Billy G's, YJ to CJ conversion, Trips and General BS - Page 105 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Billy G's, YJ to CJ conversion, Trips and General BS
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 02-13-2013, 11:02 PM   #1561
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by kw89425
You have broke more than i have bill
And that was with a 305 Chevy and a 4 bbl. must have been the Cherry Bomb mufflers.
Besides the Flex-a-lite fan controller that took a crap, and the bent Dana 30 from the dune launch, I think that was it.
Broke a motor mount on the bypass to this. The bypass was rated as a 4+ out of 5. This was 2011.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 02-13-2013, 11:03 PM   #1562
roboto65
1976 CJ5
WOW twisty splines sure you did not try and pull that tree out LOL
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline   Reply With Quote Quick reply to this message
Unread 02-13-2013, 11:44 PM   #1563
MoC
Speaking of power wagons... I spied this while driving today.
MoC is offline   Reply With Quote Quick reply to this message
Unread 02-14-2013, 06:53 AM   #1564
W_A_Watson_II
MoC, that's a nice PW. I don't recognize it, where did you wee it?
Will Watson
1993 Jeep YJ 4.6L Stroker (jeep.wawii.com)
1946 & 49 Dodge Power Wagon, 1953 Dodge M37
W_A_Watson_II is offline   Reply With Quote Quick reply to this message
Unread 02-14-2013, 06:55 AM   #1565
WNC-84CJ7
Will, I think MoC is in Louisiana.
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2013, 07:43 AM   #1566
W_A_Watson_II
Louisiana, you know when I saw the pix that was the location that first entered my mind as looked kind of like where my brother-in-law lives, but then again all subs look a like don't they?
Will Watson
Unread 02-14-2013, 09:55 AM   #1567
MoC
It's in Shreveport, LA.
Unread 02-14-2013, 10:28 AM   #1568
W_A_Watson_II
Thanks MoC. I don't recall seeing that one, but I've not seen them all. My Brother-In-Law is on the south side of Baton Rouge, so not the same location. Most of the PW owners post over on that forum, it's likly he's there, just not seen his truck pictured. Thanks for posting it.
Will Watson
Unread 02-14-2013, 12:48 PM   #1569
lucdog
lucdog's Avatar
1980 CJ5
It was a full morning cutting wood. We cut 2 8'+ Pieces and winched them out of the gully. As close as I can figure each weighed at least 1,500 pounds. I had to double line the winch coming up the approx 40 incline. The receiver of the logs will have a Sawyer come and cut them into planks for drying .
Man this fresh cut Red Oak smells good.
102 rings 20' from the base.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-14-2013, 01:02 PM   #1570
lucdog
lucdog's Avatar
1980 CJ5
My friend took my picture while I was cutting. The ravine to my left was a 9' drop, wasn't enough room to stand on the other side of the saw.
Attachment 564629
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-14-2013, 01:48 PM   #1571
W_A_Watson_II
Nice work Bill! 102 rings, well i guess the tree was older than you after all, just by a little that is.
Will Watson
Unread 02-14-2013, 04:37 PM   #1572
lucdog
lucdog's Avatar
1980 CJ5
Time to play what's its worth.
http://peoria.craigslist.org/cto/3611659128.html
No title
Only 3 of the Jackman rims.
Can't tell if it actually is a 360 , even though it has the badgeing, sitting to low to get underneath.
Missing the drivers rear axle shaft.
Missing one of these.
Has both of these.
Interior.
Engine.
This is interesting. A GM style dizzy cap, see the little trap door.
Frame and body not bad, mostly surface rust, the truck has a Arkansas license plate, last registered in '97.
Dana 44 axles front and rear , I believe full width, front is a closed knuckle .
Some exterior pictures.
Not a 4 speed, it 3 speed, and it shows 86,xxx miles.
If you didn't look at the add, asking price is $700. No title.
If your not familiar with Jackman rims, look at the picture again, notice there isn't any web between the spoke and outer rim , the spoke is welded directly to the outer. These are 15x10.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-14-2013, 05:23 PM   #1573
lucdog
lucdog's Avatar
1980 CJ5
I forgot to add I re-broke the Q-trac jeep today. If you remember , after the dune trip and the bent Dana 30 the steering arm on the drivers knuckle broke off. I did a quick weld job to get it off the trailer and be able to move it around the house, that's what broke. I was attempting to pull one of the logs in 4wd, oops.
On the plus side, both my friends said the 360 sounded Bad A$$.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-15-2013, 05:47 AM   #1574
lucdog
lucdog's Avatar
1980 CJ5
I forgot a couple things on the log retriv.
I did need to strap the CJ down from the rear to keep the Jeep from pulling down the hill. I used the Rubicon. There was a injury as well,
Only a splinter you say, it went in at a angle. A little work with a razor blade, dental pick and tweezers got that sucker out.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-15-2013, 06:12 AM   #1575
roboto65
1976 CJ5
Oh my GOD how many stitches did that take I bet the Jeep gods have taken more blood.
