Best manual transmission for a 258 CJ7 - JeepForum.com
post #1 of 27 Old 04-03-2013, 07:42 PM Thread Starter
emt1236
1978 CJ7
I have a 1978 CJ7. I am in the process of rebuilding completely. I am at the point if having to decide on the transmission. I know I would like something that is streetable and useful off-road. I want durability. What is the best available. I prefer a 5 speed or 6. I am anxious to hear your opinions.
emt1236 is offline
post #2 of 27 Old 04-03-2013, 10:43 PM
titomars
1981 CJ7
for a 258 in a CJ and needs to be a 5 spd, that's easy............... AX15
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #3 of 27 Old 04-03-2013, 11:24 PM
BagusJeep
1981 CJ7
Look up the Novak transmission website, lots of good free info from experts.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 27 Old 04-03-2013, 11:51 PM
82JeepCJ7
1982 CJ7
5-speed= NV4500. Anything else is a door stop.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is online now
post #5 of 27 Old 04-04-2013, 01:08 AM
adams1985cj
Agreed I've been running mine for a long time with zero issues.
You donít buy it you build it!!
adams1985cj is offline
post #6 of 27 Old 04-04-2013, 06:18 AM
NoNative
Ditto this. I just completed this swap earlier this year. Huge fan. Same performance as the 176 1st thru 4th, but the overdrive gear is greatness.
1986 CJ-7 Laredo, 258, AX15, AC Dana 30/44, Ox Lockers, Howell TBI, DUI, 4.5" RE YJ Springs, 1.25" BL, clocked & twin-sticked Dana 300 with Lomax 4-1, 4.10s, 33s, PB, 8000# winch, YJ Roll Bar, Factory 20 gallon tank.
1984 CJ-7 Renegade, 258, T4, AC, Howell TBI, DUI, 2.5" OME YJ Springs, 3.53, 31s, PB, Warn bumpers & 8000# winch, Factory 20 gallon tank
1984 CJ-7 Renegade, 258, Auto, AC, 3.31s, PB, Factory 20 gallon tank, Bone stock except for 31s
NoNative is offline
post #7 of 27 Old 04-04-2013, 07:12 AM
mastercraftka
mastercraftka's Avatar
I have a T5, i know i know! So do either one, NV4500 or the AX 15 bolt right up? Any drive shaft mods?
1984 CJ 7
1948 CJ 2A
1982 CJ 7
1981 CJ 7
mastercraftka is offline
post #8 of 27 Old 04-04-2013, 07:50 AM
NoNative
Not sure about the NV4500, but to install the AX-15 you'll need to buy a clocking ring, a new bellhousing, new external clutch master cylinder (mounts by the power brake booster), modify the clutch pedal, and modify the tranny mount on the skid plate. Check out novak's website for parts, pricing and how to do it.
NoNative is offline
post #9 of 27 Old 04-04-2013, 01:07 PM
titomars
1981 CJ7
Not all of us can afford the extreme prices of the NV4500.
titomars is offline
post #10 of 27 Old 04-04-2013, 03:19 PM
82JeepCJ7
1982 CJ7
If you buy it from a company like Novak or AA, then yes, they can be expensive. If you buy a used transmission and swap it in yourself, it is much cheaper.
post #11 of 27 Old 04-04-2013, 04:07 PM
titomars
1981 CJ7
What is much cheaper? the lowest I have seen a used NV4500 in my neck of the woods is about 2k. For the 3k+ it would take to get it in and working, I would rather see my CJ painted. For that matter maybe a new tub
I am running a perfectly working T-5. I have never had a problem with it. I rebuilt it when I first got the CJ. In the past I used to drag race on T-5's there is nothing wrong with them behind moderate HP engines. An AX-15 is a much better trans and it's cheap to swap over. I have a fresh AX-15 in storage to swap into mine when the time is right. And before you say it, Yes I take my CJ off road alot. I just am not a rock crawler or deep mudder.
titomars is offline
post #12 of 27 Old 04-04-2013, 04:10 PM
82JeepCJ7
1982 CJ7
I passed on one the other day for $500. Craigslist is your friend.
post #13 of 27 Old 04-04-2013, 04:22 PM
titomars
1981 CJ7
Yeah C/L in the SF bay area must not be so friendly. That's where I saw one for $1,900.00. I'd be scared to even ask any wreckers here
titomars is offline
post #14 of 27 Old 04-04-2013, 04:29 PM
WNC-84CJ7
http://greenville.craigslist.org/pts/3720610464.html
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline
post #15 of 27 Old 04-04-2013, 04:49 PM
CSP
The OP didn't say anything about cheap or best bang for the buck. Just the "best", which in a 5spd would be the NV4500.
CSP is offline
cj7 , manual , rebuild , transmission
