Billy G's, YJ to CJ conversion, Trips and General BS - Page 17 - JeepForum.com
post #241 of 2836 Old 02-03-2012, 04:13 PM
243
1978 FSJ Cherokee
I had a Quicksilver on my Nova, I loved it!
Dave's 78 Build
243 is offline
post #242 of 2836 Old 02-05-2012, 02:45 PM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
Topped off the transfer case, and rear diff with fluid, and connected the bottom of the rear shocks.
Took the Jeep for a test drive, HEY! Whats that noise.
And now that loud clunk and grinding. I look under the Jeep, 80w-90 is running out of the diff. Between the yoke and seal. Whoops not a driver yet.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #243 of 2836 Old 02-05-2012, 03:35 PM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
It's never a good sign when all the bolts are off the differential cover, you pry if off and hear a clunk in the oil catch pan. Looks like the inner pinion bearing.
Ring and pinion teeth look ok on first inspection. I'm broken enough for today. I'm done!
Looks like I'm in 243's club.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #244 of 2836 Old 02-05-2012, 03:40 PM
John87
damn!
-John
°llllll° 1985 CJ-7
John87 is offline
post #245 of 2836 Old 02-05-2012, 03:53 PM
Jim1611
Jim1611's Avatar
Those are just spare parts Bill. Zip her back up and move on.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #246 of 2836 Old 02-05-2012, 04:13 PM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
Yea, after all it's just a YJ. (Sorry Will & Tom)
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #247 of 2836 Old 02-05-2012, 04:53 PM
Jim1611
Jim1611's Avatar
Bill
My build thread
Jim1611 is offline
post #248 of 2836 Old 02-06-2012, 05:07 PM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
Here's something I've never seen before. Its a mini toilet. A coworkers wife works in a day care, he told me I have to see it. So I'm shareing it with you.
I had him stand next to it for perspective.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #249 of 2836 Old 02-06-2012, 09:59 PM
Skerr
Alrighty then...
So what did you do wrong with the diff? How'd it happen?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #250 of 2836 Old 02-06-2012, 10:13 PM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
My best guess it was the PO. I didn't do anything to the rear axle, just added fluid.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #251 of 2836 Old 02-07-2012, 03:28 AM
gmakra
Well Bill it sounds like you are the MBP of your wheeling club. Yes I did say MBP or Most Broken Pieces. Do you get the throphy back for this?
I ran into one of them mini crappers before and it threw me for a loop too.
gmakra is offline
post #252 of 2836 Old 02-07-2012, 04:51 AM
243
1978 FSJ Cherokee
Just drop the rear driveshaft and drive it in 4HI, if front wheel drive vehicles are not quite your thang, drive in reverse
Dave's 78 Build
243 is offline
post #253 of 2836 Old 02-07-2012, 05:43 AM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
Yep, first time for me. I also did more trips than everyone else.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #254 of 2836 Old 02-07-2012, 05:50 AM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
That would work if I had a front shaft. Goes foward won't move in reverse. In reverse the pinion moves down and away from the ring gear, doesn't even touch it.
That toilet was funny I LOL'ed.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #255 of 2836 Old 02-07-2012, 08:00 AM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
Ok, I have some options that are $ generated for the rear axle fix.
1. Fix the Dana 35, with just bearings.
2. I have a wide track set, Dana 30/AMC20 3.31 gears, put both in.
3. Also have a narrow track 30 and 20. The 20 has 1 piece shafts neither has gears.
4. Hunt down a Ford 8.8, they can be found with 4.10's and a decent trac-lock.
Pro and cons of each
1. Its a 35, bearings and possible ring and pinion needed, also a SYE for the TC ($300) Pro's are, I'm not sure there any, besides the wheel lug pattern.
2. Mostly pros, very little cost, can use a Dana 300 (I have one, and it should bolt to the 700r4 by moving 1 hole. The slip yoke is there, and less drive shaft issues. Front lock out hubs and In a couple months I will have 4.10 gears that will bolt right in.
Cons are moving spring perches, and 2 pc. Axles. I also have a lot more CJ axle parts than YJ (basically none)
3. Pros, 1 piece axles. Cons, a lot more work.
4. Pro's, its a stout axle, with the same wheel lug pattern as the current front, and rear disc brakes. Cons, cost, more work, I would need to change from coil springs to leafs.
Thoughts, opinions, possible problems.
Help me out please, Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
hill billy sr4 to T18 conversion kit CallMe_Lockouts Jeep CJ Forum 12 07-15-2011 02:34 PM
The General Lee raperfam Jeep CJ Forum 13 12-15-2010 07:10 PM
General CJ-7 questions Squish Jeep CJ Forum 8 10-22-2008 10:06 PM
the general? jeep795 Jeep CJ Forum 3 12-27-2006 09:46 AM
AM General CGrugger Jeep CJ Forum 9 01-10-2006 03:46 AM
