best way to ground with fiberglass tub - JeepForum.com
post #1 of 10 Old 05-18-2010, 09:59 AM Thread Starter
eagleCJ7
I'm having some issues with my electrical systems. I think most arise from poor grounding because of the glass tub. So here is a question for all you glass tub owners. What is the best method for grounding when you have a glass tub? and what have you done. Pictures would certainly help if you have them. I tend to be a visual guy. Thanks in advance.
eagleCJ7 is offline
post #2 of 10 Old 05-18-2010, 10:03 AM
JoonHoss
2011 JK Wrangler
my '57 had a fiberglass front clip, and everything was ran to a dedicated common-ground, which was run to the frame. I don't think there's much else that can be done. you need a dedicated ground (perhaps even a busbar-type terminal?)
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #3 of 10 Old 05-18-2010, 10:13 AM
Mike Romain
I ran a battery cable over to a long bolt by the fuse panel back where I just added soldered and heat shrinked loop connectors to for each ground wire. On my last harness I used a bolt with those screw plug buss terminals on it and had some corrosion issues with the open end of the copper wires. I used lots of dielectric grease which seemed to stop the issues.
I ran a dedicated 10 gauge wire inside each harness piece to pick up the components as they came along. My new harness from Centech also has this dedicated ground for the back and dash, but not for the front clip so I just used the 10 ga wire in that piece.
Here is my old one:
Mike
Mike Romain is offline
post #4 of 10 Old 05-18-2010, 11:26 AM
Exposed
Exposed's Avatar
1981 CJ5
I have about 95% of the engine compartment done on mine. I will take some pictures this evening on how I ran the grounds.... I used this stud type ground block to go through the firewall. Everything in the harness was tied to a 10 gauge ground feed inside to the block. Firewall side ties to the negative on the battery. This way did not have to run a large ground wire from battery to to inside. Also added one on the fender to feed grounds to everything on the engine side. Just like Mike said, ground header feed to every component.
Calvin
81 CJ5, Ford 331 EFI, AX15, D-300, Dana 44 (Detroit Locker)....
When there are more people voting for a living than working for a living,
We are DONE as a Country!!!!!!
Newly Acquired 2014 Grand Cherokee Summit
Exposed is offline
post #5 of 10 Old 05-18-2010, 11:33 AM
Dudman5703
I have A thick wire that runs from my frame and hooks onto my metal dash. I have grounded everything including (windshield wiper motor, after market radio, ect.) to the metal dash which all carries down onto the frame.
After a while though I moved the grounding of the radio to the negative on the battery, as at higher volume the dash wouldn't ground it good enough and it would turn off then back on.
If you have a fiber dash I would probably go with a metal clip on the back of the dash or ran along the firewall which would be yet again ran to the frame.
For the hooking to the frame I drilled and tapped a whole and put a bolt through there. Then ended up welding it right on there since I knew I wouldn't have to take that wire out and I never wanted it to get lose or fall out.
Dudman5703 is offline
post #6 of 10 Old 05-18-2010, 04:44 PM
Exposed
Exposed's Avatar
1981 CJ5
I went out and was going to take a picture of the block on the firewall and there is so much stuff in front you can't see it very easily... Here is a shot of the fender ground/hot feed blocks. Relay on left is winch relay and one on right is starter....
Calvin
Exposed is offline
post #7 of 10 Old 05-18-2010, 04:56 PM
JeepHammer
Running On Empty...
1973 CJ5
The same way you ground ANY Jeep you want the electrical components to work on...
DEDICATED GROUNDS.
One that runs from battery negative to solenoid, then on to the front grill for front lights.
One that runs to alternator housing.
One that runs to engine, then to ignition harness ground.
One that runs to the dash for gauges, switches, ect.
LARGE one that runs to starter, then to frame.
One that runs to back of vehicle for rear lights, fuel tank sender, ect.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #8 of 10 Old 04-04-2013, 10:58 AM
clubbs
I did a fiberglass body swap on my friends 83 cj7 (5sp 6cyl all stock ignition and wiring, no cruise control no radio) this past weekend, did it all in two days including new paint on the tub front clip and windshield frame. I get the dash and harness back in and immediately start running new grounds. I get marker lights, dash lights, horn, flashers, volt meter, cigarette lighter, all to work but no ignition, and no headlights yet. I can run a jumper to the solenoid and she fires right up with the key in the "run" position. Switching the key to the off position shuts off the motor. But it won't energize the starting solenoid. I get voltage to the coil in "start" position though. I've looked over the wiring harness and haven't seen a ground for the ignition switch, what am I missing. I was trying to not have to drop the dash and column out again but its looking like I need to tone out some wires. If anyone has any pointers I'd greatly appreciate some input.
Thanks in adavnce
Dave
clubbs is offline
post #9 of 10 Old 04-04-2013, 05:15 PM
skizriz
1978 CJ7
Thanks in adavnce
Dave
Did you ground the solenoid??
skizriz is offline
post #10 of 10 Old 04-05-2013, 02:31 PM
clubbs
yes solenoid is grounded. I took the dash and column out last night and realized I had bumped the ignition switch and it simply wasn't moving far enough to make contact... Once I moved it a bit it started right up
Now I just have to get the wipers, headlights, and heater fan to work and I'll be all set.
clubbs is offline
Fiberglass Tub thiswebs4u Jeep CJ Forum 3 04-07-2011 07:28 PM
cj5 ground up troy.j Jeep CJ Forum 4 02-16-2009 07:24 AM
Help with ground!! jimbos76cj Jeep CJ Forum 4 06-10-2007 01:14 PM
Tub ground Pick01 Jeep CJ Forum 3 04-13-2007 04:55 PM
where is the ground? mike360 Jeep CJ Forum 3 08-03-2006 06:15 PM
