-20-2013, 08:25 PM   #2128
lucdog
lucdog's Avatar
1980 CJ5
I also found there is a learning curve on sand dunes. The Q-trac jeep I used has a 360, 4.10 gears and bias ply 33" LTB Super Swampers. I really didnt think I would have any issues on the dunes, I was wrong. My cousin with a stock '98 TJ with a 4.0L and a 5 speed with basically street tires, and not even a limited slip diff in the rear did better than me.
I am a little concerned with 35's on the Dana 30, like I said, I will be interesting.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 08-20-2013, 08:29 PM   #2129
243
1978 FSJ Cherokee
What's wrong with the Q-trac?
Unread 08-20-2013, 08:50 PM   #2130
lucdog
lucdog's Avatar
1980 CJ5
It's not the Q-trac, it works fine. It's the fuel and bias tire, on the sand hills. I never tried it in normal drive, this Jeep also has welded rear spiders, and a front lock rite .
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
