Best hubs for a CJ-7 - JeepForum.com
post #1 of 15 Old 11-15-2012, 02:27 PM Thread Starter
Jester77
I'm getting ready to redo the brakes on my 1985 CJ-7 and I figured I might as well replace the front axle U-Joints and hubs while I'm in there.
Anybody got any suggestions on the best hubs you can put on a 1985 CJ-7 and where I might purchase them? I'm running with a stock Dana 30 front end.
Any help would be appreciated.
Jester
Air Force Jeep Club - Tail # 200
"You miss 100% of the shots you don't take." Wayne Gretzky
Jester77 is offline
post #2 of 15 Old 11-15-2012, 03:11 PM
CSP
Every time this subject comes up the same three players are mentioned, Warn, Superwinch, and Mile Marker.
Warn doens't make a premium hub for that year, so that leaves the other two, both of which are quality lockouts.
CSP is offline
post #3 of 15 Old 11-15-2012, 03:19 PM
dandd
1982 CJ8
Get a 6 bolt hub flange from a early CJ with disc (I think 79,80) and then you can fit the Warn (6 bolt) premium Hub's.
dandd is offline
post #4 of 15 Old 11-15-2012, 03:39 PM
keith460
Jeep. There's Only One
keith460's Avatar
Yeah, but the factory style center caps won't fit over them anymore if you have OEM wagon wheels.
Warn still makes replacements for them, same as OEM.
1984 CJ-7 Renegade
keith460 is offline
post #5 of 15 Old 11-15-2012, 03:47 PM
85LaredoCJ7
I converted my crappy 5 bolts to 6 bolt premiums with the stud kit on my 85'. You can kind of see them in the second pic.
The Dude abides....
85LaredoCJ7 is offline
post #6 of 15 Old 11-15-2012, 07:14 PM
Fatman
Fatman's Avatar
2008 CJ7
Agree, If you're going to actually use 4W drive, ditch the 5 stud bearing hubs for the pre- '80 D30 or D44 6 stud hubs. Then you can run decent hub locks.
Thread Links:
Fatman is offline
post #7 of 15 Old 11-15-2012, 08:03 PM
brownbagg
1930 MK Compass
the best hub out there is the one that wont break, or maybe you do. if the hub was the weak link it would save the rest of the drivetrain. so maybe just go to junkyard and get a spare to carry.
brownbagg is offline
post #8 of 15 Old 11-15-2012, 08:47 PM
only in a jeep cj
Ive been preaching that for years. I run stock hubs as a weak link. Id rather replace a hub any day rather than a busted ring and pinion, carrier, or axles.
As stated, weather your running the stock rims/center caps plays a big role in hub type as well.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #9 of 15 Old 11-15-2012, 10:36 PM
85LaredoCJ7
I run alloy shafts with an ARB. So, who knows what would give first. I'm not hard on my stuff, so I don't really worry about it to much.
The Dude abides....
post #10 of 15 Old 03-06-2013, 07:46 PM
maedwards
stud kit
were did you get the 5 stud to 6 stud hub kit I looking to changing my 85 CJ 7 also
maedwards is offline
post #11 of 15 Old 03-07-2013, 10:41 AM
wm69
This will work with factory wheel center caps, and is the best hub conversion you can get
http://www.ebay.com/itm/110810950047...9#ht_448wt_932
Hope you're rich.
wm69 is offline
post #12 of 15 Old 03-07-2013, 01:21 PM
CSP
There isn't a 5 stud to 6 stud conversion kit. There is a kit that converts from using bolts to retain the lockouts to studs. You can separately buy the parts to convert the wheelbearing hubs from five bolt WB hubs to six bolt WB hubs, but there isn't a "kit" that does both things.
CSP is offline
post #13 of 15 Old 03-08-2013, 10:09 AM
Agar426
1974 CJ6
Whatever happened to the "internally splined conversion" kit that Warn used to sell? I had heard that Randy's R&P picked up that line, but I'm not sure. Anyhow, that conversion was a little pricey, but was supposed to be a very good setup. One of the benefits was that it eliminated the external bolts, so there was nothing to worry about in terms of the bolts backing out or even shearing.
Agar426 is offline
post #14 of 15 Old 03-08-2013, 10:41 AM
CSP
That's the one wm69 has the ebay link to. I don't think Randy's ever put it back into production.
CSP is offline
post #15 of 15 Old 03-08-2013, 11:29 AM
Agar426
1974 CJ6
Correct...I should have caught that! The price it's going for is much more than it used to sell for new. The YJ & TJ conversions were major dollars, but the CJ conversion was under $300. That being said, it did force you to upgrade to the larger u-joints and outer shaft, but I could be mistaken. This naturally incurred further costs.
Agar426 is offline
