Best way to remove Spring Shackle bushings? - JeepForum.com
post #1 of 14 Old 02-06-2011, 04:50 PM Thread Starter
Brettm0352
So what's the best way to remove old spring shackle bushings? I'm trying to get them off the rear frame spring shackle bracket.
1973 CJ5 frame-off resto-mod - 304,t176,d300
2004 Wrangler Rubicon - DD
Brettm0352 is offline
post #2 of 14 Old 02-06-2011, 05:21 PM
Scooter402
Theyve got to be pressed out. You can do it with a vice if youre careful.
Oh, and thanks, Devildog.
Scooter402 is offline
post #3 of 14 Old 02-06-2011, 05:33 PM
greengiant1
1947 CJ2A
Just did it. Use a small cutting torch. Heat the center sleeve and the rubber will melt out. Now cut a slice in the outer sleeve without cutting the bushing support. Tap it out with a punch. The sleeve material is so thin that I had no luck pressing them out. If no cutting torch is available, a propane torch could be used to melt the rubber bushing out and then a grinding bit to slice the outter bushing. I used a large c lamp to press them back in. Kind of hard to get the jeep frame in a press sideways. ha ha
greengiant1 is offline
post #4 of 14 Old 02-06-2011, 06:33 PM
Scooter402
Hm. Removing parts works wonders. Or just eat your wheaties
post #5 of 14 Old 02-06-2011, 07:34 PM
CJ8Extreme
1983 CJ7
the only two ways I have found to remove rubber bushings is 1) torch as stated above, which is messy and can be time consuming using a propane torch. 2) if you plan to use poly bushings then you don't need the thin sleeve that the rubber bushings need. If you can get a small cold chisel or punch then you can sometimes knock it out with the rubber bushing.
CJ8Extreme is offline
post #6 of 14 Old 02-07-2011, 09:56 AM
scrapman
I just went through this myself.
First I used a drill to get the rubber and inner sleeve out. Then I used a torch to lightly cut the outer sleeve out. I knew there had to be a better way, so I googled it and this way worked for me.
http://www.handymanxchange.com/remov...kle-vt148.html
You stick a screw driver in the gap in the spring eye and hammer it in to open the gap a little. You can then pound the bushing out with a hammer and a socket that is slightly smaller than the eye. The eye closes back tight after you remove the screwdriver.
I also used this method to help get the new bushings in.
PS. This method is much easier if the springs are off the jeep.
scrapman is offline
post #7 of 14 Old 02-07-2011, 10:03 AM
82JeepCJ7
1982 CJ7
I chucked up a thin sawz-all blade in the sawz-all and sliced the inner sleeve. Then I used a punch to collapse the sleeve and drive it out. Did pretty much the same thing on the bushing parts.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #8 of 14 Old 02-07-2011, 11:25 AM
yippie21
1979 CJ7
I was just about to do this . Glad I saw this thread. I bought some poly bushings (Rancho) and see they are two-piece.. I guess I thought they'd be one-piece. I'll have to do some searching to see if others have had any trouble with them.
'79 CJ7
'09 JK Unlimited Sahara ( sold )
'97 TJ (sold )
yippie21 is offline
post #9 of 14 Old 01-30-2015, 01:33 PM
JackStanton
I have a 1960 willys, and am replacing the suspension, something I thought would be relatively easy. The old bushings in the frame (for top part of shackle) have been a nightmare. The inner sleeve and rubber popped out, but the outer sleeve is 'welded' to the frame, and even after cutting thru sleeve with hacksaw, and using a punch aggressively, all I have is a messed up sleeve still firmly attached within the eye -- have also applied penetrating oil liberally. Any ideas? Do you think heating the frame with a butane torch could help?
Thanks
JackStanton is offline
post #10 of 14 Old 01-30-2015, 01:41 PM
JackStanton
Thanks
post #11 of 14 Old 01-30-2015, 01:43 PM
JackStanton
Sorry for the double entry -- I am getting an error message from site asking me to register again -- but apparently it took the first time..,.
Also SCRAPMAN -- can you post the full link -- I am not finding it.
Thanks again
post #12 of 14 Old 01-30-2015, 03:17 PM
Stumpfarming
1974 CJ5
I just did this about a week ago. My rubber was toast, so I drove a screwdriver through the rubber in between the inner sleeve and outer sleeve until I deformed the inner sleeve and it tore away the rubber enough to drive the guts out with a punch. To get the outer sleeve out, I cut a notch lengthwise in the sleeve, just deep enough to cut through the sleeve, but not so deep that I cut into the frame hole (maybe a small scratch or so). This relieved the tension. I then filed a washer down to the same diameter of the sleeve, so that it barely fit inside the hole. You can then used a long bolt as a punch to drive it out, or used a bolt (or threaded rod), nut and washer in conjunction with a larger socket to press the sleeve out, much like you would with a balljoint press.
http://www.jeepforum.com/forum/f22/stumpfarmings-73-cj5-build-1935041/
Stumpfarming is offline
post #13 of 14 Old 01-30-2015, 03:21 PM
Stumpfarming
1974 CJ5
Here's some pics showing how I did it. Read description above.
post #14 of 14 Old 01-21-2016, 12:04 PM
258
Cj Rear Shock Bushings (Bottoms)
Helpful - THANKS!
258 is offline
Remove spring to replace bushings?? Dborns Jeep CJ Forum 2 02-23-2010 04:12 PM
Poly Spring and Shackle Bushings sanddrag Jeep CJ Forum 7 12-16-2009 09:08 AM
shackle bushings poly or OEM? keithf Jeep CJ Forum 8 01-10-2009 08:21 AM
Spring/Shackle Bushings Blue83CJ7 Jeep CJ Forum 4 12-04-2006 02:47 PM
CJ Shackle Bushings HighCountry Jeep CJ Forum 2 02-17-2002 06:34 PM
