Billy G's, YJ to CJ conversion, Trips and General BS - Page 102 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Billy G's, YJ to CJ conversion, Trips and General BS
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 02-07-2013, 11:25 AM   #1516
W_A_Watson_II
Looks like it should be on the trail not the road!
Will Watson
1993 Jeep YJ 4.6L Stroker (jeep.wawii.com)
1946 & 49 Dodge Power Wagon, 1953 Dodge M37
W_A_Watson_II is offline   Reply With Quote Quick reply to this message
Unread 02-07-2013, 12:50 PM   #1517
Dadamsnv
1977 CJ5
Nice work gettin her into first and then home!
And nice thinking on the grade 8 bolts
Cheers!
Dadamsnv is offline   Reply With Quote Quick reply to this message
Unread 02-07-2013, 05:51 PM   #1518
kw89425
Clutch? We dont need no stinkning clutch...pedal
86 cj7 496 powered 465/205 ton axles 38.5 boggers
http://www.jeepforum.com/forum/f8/my...oject-1019388/
kw89425 is offline   Reply With Quote Quick reply to this message
Unread 02-07-2013, 06:10 PM   #1519
tractor1
1979 CJ5
You are starting to show your age when you can drive and shift with no clutch!
1979 CJ5 304 T150 Dana 20 under construction
1993 Wrangler 4.0 HO AX15 231 4 lift 33 12.5 15 DD
1994 Wrangler 2.5 AX5 231 Stock Sold
1973 Cj5 304 T15 Dana20 Sold
[COLOR="Black"][CENTER][SIZE="4"][FONT="Showcard Gothic"][COLOR="Black"][URL="http://groups.jeepforum.com/Built_Not_Bought"][COLOR="Black"]Built Not Bought #457[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
tractor1 is offline   Reply With Quote Quick reply to this message
Unread 02-07-2013, 06:12 PM   #1520
kw89425
Be 46 the 10th....but i shift 18 all day without the pedal..lol
Unread 02-07-2013, 06:23 PM   #1521
lucdog
lucdog's Avatar
1980 CJ5
I agree with what considering your DD. I rode with my neighbor a couple times. Only used the clutch at stop lights. His truck I believe is similar to your signature, except for the year. He hauls road millings, dirt, broken up concrete, ECT. It's a shortened road truck (took the sleeper out) he also told me it will run 110 mph.
Where ya at tonight Keith?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 02-07-2013, 06:30 PM   #1522
fourbtgait
1930 MK Patriot
Very true. Whether its a car, cj, pickup or a tractor, rarely do I use the clutch except when stopping.
fourbtgait is offline   Reply With Quote Quick reply to this message
Unread 02-07-2013, 06:40 PM   #1523
kw89425
Bill
Im home been here since friday was supposed to load last monday but fell ill sunday. I may try to load tom and truck through the weekend..maybe....my lil bully just wont leave my side. I laid down he climbed on me and up to my face i just didnt have the energy to fight with him. I covered him thinking he wouldnt stay long...he was there when i got up.
Unread 02-07-2013, 06:46 PM   #1524
lucdog
lucdog's Avatar
1980 CJ5
New project.
These seat came originally from (I think) a 1984 Buick Regal GS. Then they were in my Jimmy, now there going in the DD. Passenger side is complete, I used the factory fold foward mount. Front to back the bolt holes are 1.250" further apart the Jeep seats. The bolt boles are also 13.375" CtoC wide, compared to the 14" on The factory seat. I redrilled the passenger bracket to match and bolted them in.
Now the real work begins, adapting the seat slider to the seat.
I'm still thinking on a plan of attract, without raising the seat to high.
I'm saving the low backs.
More after I have a plan.
Bill
On edit, my first though is to weld the sliders to the bottom of the seat. The sliders can't be redrilled to match the seat, they aren't long enough.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-07-2013, 06:50 PM   #1525
lucdog
lucdog's Avatar
1980 CJ5
There's a good reason they call them Mans best friend!
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-08-2013, 08:26 AM   #1526
lucdog
lucdog's Avatar
1980 CJ5
So here's the drivers seat plan . Remove the bolts that hold the sliders to the bracket. Remove the seat and sliders as a unit, then tack weld 2 pieces of steel to hold the sliders at the proper distance apart, remove the sliders.
Get some water handy cause I'm not removing any seat material. Weld the sliders to the bottom of the new seat. Quench any hot spots, and install the seats. A little measuring will be required to insure the seats are where I want them.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-08-2013, 08:41 AM   #1527
W_A_Watson_II
When I used the Dakota seat, the only issue I found was lower seat base thickness moved the seating location too high for us taller folks, might work well for a vertically challenged individual.
Will Watson
Unread 02-08-2013, 10:35 AM   #1528
lucdog
lucdog's Avatar
1980 CJ5
Thanks Will, actually the factory low back seats were a little high, even for me.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-08-2013, 11:03 AM   #1529
lucdog
lucdog's Avatar
1980 CJ5
Yea, got the drivers seat in. Because of the style of the seat it's a out 1" lower than the low back factory seat. This is going to be a plus at stop lights. Up until now I've had to watch the light reflection on the hood for when the light changed green. So here's what I did.
As you can see I didn't weld a strap to the sliders to keep them in line.
This worked great. I did need to oval one hole to bolt them on, for this I used the Tungsten carbide rotary file, it works great for this kind of thing.
As can also been seen is the bolts the PO put in, no way for a socket to fit them. ( the factory uses a inverted Torx bolt)
So I ground a slot in the head and backed them out as shown in the picture. They also had nuts on the back side
Setting the sliders on the new seat to line stuff up. You might also see the depression (raised while looking at the picture) . This helps to lower the height when sitting in the seat.
Getting ready to weld. The thin sheet metal is called panning that HVAC use to span floor joists for cold air returns . I used it to protect the foam and material.
Safety first!
The sliders welded on.
And the finished project.
I thought the seats matched the garnet interior pretty good, the seats are Comfortable with good side bolstering.
I'd wish I could find another set in black leather for the trail Jeep.
2 more pictures of the clearance at the door and center counsel (Walmart special $29).
Ok one more picture. I never lock the doors, so a zip tie is used to keep the lock from pushing in and locking , by pressure from the seat.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 02-08-2013, 12:05 PM   #1530
tractor1
1979 CJ5
They look real good. nice fit in the jeep.
