Best Swap for a Quadratrac transfer case? - JeepForum.com
post #1 of 21 Old 07-17-2008, 03:48 PM Thread Starter
k1llerkyle
I am having issues with my transfercase in my 76 CJ7. Wondering what you guys think would be the best swap out for it? Should I swap back in another? Is there something better I could put in place of it?
I have a 304 v8 with the th400 auto....
k1llerkyle is offline
post #2 of 21 Old 07-17-2008, 04:37 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Can you explain your issues? Many times simple repairs of the unit will far outweigh the cost of a swap.
jeepdaddy2000 is offline
post #3 of 21 Old 07-17-2008, 04:49 PM Thread Starter
k1llerkyle
I think the chain is just stretched... seems to be slipping under load. I have not took it apart yet, but I am thinking that is what it is.
I was thinking a swap, as I know that the quadratrac doesnt have the best low range......
Thoughts?
post #4 of 21 Old 07-17-2008, 05:20 PM
243
1978 FSJ Cherokee
What do you use the Jeep for?
There was no way I could mistake the chain jump on my Waggie's QT...bang, bang bang during acceleration right under my butt. Splitting the case is an easy job, many will counter with the cost of the the QT fluid but it doesn't take much to fill it up.
The low range is 2.57:1 compared to the D300 2.62:1, virtually the same.
Dave's 78 Build
243 is offline
post #5 of 21 Old 07-17-2008, 05:31 PM
bigjoe
1977 CJ7
I'm with jeepdaddy on this. If you believe the chain is jumping (most times it's do to lack of service, changing fuilds, checking chain slack) your best bet maybe to just do a part-time kit for the tcase. Mile-marker makes one with 16% overdrive. You could do part-time kit and add a low-range unit and be done. If you decided to swap out the Quadratrac I think only a Dana 18 case will work with the offset rear diff. You will also need adapter and new tail shaft for the 400. FYI the adapter verse the conversion kit is around the same price of $500 and change. Don't forget you'll need to make changes to the drive shaft lenghts as well. Hope this helps a little.
bigjoe is offline
post #6 of 21 Old 07-17-2008, 05:32 PM Thread Starter
k1llerkyle
YEP that is it.... i thought it was the rear driveshaft slipping.. but nope....
I use this jeep to beat around on the trails.. at least thats what I bought it for. It has a 4 inch suspension lift, 2 inch body, and 35s....
post #7 of 21 Old 07-17-2008, 06:13 PM
ndigilio3
find a 300, buy an adapter for the 400, put it in and call it good
ndigilio3 is offline
post #8 of 21 Old 07-17-2008, 06:49 PM
Totallymetal
I would fix the quadratrac, I love mine with low range and TH400.
2007 JK Rubicon
5.5 Rock Krawler X-factor lift w/37 x 12.5 x 17 BFG KM2s, 5.13 Superior gears
Warn Powerplant HD
Totallymetal is offline
post #9 of 21 Old 07-17-2008, 07:04 PM
jfwireless
1976 CJ7
I rebuilt my QT and TH400 and they are running just fine. I have read several articles online about the QT part time kit. It really does not improve gas mileage much at all, so I do not believe it is worth the cost, time effort.
Rebuilding the QT is most likely your best bet. Make sure you get a Borg Warner chain, not a cheep imitation.
Jim
jfwireless is offline
post #10 of 21 Old 07-17-2008, 09:07 PM
No_Bs
1977 CJ5
I'm going to have to agree with tossing it..... If it's an off road only jeep, there is no point in keeping the q-trac. Unless you can just get another, toss it in and call it a day, go with a 300, or swap out the auto for a manual.
1977 Cj5, 258, T-18, 2.46:1 Dana 20, 2.5" BDS lift, OBA, 38.5's. Chevy 60 frt, 14b Rear, Full hydro, 102"wb, full DOM cage.
No_Bs is offline
post #11 of 21 Old 07-17-2008, 09:07 PM
jeepdaddy2000
1971 CJ5
The pluses to the part time kit are the ability to unlock the front axle. This can be important if you have a failure anywhere in the front system. You will also get a bit better fuel economy, better steering manners, and a huge drop in wear in the front axle. It also eliminates the need for the expensive Q trac fluid. Either way, changing the chain is a pretty straight forward job. Much less expense and effort than a conversion.
post #12 of 21 Old 07-17-2008, 09:20 PM
bigjoe
1977 CJ7
Someone correct me if I'm wrong. Isn't the Dana 300 tcase rear output in the center? Since the Quadratrac Jeeps are offset to the pass side of Jeep wouldn't the angle be pretty extreme for the rear drive shaft to work with a 300 case?
bigjoe is offline
post #13 of 21 Old 07-17-2008, 09:24 PM
No_Bs
1977 CJ5
Yes and no. It really depends on the length of the rest of the drivetrain. With the auto, no way. With a factory CJ T18/ Dana 20, probably fine. So yeah, I stand corrected. However, this is only a rear issue, if it were me I would ditch the offset rear and get a centered axle, but that's just me.
No_Bs is offline
post #14 of 21 Old 07-17-2008, 11:22 PM
243
1978 FSJ Cherokee
It's only 8.00 a quart so less than 25.00 from Crown...if cost is really an issue, you can use non-detergent 30W motor oil and a friction modifier.
If it's never on the highway, leave it in e-drive and weld the spiders.
Dave's 78 Build
243 is offline
post #15 of 21 Old 07-17-2008, 11:32 PM
243
1978 FSJ Cherokee
Sorry if I sound like a Quadratrac slut but I am...they are cool, innovative (when introduced) and reasonably strong xfer case with a lot of advantages for a dual purpose 4x4. I hammered my QT behind a strong 401 in my Waggie and it never whined. It may not be right for everybody or even the OP but a chain solves the number one problem in about 8 hours.
The NP205 may be a reasonable option behind the T400.
Dave's 78 Build
243 is offline
Quadratrac transfer case ... chain replacement k1llerkyle Jeep CJ Forum 3 01-31-2010 10:44 AM
transfer case swap? allornothin Jeep CJ Forum 6 12-10-2009 03:49 PM
Transfer Case Swap Crunch56 Jeep CJ Forum 3 02-02-2009 09:56 AM
Quadratrac Transfer Case rpippett Jeep CJ Forum 6 06-21-2007 02:33 PM
Quadratrac Transfer case.......... Quadratrak Jeep CJ Forum 5 02-23-2003 10:10 AM
