big daddy tie rod and drag link - Page 2 - JeepForum.com
post #16 of 28 Old 08-28-2013, 01:17 PM Thread Starter
TRUVOL
Mine says 60 ft. Lbs
TRUVOL is offline
post #17 of 28 Old 08-28-2013, 01:25 PM
SamanthaRae
The whole tie rod is spinning before I even get to 3p ft lbs.
SamanthaRae is offline
post #18 of 28 Old 08-28-2013, 01:37 PM Thread Starter
TRUVOL
Same here. Don't know how I'm gonna torque it.
TRUVOL is offline
post #19 of 28 Old 08-28-2013, 01:42 PM Thread Starter
TRUVOL
I'm just replacing that one with another Moog tre
TRUVOL is offline
post #20 of 28 Old 08-28-2013, 01:46 PM
Spieg8
1984 CJ8
I believe the BD tie rods come with a wrench flat on the tube to hold it in place while you torque down the jam nut. If not, try a pipe wrench to hold it.
Spieg8 is offline
post #21 of 28 Old 08-28-2013, 02:33 PM Thread Starter
TRUVOL
Samantha how did the torque on your other ones do?
TRUVOL is offline
post #22 of 28 Old 08-28-2013, 02:37 PM
SamanthaRae
Neither tie rod end that went to the knuckle would torque. On the drag link they torqued fine. So I just put washers under the nut on the tie rod ends and got the cotter pin in to get it home.
post #23 of 28 Old 08-28-2013, 02:51 PM Thread Starter
TRUVOL
Keep me updated
TRUVOL is offline
post #24 of 28 Old 08-28-2013, 02:57 PM
SamanthaRae
I'm not sure what to do next. I read some things online that some people just run them with washers in it. Not sure what to do?
post #25 of 28 Old 08-28-2013, 07:10 PM Thread Starter
TRUVOL
Hey Samantha Just changed my one tie rod that came with the kit. I got another left hand thread Moog. Torqued to 40 ft lbs. Factory. The tie rod that comes in the kit is ****.
TRUVOL is offline
post #26 of 28 Old 08-28-2013, 10:34 PM
titomars
1981 CJ7
I have the same kit. I never even tried the supplied rod end. I bought the 3 Moog ends I needed and the one end I went to a heim joint end. I run an SOA so I did a modified drag link flip which required something other than a standard TRE on the knuckle side. The Moog's all fit fine on mine. here is a trick for tightening a spinning TRE. take a drift and insert into the cotter pin hole and then use an open end wrench and tighten till it hits the drift. Usually the 1/8 turn is enough pressure to hold the stud to finish tightening the nut. another method is to use a jam nut instead of the castle nut to tighten also using the drift to hold the stud but with a jamb nut you won't get the interference of the slots against the drift pin. torque it down then remove the jam nut and install the castle nut.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #27 of 28 Old 08-29-2013, 12:18 AM Thread Starter
TRUVOL
Get it aligned in the morning
TRUVOL is offline
post #28 of 28 Old 08-29-2013, 12:19 AM Thread Starter
TRUVOL
Happy happy happy
TRUVOL is offline
