Better Brakes ?? - JeepForum.com
post #1 of 5 Old 03-15-2002, 03:28 PM Thread Starter
LS1CJ5
1979 CJ5
Post Better Brakes ??
Has anybody found a good path to improved front brakes? I was thinking someone has had to do this before. Any ideas? My LS1 needs to stop a little better.
Thanks
Larry
1979 CJ5 LS1, NV4500
LS1CJ5 is offline
post #2 of 5 Old 03-15-2002, 04:47 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Post
If they are drums right now, simply going to disc will make a big difference.
If they are already disc, there are a few options:
1) If you have a lift, you can get the stainless braided hoses, they have a smaller inner hose diameter, making the brakes more responsive (they are longer than stock, so no good if you have no suspension lift, and also available for the rear hose).
2) You can get high-performance rotors, with grooves in them, they provide quicker stopping power and better heat dissipation, they even have them in Stainless Steel.
3) If your master cylinder is manual, you can look into switching over to a power brake setup, buying the booster and everything else for the conversion.
4) You can buy the rear disc conversion kit, switching the rear drums to disc (pricey, and personally, my last option I would ever use, since rear brakes only supply 20% to 25% of your braking on average, I would put more money into front brakes or the power conversion).
4wheeler4CJ is offline
post #3 of 5 Old 03-15-2002, 09:14 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Post
What year is your Jeep and What brake size/setup are you running now?
bazinga
jeepdaddy2000 is online now
post #4 of 5 Old 03-16-2002, 12:06 PM
Bulletproofcj7
Post
I agree with 4wheeler,thats a good plan,another thing to think about is that rear drums suck in reverse! whereas a disk brake works equaly as well. Good for wheeling when you just cant quite make it to the top of that hill climb and need to back down slowly.
just my .2cents worth
Oh and just FYI, they do make DOT approved stainless steel brake lines.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #5 of 5 Old 03-18-2002, 02:14 PM Thread Starter
LS1CJ5
1979 CJ5
Post
Thanks everybody. I'll do options 1,2,3 and 4 if I budget just right. It's an 1979 with a Dana 44 from an 86 in the back. The front will be updated to wide track soon.
LS1CJ5 is offline
Need opinion....Manual Brakes/360 to Power Brakes Rollbar Jeep CJ Forum 16 04-08-2009 11:06 PM
cj brakes to power brakes worth it? drunkenrich Jeep CJ Forum 21 02-15-2008 03:25 PM
Manual brakes to power brakes theclothman Jeep CJ Forum 17 06-18-2007 05:40 PM
Manual brakes to power brakes. NOVACAIN350 Jeep CJ Forum 4 04-27-2007 09:16 PM
Hydraulic brakes to power brakes question Jeep'N 4 Fun Jeep CJ Forum 5 03-05-2003 11:00 PM
