BIG PROJECT!! '82 CJ7 Ltd Ground Up Build! - Page 2 - JeepForum.com
post #16 of 49 Old 09-04-2012, 06:19 PM Thread Starter
82bigdogcj7
1982 CJ7
lol anything??
82bigdogcj7 is offline
post #17 of 49 Old 09-11-2012, 03:04 PM Thread Starter
82bigdogcj7
1982 CJ7
still tryin to confirm which trans I have......
also looking for a glass tub. I've been told it is possible to reinforce the rear of the tub so that you can put a tailgate in a tub that doesn't already have one. sound reasonably feasible? have seen a couple of clean steel tubs, but more glass ones, so that's what I'm sticking with for now.
post #18 of 49 Old 09-12-2012, 10:15 AM
wm69
bunch of info on GM tranny id here
http://www.thirdgen.org/techboard/tr...y-vs-late.html
http://www.nastyz28.com/chevy-transm...tification.php
You might have some other markings on the transmission you're not seeing.....
As for glass tubs....ick.
wm69 is offline
post #19 of 49 Old 09-12-2012, 04:54 PM Thread Starter
82bigdogcj7
1982 CJ7
why ick? where do you live at? I just don't wanna have to deal with the rust of the steel tub. I realize there are some reinforcements that will need to be made to the glass tub but why don't you like them?
the steel tubs I find have always been cheaper because they need to be completely redone. Glass tubs I can find one in pretty good condition for a bit higher price. The steel ones that are still steel and not bondo tend to be higher than a glass tub around me.
post #20 of 49 Old 09-13-2012, 02:53 PM
wm69
I'm in Arkansas, so not a lot of rust, BUT I don't like glass tubs because they crack/break instead of dent. I did put a fiberglass windshield frame on one of mine and it's been nothing but trouble due to the wiper pivot area not being reinforced and the inserts busting out where the hinges bolt up.
If you're replacing the tub, I'd get a good steel tub and just rustproof the crap out of it. That said, if you want fiberglass, it is your Jeep, and lots of people are happy with glass tubs. Just not my cup of tea.
wm69 is offline
post #21 of 49 Old 09-13-2012, 03:12 PM
Dadamsnv
1977 CJ5
This is looking like a fun and challenging build thread so far
Double check your leaf springs and shackles against stock measurements because I bet you already have a spring lift on the old chassis given the size of the tires.
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #22 of 49 Old 09-15-2012, 08:45 PM Thread Starter
82bigdogcj7
1982 CJ7
ok yea I can understand that from your perspective. I'm not saying that fiberglass is the strongest thing out there, and if I were ever to get a fiberglass windshield frame I'd definitely reinforce it before installing it.
The thing is, for all the complaining you probably see about the "rust belt" up here, it really does happen, and it's something that I don't want to happen again. I've found 1 steel body in 6 months that is for sale but is still $100 more than the fiberglass body I'm looking at. The glass body and the steel body are both in good shape. Steel one was re-done to some degree. I'd definitely be reinforcing the glass tub in certain key spots if I did get one.
post #23 of 49 Old 09-15-2012, 08:50 PM Thread Starter
82bigdogcj7
1982 CJ7
Thanks! it's intense for sure. Awesome. I was just wondering whether I might already had a suspension lift. Those body mount bushings were rubber and just crumpled right off when I uninstalled them. They didn't look that big. I say that because I was thinking it had a body lift.
A spring lift is a possibility tho. I've been told my shackles look home made. I didn't do them, so I guess the shackles could be an add on and the springs could be lifted a bit. Would I measure a difference in length and height vs stock springs?
How much do you think it's lifted to accomodate the tires?
post #24 of 49 Old 09-15-2012, 08:54 PM Thread Starter
82bigdogcj7
1982 CJ7
I've read a bit on here about rust treatment and different chemicals, so I just wanna throw this out there and see what the opinions are. I've read about the electrolysis process. Pretty cool, but takes a little while, and I will never have anything big enough to soak my axles in. I was reading about brushing or spraying on phosphoric or muriatic acid on the axles and letting it sit for 15 min I believe, then washing the acid off with soap and water. I realize that stuff is potent. Eye protection, gloves, the works I know. I'm wondering if I need to let it sit for longer or if it will eat too much into the metal at that point?
After that I was going to sand it down a bit, use some surface cleaner on it, and then some self priming vht chassis paint. Sound ok?
post #25 of 49 Old 09-16-2012, 01:45 AM
Dadamsnv
1977 CJ5
I've just been wire wheeling or sand blasting to bare metal, cleaning with brake clean after that, then painting with VHT chassis and rollbar paint. I really dig the VHT. It's great stuff
Dadamsnv is offline
post #26 of 49 Old 09-16-2012, 01:46 AM
Dadamsnv
1977 CJ5
How long are your shackles eye to eye?
Dadamsnv is offline
post #27 of 49 Old 09-16-2012, 07:55 AM
243
1978 FSJ Cherokee
You really have a lot of work ahead of you *and* 100X if you keep most any part of the body.
I can confidently say you will not keep rust away with any used tub, there will be rust between every panel flange on the tub and it will eventually find a way back through the paint. So I understand using a glass tub and the point about glass cracking is true, but do you plan to beat the Jeep wheeling it, or, plan on trail riding and less abusive use?
A Wrangler tub should be pretty easy to find and repairing the rust will get you much farther ahead in less time with a reasonable cost. If you budget allows, a new steel or glass tub would be worth it in my opinion.
Take some pictures of the trans now that it is out....best of luck to you
Dave's 78 Build
243 is offline
post #28 of 49 Old 09-16-2012, 04:12 PM Thread Starter
82bigdogcj7
1982 CJ7
yea I just found out about the VHT a few weeks ago, but I like it. seems to be good stuff. I'm trying to avoid wire wheeling my axles and differential cause that'd take way longer than spraying it down with some strong chemicals.
I wont be near the jeep for about a week unfortunately with my class load so I can't measure them right now. I'm trying to work on it on Fridays. I will say that my shackles are not stock. They seem almost homemade.
here are the front springs, not sure if anyone thinks I have a suspension lift. I think I must have one. body mount bushings weren't big when I took them off.
post #29 of 49 Old 09-16-2012, 04:21 PM Thread Starter
82bigdogcj7
1982 CJ7
Here are some pics of the steel tub I'm sort of looking at. yea I know keeping rust away can be a pain. That's why I wanted a glass tub from the beginning. But this tub seems to be in pretty good shape.
Wrangler tubs are certainly locatable, but it will also be a bit different and require some mods I don't want to have to do and have features I wont like.
Ex. Swing open tailgate, wrong location fuel fill, relocate body mounts etc.
I've been looking at used and pre-cut glass tubs rather than new ones. I don't want a new one really. More money and more work to make it ready.
Yea I'm definitely going to take a few pics of the trans when I get over to it at the end of the week.
And I 100% intend on NOT beating it up. I want to keep it in good shape once I get it good shape. Streeting it, with a little bit of trail time maybe.
post #30 of 49 Old 09-16-2012, 04:24 PM Thread Starter
82bigdogcj7
1982 CJ7
all the white in 3rd pic from top is dirt, nothing bad.
Alpine Lizard Build Project Dadamsnv Jeep CJ Forum 5263 05-23-2017 09:06 AM
New Project - slow build 92XJT Jeep CJ Forum 60 06-19-2010 05:40 AM
My Bad Choice Project CJ7 Build jsc7002 Jeep CJ Forum 9 08-04-2009 10:01 AM
1979 CJ-5 ground-up project dirtyd5 Jeep CJ Forum 1 09-09-2008 06:37 PM
Project quick build - Rezurected Bard Jeep CJ Forum 36 05-21-2008 11:37 AM
