Billy G's, YJ to CJ conversion, Trips and General BS - Page 110 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Billy G's, YJ to CJ conversion, Trips and General BS
Metalcloak: Celebrate Freedom with Free ShippingFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-08-2013, 06:59 PM   #1636
Coiz
1979 CJ7
You need to clean all of the mud out of those rotor fins, let them babies breath.
Hey do those Precision u-joints have the grease zerk on the cross or on the end of a cap? Or did you get the solid ones?
Mike
My build thread
Coiz is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 07:55 PM   #1637
lucdog
lucdog's Avatar
1980 CJ5
On the cap.
The mud is hi-tech rotor balancing, the idea being pack them full, once you hit 88 mph the excess flys off and their balanced. So why is there so much mud left on them you might ask. Well bad things happen at 88 mph, I didn't want to end up in 1955 on October 26.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 11:08 PM   #1638
lucdog
lucdog's Avatar
1980 CJ5
Good news on The Lucdog front. My wife called and said the box from Moser Engineering arrived today, talk about quick , they called me Tuesday to confirm payment and to start on the axle shaft. They are only 6 hours east of me. But still, That's customer service!
Made the part Tuesday or Wednesday, shipped it and I got it Friday.
And I got the bearings all packed, seals put in and ready to install. Just need the U-bolts, some shocks and pick up the new TRE's tomorrow.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 03-09-2013, 07:34 AM   #1639
lucdog
lucdog's Avatar
1980 CJ5
The wife was correct.
Bill
This included installing and supplying the studs.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 03-09-2013, 08:04 PM   #1640
Skerr
mmm-mmm-mmmmm....
What kind of vitamins you taking Dude? I need some of them.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 03-09-2013, 08:33 PM   #1641
kw89425
Ill be glad when you get done get it out and use it. Oh and make all videos from the driver seat so i cant feel like im there...lol i havent seen mine in a couple of months i hope its still there.
86 cj7 496 powered 465/205 ton axles 38.5 boggers
http://www.jeepforum.com/forum/f8/my...oject-1019388/
kw89425 is offline   Reply With Quote Quick reply to this message
Unread 03-09-2013, 08:33 PM   #1642
lucdog
lucdog's Avatar
1980 CJ5
I think it might have been the sugar in one of these .
Or combo of the 3, those Jelly beans are good.
The wife and Grand Daughter kept me busy today, I was doing good to get the seals on the stub shafts, axles installed along with the spindles.
A FYI, peeps are best if you let the package sit open for 3 days. Makes them nice and chewy. :-)
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 03-10-2013, 06:53 AM   #1643
gmakra
Billy I see you shop at Big R I love that store! The one by me has everything from welders to walnuts in the same isle. Kind of like a Tractor Supply on steroids!
gmakra is offline   Reply With Quote Quick reply to this message
Unread 03-10-2013, 08:21 AM   #1644
lucdog
lucdog's Avatar
1980 CJ5
Since you mentioned Big R, they put it in a old Walmart store. 5 blocks from the TSC . Used to be TSC would have a dozen or more cars in the lot at any given time. Now there are 1 or 2 cars there, "R" has 2 dozen.
This TSC has Larin brand tools like engine hoist, creepers,jacks, ECT. They bare a striking Resemblance to Harbor Frieght stuff, only painted red. I see no difference in outward appearance. And they're more expensive than HF.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 03-10-2013, 12:25 PM   #1645
Skerr
You better HUSTLE! Get off JF! What're you doing? Wasting time on the phone... wasting time on the computer!! You have, what... 5 more days!?!? Tick Tock, Tick Tock, Tick Tock...
Kerrdog
Go Fish! <*////><
Unread 03-10-2013, 03:12 PM   #1646
lucdog
lucdog's Avatar
1980 CJ5
I would have gotten more done today, had someone not called me.
Anyway, the axle is setting on the springs and U-bolts need torqued. Tie rod and drag link installed, sleeves still loose for any final adjustment, toe in set and steering wheel centered. Brake rotors/hubs installed need to set preload on the bearings, and install and torque the outer nut and bend the washer. New cheap shocks installed.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 03-10-2013, 03:20 PM   #1647
Skerr
Atta Boy. That's more like it.
Kerrdog
Go Fish! <*////><
Unread 03-10-2013, 04:33 PM   #1648
lucdog
lucdog's Avatar
1980 CJ5
I'm not done yet. Brakes on, and hub bearings set and washer bent over.
I like to leave the caliper off when setting the bearings. I also put the wheel/tire on.
Used this to bend the washer.
So what's left.
1.) driveshaft
2.) diff fluid
3.) grease the TRE's and put the cotter pin in the castle nuts.
4.) bleed the front brakes while the tires are still off.
5.) tighten the sleeve bolts on the drag link, road test, readjust as needed.
6.) might as well put the steering stabilizer back on.
7.) install the lockouts.
8.) check the torque on the wheel spacers and put the wheels back on.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 03-10-2013, 05:58 PM   #1649
Skerr
You better put the wheels back on BEFORE the road test. It'll be a much more gratifying experience. Just sayin...
Kerrdog
Go Fish! <*////><
Unread 03-12-2013, 08:18 AM   #1650
lucdog
lucdog's Avatar
1980 CJ5
I'm am pumped up. I just bought another Jeep!!! It's the J truck I posted about 2 weeks ago.
Pick it up Thursday.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
