BIG PROJECT!! '82 CJ7 Ltd Ground Up Build! - Page 3 - JeepForum.com
post #31 of 49 Old 09-16-2012, 11:26 PM
Dadamsnv
1977 CJ5
Those shackles don't look lifted. Must be springs to fit 33s
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is online now
post #32 of 49 Old 09-17-2012, 02:25 PM Thread Starter
82bigdogcj7
1982 CJ7
Yea I doubt the shackles are lifted.... i had been asked how long the shackles were from eye to eye. I didnt know, but I also mentioned that they looked strange to me, so I posted a picture of them.
I'm thinking my springs must be lifted. Actually I'm hoping they are. Then I'll be able to explain why it could fit 33s, since the body mount blocks didnt seem like they were longer than stock. Then I wouldn't need to buy a lift...... Just maybe new shacklesl. I guess an add-a-leaf lift couldve been done, but I hope not.
82bigdogcj7 is offline
post #33 of 49 Old 09-17-2012, 02:35 PM
Dadamsnv
1977 CJ5
for me to be able to run 33s on my CJ5, I'd need 4" of lift. I don't think you could score that much from an add a leaf.
post #34 of 49 Old 09-17-2012, 07:24 PM Thread Starter
82bigdogcj7
1982 CJ7
yea ok good I thought that would be too much for an add a leaf. Although I guess an add-a-leaf and a normal spring lift could both have been done. I just don't like the add-a-leaf lifts cause it's just gonna make the ride stiffer than it needs to be.
That's a relief to know that it must already have some type of suspension lift. My rear driveshaft angle was getting just a bit on the steep side, and I didn't want to have to mess too much with the pinion angle or getting a cv shaft or anything. May still get axle shims though.
I'll have to measure those springs and shackles this coming weekend. Will the measurement while the springs are installed be accurate or do I have to take them off to get the correct reading?
post #35 of 49 Old 10-01-2012, 08:02 PM Thread Starter
82bigdogcj7
1982 CJ7
got the rest of the new frame painted over the weekend!!
I'll measure the sprigns when I get the axles off the old frame. Once I get the axles off, I think I will try and get some phosphoric acid and spray it on the axle so it can eat through the rust (once I get it off the old frame) then it will be a lot easier for me to sand any remaining rust off the axles and then paint them.
what do I watch out for? other than wearing glasses and gloves so i don't go blind. and not rinsing the axles with water and letting the acid eat through the steel haha.
muriatic acid is too strong right?
post #36 of 49 Old 10-01-2012, 08:45 PM
Dadamsnv
1977 CJ5
Go to home depot and buy "prep n etch" it kills rust easy, isn't super deadly, and the guys on the forum love this stuff!
post #37 of 49 Old 10-01-2012, 09:41 PM Thread Starter
82bigdogcj7
1982 CJ7
ok, interesting. never heard of it, I'll have to look it up. Does it kill rust over like a certain extended period of time or is it like an instant reaction like acid? guess I should just look it up lol
post #38 of 49 Old 10-01-2012, 09:58 PM Thread Starter
82bigdogcj7
1982 CJ7
well just looked it up real quick.... so it's based from phosphoric acid. My question is how much weaker is it than straight phosphoric acid?
post #39 of 49 Old 10-02-2012, 03:10 AM
Dadamsnv
1977 CJ5
I guess you leave it on overnight, then wash or wire wheel the residue off after a day or two of its bad rust.
post #40 of 49 Old 10-02-2012, 12:46 PM Thread Starter
82bigdogcj7
1982 CJ7
Yea from what I read briefly, thats what it appears you have to do. I wonder though whether the phosphorus based "prep and etch" is more watered down than just plain phosphoric acid. I should get a chemical breakdown sheet of that stuff. Plus, I dont think phosphorus leaves a sticky residue when it dries. Not sure though, I'll have to look that up.
post #41 of 49 Old 11-03-2012, 09:15 PM Thread Starter
82bigdogcj7
1982 CJ7
well.... it's been a while. I keep forgetting to take my camera with me when I go to work on the jeep. I have one little picture from my phone though.
Long story short, I got both axles off the old frame, and just slapped them on the new one real quick, didn't mount up the rear of the rear shackles or the front of the front. Just bolted the front rear springs and same with the rear front ones.
Probably won't be able to get much more done before spring. Next step was going to be to de-rust the axles with acid, but they may just get sandblasted come springtime. I'm not sure.
Would blasting the axles take more metal off then I want? Or if I used a softer media like walnut shells (too soft) or whatever... would that work without removing too much metal??
Here it is as it sits.
Next little project is to fix the hole in the hardtop, and throw it on the jeep with some doors and the tub I just got. Not actually mounted, just to keep the frame safe from snow getting in and to keep it all in one spot. I'll probably tarp over the whole thing also.
post #42 of 49 Old 11-03-2012, 09:21 PM Thread Starter
82bigdogcj7
1982 CJ7
Other good news is.... I finally got a lead on a good glass tub! I wanted one with a tailgate.... but that's practically impossible to find... so after a few months I settled for this tub.
The end result of it all is this will be picked up from Atlanta and I will pick it up from someone in Ohio! Keep in mind here that Atlanta is a 12+ hr drive for me!! And I found someone who is already heading that way who can help me out and pick that up for some gas money. What a blessing.
It felt so weird looking in the Atlanta craigslist
So here it is, such a nice midnight blue. Unfortunately the top and doors are already sold.... but I did get the front clip with it. yea yea I know they aren't good for offroading.... and are inconvenient in a number of ways..... but this is in good shape..... and it matches the tub!!
post #43 of 49 Old 11-03-2012, 09:31 PM Thread Starter
82bigdogcj7
1982 CJ7
also.... any ideas on this dash pad cover? It's supposed to slide over the original one. I don't think I've seen one before.... but I may have heard of them before.
post #44 of 49 Old 11-06-2012, 10:32 AM
wm69
I've got one on my green Jeep. Fit is ok, but not nearly as nice looking as an original dash (it covers up the "Jeep" on the passenger side).
Don't remember who made them. I bought mine back around 2000 and IIRC paid about $50-60 for it.
wm69 is offline
post #45 of 49 Old 11-07-2012, 12:13 PM Thread Starter
82bigdogcj7
1982 CJ7
hmmmm yea ok, that was my original concern, that it might not look very nice. he did tell me that it covers up the logo.... which I was also not too fond about.
He has a bunch of them that are new.... and he said $50 for it.... which isn't a bad price I guess, but I think I'd rather find a good condition original dash for it.
Thanks, that input helps.
Alpine Lizard Build Project Dadamsnv Jeep CJ Forum 4894 Today 07:57 PM
New Project - slow build 92XJT Jeep CJ Forum 60 06-19-2010 06:40 AM
My Bad Choice Project CJ7 Build jsc7002 Jeep CJ Forum 9 08-04-2009 11:01 AM
1979 CJ-5 ground-up project dirtyd5 Jeep CJ Forum 1 09-09-2008 07:37 PM
Project quick build - Rezurected Bard Jeep CJ Forum 36 05-21-2008 12:37 PM
