Billy G's, YJ to CJ conversion, Trips and General BS - Page 12 - JeepForum.com
post #166 of 2836 Old 01-18-2012, 06:00 PM
Skerr
What is a CAD front axle??
Kerrdog
Go Fish! <*////><
Skerr is offline
post #167 of 2836 Old 01-18-2012, 06:09 PM
243
1978 FSJ Cherokee
"Center Axle Disconnect" IIRC
Dave's 78 Build
243 is offline
post #168 of 2836 Old 01-18-2012, 07:07 PM
Skerr
Oh... What the hell is a center axle disconnect? You got three axles Bill?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #169 of 2836 Old 01-18-2012, 07:09 PM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by MoC View Post
Sent you a care package today Bill!
Cool, if I can help in return let me know. Thank You.
You remember correctly. Its actually close to the E-Drive shift in a Quadra-trac, Scott.
A vacuum actuator moves a shift fork and splined collar over a splined opposing axle shaft,midway between the pumpkin and knuckle connecting the two. Three lines run to the axle, one being a vent, yet another runs to a vacuum switch that sends a ground to the dash light. There are 4 lines running to the TC, looks like spaghetti and is very colorful.(red, blue, black, and yellow) It still uses spider gears, and the YJ's use unit bearings like newer cars, so no lockouts .
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #170 of 2836 Old 01-18-2012, 07:23 PM
Jim1611
Jim1611's Avatar
Good to see you getting some work done Bill. I aint even touching the nickname thing though, we'll let Scott take care of that one.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #171 of 2836 Old 01-18-2012, 08:51 PM
Skerr
Bill
Ahhh... and this is desirable?
I can't go there, Jim. I already had my wicked thought for the month!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #172 of 2836 Old 01-19-2012, 08:56 AM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
Here ya go Scott, this is the CAD.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #173 of 2836 Old 01-19-2012, 06:52 PM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
Hey, still motivated, did a little reworking of the skid plate. Put together a drive shaft, so I could move this thing around without pushing and pulling it
, once I get it running.
Put a plug in the hi pressure PS line to replace some kind of sending unit. ( no clue what its for)
This NP 241c transfer case is huge, as you can see in the picture. It not the stock TC.
Going to have a front DS issue, the stock DS u-joint is tiny compared to the 241 yoke. They do make u-joints with different ends. I have one the adapts a 297 or 760 to a 1350. Haha can't find it.
Put a new to me rebuilt starter on the 305, couldn't find the one I took off 2 years ago.
Currently in the process of bleeding the power steering of air, then finish with the final install of the exhaust manifolds.
Bill
ForumRunner_20120119_194615.jpg   ForumRunner_20120119_194657.jpg   ForumRunner_20120119_194845.jpg   ForumRunner_20120119_195003.jpg   ForumRunner_20120119_195112.jpg
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #174 of 2836 Old 01-19-2012, 07:02 PM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
Trying for a better picture of the TC. The same issues would be there on a CJ
Not hard to see why a slip yoke eliminator is needed
That tailshaft is 6" long.
Real fun tomorrow, I get to bend new tranny cooler lines, past the bell housing, starter, motor mounts fuel pump, taking into consideration the exhaust.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #175 of 2836 Old 01-19-2012, 07:13 PM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
One more post for Scott. Dipped my finger in, good stuff, Thank you and Beth.
On another note, one of our fire chiefs called today
Seems I took 1 to many vacation days. 24 hours pay will be deducted from my next pay check. No radiator for three more weeks.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #176 of 2836 Old 01-19-2012, 07:52 PM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
A post hore tonight, before cranking the engine with the starter, I prelubed with this and my drill, ran it till oil came to the rocker arms. Home made, works on AMC V-8's also. Nothing more than a 8" bolt, 2 coupling nuts, a hole, and roll pin.
Bill
Bill
ForumRunner_20120119_204952.jpg   ForumRunner_20120119_205033.jpg   ForumRunner_20120119_205214.jpg
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #177 of 2836 Old 01-19-2012, 07:54 PM
Skerr
Your welcome Bill. Hope you like it.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #178 of 2836 Old 01-19-2012, 07:57 PM
Skerr
Okay, Bill... I'll bite. I know ALL the motorheads know what that thing is, but I don't know what it does! 'Splain...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #179 of 2836 Old 01-19-2012, 08:17 PM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
Since you asked so nicely, I will. The large coupling nut slides down over the oil pump drive shaft. The roll pin engauges the slot in the shaft. This turns the oil pump, by use of the drill, sending oil thouout the engine, all the way up to the rocker arms.
If you could see the oil pressure gauge, (mechanical) you would see pressure.
The oil pump drive shaft, on the right in the first two pictures is for a SBC. AMC V-8's have the same kind of shaft. Don't know about the 258's never had a distributor out of one. Well I did, just didn't pay attention to the oil pump drive.
Maybe I should add, this tool turns the oil pump, just like the dizzy does.
Bill
ForumRunner_20120119_210858.jpg   ForumRunner_20120119_210919.jpg   ForumRunner_20120119_210955.jpg
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #180 of 2836 Old 01-20-2012, 05:05 PM Thread Starter
lucdog
lucdog's Avatar
1980 CJ5
Bent the transmission cooling lines today, wasn't as bad as I thought.
Put a relay in for the distributor 1 wire hookup, the wire from the fuse block wasn't large enough.
Finished up some wiring to the electric choke with a ground to the carb.
Still need to get a radiator and cable shift linkage, for the tranny. The YJ was a 5 speed.
Ya'll have a great weekend, Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
hill billy sr4 to T18 conversion kit CallMe_Lockouts Jeep CJ Forum 12 07-15-2011 02:34 PM
The General Lee raperfam Jeep CJ Forum 13 12-15-2010 07:10 PM
General CJ-7 questions Squish Jeep CJ Forum 8 10-22-2008 10:06 PM
the general? jeep795 Jeep CJ Forum 3 12-27-2006 09:46 AM
AM General CGrugger Jeep CJ Forum 9 01-10-2006 03:46 AM
