Best Way to weld on axle tube - JeepForum.com
post #1 of 7 Old 09-27-2011, 08:47 PM Thread Starter
Jp78cj5
1978 CJ5
I have installed a sway bar on my 78 CJ5. I have replaced the lower spring plates with the ones that have two posts pointing towards the tire, one on each side of front axle. The rear post is for the shock and the front would be for the disconnect. The disconnects will not disconnect due to clearance problems. The JKS disconnects came with a tab that can be welded to the axle tube to act as the lower connection point for the disconnects. My question is simple. I do not want to remove the axles from the tube. I just want to weld the tabs. Is there a trick to not boiling out all the axle grease or is that not really an issue? I have ran searches on the topic but the search tool takes "Weld", "Axle" and "Tube". As you can guess, there are over 250 threads that have those words and although there are some really nice build threads, I am not finding the answer. Thanks for all the help in advance.
Jp78cj5 is offline
post #2 of 7 Old 09-27-2011, 08:52 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Having a 4x4 shop do the welding would be best. You can wrap the axle tube either side of the weld in wet towels to absorb the heat. Weld short beads, with plenty of time between welding sessions to keep the heat build-up to minimum.
CJ7-Tim is offline
post #3 of 7 Old 09-28-2011, 12:07 AM
HotJimmy
Just weld the little tabs to the axle. No problems.
HotJimmy is offline
post #4 of 7 Old 09-28-2011, 11:28 AM Thread Starter
Jp78cj5
1978 CJ5
Thanks
Jp78cj5 is offline
post #5 of 7 Old 09-28-2011, 11:30 AM
justanotherjpr
I would just weld them on. Maybe weld them in steps if you are worried about it, rotating between each tab, each side.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #6 of 7 Old 09-28-2011, 02:12 PM
82JeepCJ7
1982 CJ7
Welding a tab your not going to build heat in the tube like you would on something larger. Skip around from side to side with some short pauses in between and you will be OK. Just make sure the metal is clean and get some good penetration. What welder/wire/gas are you going to be using?
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #7 of 7 Old 09-28-2011, 03:34 PM
80cj
80cj's Avatar
1980 CJ5
You're talking about the front axle right? No problem as there is no oil in the axle tube. In fact, there is normally a space between the the axle shaft and the tube that would allow things to vent.
80cj is offline
AMC 20 axle breather tube SuB8HaVeN Jeep CJ Forum 13 02-07-2011 08:18 PM
should I weld my axle tubes??? joecool79 Jeep CJ Forum 7 02-16-2010 12:04 PM
Bent axle tube BioTex Jeep CJ Forum 4 06-23-2009 08:58 PM
axle tube vent for amc 20 spk454 Jeep CJ Forum 9 10-17-2008 02:49 PM
