Best way to fix a BBD? - Page 2 - JeepForum.com
View Poll Results: What is the best way to fix/repair a Carter BBD?
Rebuild it. 10 40.00%
Replace it. 10 40.00%
If replaced use, Weber 32/36 DGEV 5 20.00%
If replaced use, Weber 38/38 DGES 2 8.00%
Multiple Choice Poll. Voters: 25. You may not vote on this poll
post #16 of 27 Old 09-08-2011, 08:36 PM
CSP
BBDs might be fine after rebuilding, rebushing, etc. but point any of them up a steep hill and they will flood.
CSP is offline
post #17 of 27 Old 09-09-2011, 12:05 AM
BagusJeep
1981 CJ7
Mine doesn't and I live at the top of a very steep hill.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #18 of 27 Old 09-09-2011, 12:36 AM
BagusJeep
1981 CJ7
Originally Posted by tdkask View Post
I just hated the idle tube issues and constant aggravation. I understand that they worked for 30 years, but mine always had problems. Since my swap (only 3 months ago) I have driven my CJ every day but 3 and have not had to touch the carb for any reason. Also, I can now pass people on the highway and accelerate to to speed (probably not more than 80... haha) reasonably with stock gears and 33's.
Thise idle tube issues are a pain. I fixed mine 3 years ago, put some new filters in and no trouble since. Bagusjeep has only stopped twice from working in the last 3 years and that was for a dodgy electrical connection to a pump and a broken axle.
The BBD is characterised as being unreliable but I find it a reliable if unexciting piece of kit.
P.S. I pass people at all speeds, but no one drives that quickly here.
post #19 of 27 Old 09-09-2011, 09:40 PM
86cj74.2L
86cj74.2L's Avatar
I have a base plate rebushed sitting on a shelf and a dead bbd in a box. When the throttle shaft guides wear to the point I can't compensate for it I'll put the other base plate on.
When the throttle shaft bushings wear out it messes up the idle and the fuel needle position will no longer match the butterfly position causing a hesitation. I just modify the slot so that the needles move as soon as the butterfly's start moving.
I like the BBD soo much I have done the nutter bypass with a twist. I paralleled the dizzy pickup with a MSD box. All the 'Puter Does is control fuel mixture. Timing control is know longer part it.
As a side note........the 258 has been known to have intake manifold gasket leaks. Which on turn cause some problems similar to a carb needing rebuilt. I wonder how many did carb swaps and still had carb problems when they were done? Or did a carb swap and redone the manifold gaskets at the same time when only gaskets would have fixed their carb problems.
86cj74.2L is offline
post #20 of 27 Old 09-09-2011, 09:45 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
i agree, mc2100 or tbi. the howell tbi kit is nice and they have great support. only down side is i found the wiring harness isnt very long at all.
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #21 of 27 Old 09-10-2011, 12:03 PM
Mike Romain
Then the float isn't set right. We climb sand pit and ravine walls until we are so steep the tires just churn in and none of the BBD's I helped folks tune ever stalled out on us. Check my sig line out for photos.
One trick about the float is you need two wrenches to put the gas line on or you will mess up the float level. One wrench has to hold the brass fitting at the carb or it will compress it's gasket which is the other side of the float setting.
Mike
Mike Romain is offline
post #22 of 27 Old 09-10-2011, 04:07 PM
jeeperjack
If your BBD has the electronic "growth" sticking out the back of it go to the salvage yard and get a Dodge 318 truck BBd that does not have one. Have to go back in the 70's to get one before Holley repooped them. Use the Jeep base plate to keep your choke working. Install the upper assy to it. It will then be a much better carb. Play with the timing, advancing till spark knock sets in, back off till it is very faint or gone. Adjust the metering rods down till you get a stumble and move them up just a fine hair till it smooths out. Will run much better and increase mileage by 2-5 mpg. Have fun!
jeeperjack is offline
post #23 of 27 Old 09-10-2011, 09:14 PM
foggybottombob
I rebuilt my BBD and had never taken apart a carb before. Like CSP says, the only problem I have is that it floods and stalls when you are in near vertical positions going up hill. Otherwise I have not had any more problems with the BBD and it even idles now 2 years after the rebuild.
foggybottombob is offline
post #24 of 27 Old 09-10-2011, 09:28 PM
afgd1
have 2 of them one new got it from oreillys 216.00 have other one had it rebuilt put it in box coverd with plastic, sealed ytou can get really good at changing them out quick have friend that had weber took it off didnt like it he put ford carb on cj he likes it almost gets beter gas mileage then me
afgd1 is offline
post #25 of 27 Old 09-10-2011, 09:35 PM
tdkask
I too got really good at swapping out my BBD or taking it apart, cleaning the idle tubes, reassembling, and reinstalling. I have not gotten any practice doing any of that with my MC2100 (from '73 CJ5 w/304), as it has never faltered.
Increased dependability, increased power, better mileage (depending on driving habits) originally on a Jeep anyway.
80 CJ7_360_32RH_D300_44/9"(4.56)_custom bumpers/cage
4" lift,tube fenders,comp cut_37s on H1 rims
tdkask is offline
post #26 of 27 Old 09-10-2011, 11:18 PM
pcg7384
1981 CJ7
Swapped mine out with a MC2100. $40 at a U-pull it yard, $25 rebuild kit, $10 new jets, $10 spacer, $10 air filter housing. Much better power, smoother idle, and added 5 MPGs to my gas mileage.
Sold the Carter BBD on E-bay for $50...Sucker.
pcg7384 is offline
post #27 of 27 Old 09-12-2011, 07:27 AM
CSP
We have a different interpretation of what the definition of steep is. Building materials don't make it up what I'd call steep.
Again, same thing.
CSP is offline
