Best mpg mods - JeepForum.com
post #1 of 19 Old 10-06-2013, 02:56 PM Thread Starter
sgtusmc_nc
1978 CJ5
Best mpg mods
What are any and all upgrades or mods I can do to improve fuel mil. For a 78 cj with 3 speed. Jeep is my hunting/daily driver 3 days a week.
sgtusmc_nc is offline
post #2 of 19 Old 10-06-2013, 03:02 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Fill out your profile completely, otherwise we can't make many suggestions.
A thorough tune-up is probably your best bet.
Matt
Matt1981CJ7 is offline
post #3 of 19 Old 10-06-2013, 04:33 PM
LumpyGrits
MPG and Jeep CJ's, do not belong in the same sentence.
Whatever you do. You will not see any cost recovery in gas savings.
It's just the price of 'admission' for driv'n the real deal.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #4 of 19 Old 10-06-2013, 05:27 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Fuel economy increases come in three categories:
Basic maintenance:
This includes insuring your fuel system is operating properly, ignition system is sound, air cleaner clean, thermostat operating at temp, exhaust system isn't mashed, cat operational, tire pressure, dragging brakes, etc...
Optimization: This can run from free to thousands of dollars depending on what has been done to the Jeep and what your trying to accomplish. Examples starting with the cheapest; bumping the timing, opening the plugs, jetting the carb, installing a fan clutch, re-gearing the diffs to match the big tires you had to have (this is a big one), and of course, slowing down....
upgrades: These usually help performance, many times with a small boost in fuel economy (if the Jeep is driven prudently), but usually won't come close to paying for themselves in the end; Aftermarket ignition systems, changing carbs, FI, different exhaust systems, upgraded cam, transmission swaps.
usually if you start with maintenance and work your way through the cheap optimization list, you can bump your economy up with little or no out of pocket expenses. If course, such things as a tired engine, or poor gearing will defeat you before you get started.
jeepdaddy2000 is offline
post #5 of 19 Old 10-06-2013, 05:35 PM
LumpyGrits
OP, what's your ave. mpg now?
LG
post #6 of 19 Old 10-06-2013, 05:35 PM
WindKnot
1977 CJ7
LG is right on this. The whole nature of a Jeep is to take you places where you can't get to otherwise. Anything you do to increase mileage will interfere with its "mission".
Even its appearance shouts disdain and contempt for the wind tunnel. The engines are all about torque, and the transmissions and gearing are all about climbing. It carries the extra weight of a transfer case an extra driveshaft and another differential. Sipping gas is not what a CJ is about.
Jeep tried to play the mileage game during the gas crunch. The owners of those Jeeps today are the ones changing out the gears to ones more stout, and even they with their four cylinder engines will tell you they still get lousy mileage.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #7 of 19 Old 10-06-2013, 06:05 PM Thread Starter
sgtusmc_nc
1978 CJ5
Lol thanks, while I'm use to the classic truck mpg of 8-12 mpg. I'm just looking to not be around the 8 range and hopefully more by the 12-15 range
post #8 of 19 Old 10-06-2013, 06:09 PM
rcsutton
2010 JK Wrangler
EFI will help mileage & power all it takes is $$$$$$$$$$$$$$$$$$
2010 2 door JK Red Rubicon.
rcsutton is offline
post #9 of 19 Old 10-06-2013, 08:14 PM
holliewood61
holliewood61's Avatar
1981 CJ7
Only way I've found to save a little gas in my cj is to drive the tj instead. I'm like you in the 8 mpg range but the enjoyment I derive from driving it is worth every penny. If it got 2 mpg I'd just suck it up and put the gas in it
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
post #10 of 19 Old 10-06-2013, 08:26 PM
LumpyGrits
Mine gets 14-15mpg on level road and no head wind.
It's carb'd, and PRK smog legal.
LG
post #11 of 19 Old 10-07-2013, 02:18 PM
Balvar24
1979 CJ7
I'm pulling 16 mpg on a mostly stock set-up. Not getting in a big hurry helps quite a bit.
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #12 of 19 Old 10-07-2013, 04:53 PM
CJ7KAHUNA
Im getting similar results. Best I can figure is 16-18 and thats running a MC2100 and no smog gear. Not getting in a hurry is a huge mpg saver IMO.
EDIT:
I should ad that I don't have an odometer due to my speedo being out at the moment (using GPS for speed). My wife has been driving my CJ to work and back - a little better than 30 miles round trip - and she is getting about 4 days or 120 miles on roughly 6.5 gallons (varies depending on cost per gallon of gas)
My childhood was typical. Summers in Rangoon, luge lessons. In the spring we'd make meat helmets.
When I was insolent, I was placed in a burlap bag and beaten with reeds. Pretty standard, really.
CJ7KAHUNA is offline
post #13 of 19 Old 10-07-2013, 04:59 PM
swatson454
1983 CJ7
An optimized advance curve helps a bunch. My buddy has a bone-stock, mid-90s Chevy truck. He installed a data-logger on it that shows what the factory ecm is doing and it shows around 18* of advance at idle and runs a hair over 50* going down the highway.
I'm not suggesting that a Jeep with a six-banger needs those numbers but moving in that direction and away from the FSM specs should show good results.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #14 of 19 Old 10-07-2013, 07:27 PM
86cj74.2L
86cj74.2L's Avatar
Grammys CJ with everything still working smog wise is 16-18 also.
86cj74.2L is offline
post #15 of 19 Old 10-07-2013, 07:46 PM
superj
My slightly more then stock I6 get 12 in town and 15 on the highway.
Automatic, 4.5, offenhauser intake, four barrel holley, 3.55 gears, installed today a 2.5 lift with stock tires, and the advance plate in the distributor flipped to 18.
I also set my time and idle with a vacuum gauge so it is properly set for my engine, not set for a variety of pretty close to the same engines.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
