Best Gauge Designs - JeepForum.com
post #1 of 16 Old 11-27-2009, 02:14 PM Thread Starter
RetiredSERE
RetiredSERE's Avatar
1980 CJ7
Best Gauge Designs
So who makes the best gauges? Almost to the point on the build to replace all the gauges. Think I will stick with electrical gauges, to include an electrical speedo.
What is the consensus???
Shoot, Move, Communicate
Admit to Nothing, Deny Everything, Make Counter Accusations...
I Feel Like a Monkey F***ing a Football..
RetiredSERE is offline
post #2 of 16 Old 11-27-2009, 03:30 PM
CJ258
1974 CJ5
I'm looking at Stewart Warner gauges since I've used them for everything else in the past. For an oil press, gauge I'm going electric for the 1st time but going with a mechanical water temp. gauge.
This is the only vehicle I've ever had problems with as far as o.p. capillary lines breaking so I'm going electric. I want to run the ignition wire thru the press. sensor for auto cut off if oil press. drops too low since I have the oil sensor/ sending unit manifold.
CJ258 is offline
post #3 of 16 Old 11-30-2009, 07:37 PM
Bubba Ray
Go with mechanical Autometers. A little more work to install but well worth it.
Bubba Ray is offline
post #4 of 16 Old 12-02-2009, 07:12 AM
skclark
1982 CJ7
I'm considering the Glow Shift gauges after seeing them installed on a Truck U episode.
Performance Gauges & Gauge Pods GlowShift Gauges - Boost Wideband Air Fuel Gauges I like the elite 7 color. The tinted gauges go completely blank when you turn off the vehicle.
skclark is offline
post #5 of 16 Old 12-02-2009, 07:30 AM
IDK
Go mechanical, like the guy above said they will be a little more work but well worth it! I plan to do the same.
JpThang
IDK is offline
post #6 of 16 Old 12-02-2009, 07:32 AM
green cj 78
1978 CJ7
Auto-meter is the best... I have no preference for mechanical or electrical. I know mechanical are a little more accurate. I guess it depends on how savvy you are.
If auto meter doesn't do it for you, check out the Livorsi gauges, http://www.livorsi.com/
They make some pretty cool and custom gauges.
78 CJ7
5.3 Vortec, T18, Dana 20, AMC 20, Dana 30
97 XJ 2wd POS.
green cj 78 is offline
post #7 of 16 Old 12-02-2009, 08:45 AM
John Strenk
John Strenk's Avatar
1976 CJ5
What makes a good gauge is one that tells you when you are in trouble.
It should be visable without having to take your eyes off the road.
Visable under all light conditions.
Quick glance will tell you if you are in trouble and were.
No need to be accurate. Putting a high accuracy gauge into a CJ, when best viewed from the passenger seat, in a CJ is just silly. You have parralax error a minimum and trying to read an oil pressure gauge in a CJ is just as dangerous as texting while driving. If you want accuracy, go digital. If only they didn't make them so geeky.
I think YJ's have a great gauge layout and anyone interested in gauges probably should look into putting a YJ dash into thier CJ.
I love the pods DieselSmake makes but a little leary about what my passenger might hit against in case of an accident. If Diesel Smoke makes a mold of his pods and makes the corners smoother and built out of rust proof fiberglass that will crush under impact. He will have a winner.
I also like the ones that mount on the window pillars. Putting them under the dash is also silly. HUD's would be great but not enough angle on the window to make it work.
Mount your gauges so that all the needles point straight up when everything is running normal. Makes it easy to find the one pointing out the problem.
I realy like idiot lights or a klaxon that will sound off if you have a really serious problem.
John Strenk is offline
post #8 of 16 Old 12-02-2009, 09:22 AM
skclark
1982 CJ7
What I like about the glow shift is that you can set a threshold for some of thier guages and if it goes past the whole gage lights up red.
skclark is offline
post #9 of 16 Old 12-02-2009, 11:12 AM
Mike1084
1979 CJ7
I've always liked the white on black gauges that VDO sells. But the digital ones from Cyberdyne are pretty cool also.
http://www.usa.vdo.com/generator/www...tional_en.html
Cyberdyne Guages Home
Mike1084 is offline
post #10 of 16 Old 12-02-2009, 04:11 PM
horselaff
1978 CJ7
x2 here
horselaff is offline
post #11 of 16 Old 12-02-2009, 04:38 PM
brian613
1977 CJ5
i like the looks of the glow shifts
brian613 is offline
post #12 of 16 Old 12-02-2009, 05:47 PM
rodjr
1980 CJ7
i used electric vdo, fit perfect, factory connectors plugged in, even the factory light sockets snap right in. didnt cut a single wire. checked them against mech gauges and they were dead on.
rodjr is offline
post #13 of 16 Old 12-02-2009, 06:16 PM
jfwireless
1976 CJ7
The only two gauges that can be mechanical are the coolant temp and the oil pressure. Everything else has to be electrical. The speedometer of course can be either, but I just do not think of that as a gauge, but I guess it is.
The gas gauge, voltmeter or ammeter are going to be electric.
I know back when mechanical gauges were the best, I do not believe that anymore. Sensors and electrical gauges are better now than ever. All of the fuel injected engines today use electrical sensors to control the engine. I see no reason not to use the same electrical sensors to monitor them or monitor carbureted engines.
I like that feature.
Jim
jfwireless is offline
post #14 of 16 Old 12-02-2009, 09:03 PM
JKM3134
1983 CJ7
it's funny how some of these posts come up as you're searching for an answer to the same question.
i think ill be going with VDO electrical gauges. mechanicals are supposedly more accurate. one, i don't buy into this theory. and two, im not building a spaceship, pinpoint accuracy is not a concern. i also don't like routing fluids into the cab.
JKM3134 is offline
post #15 of 16 Old 12-02-2009, 09:18 PM
Dngrs1
1979 CJ7
Guages tell you what is going on under the hood. If you have to monitor the guages to keep track of whats going on all the time, you should spend more time doing PM's. I agree with John Strenk in that idiot lights work well to warn you of impending doom. They distract your attention from what you are supposed to be doing--driving---to warn you of failure. Then you can look at the guage to see where the failure is. Guages don't have to be super accurate; unless you are running a very tight, high dollar race setup. I think the best guages to tell you how your rig is running is your ears, nose, eyes and sense of touch.
Dngrs1 is offline
Temp gauge and fuel gauge quit Foulplay Jeep CJ Forum 11 11-09-2012 09:43 AM
I Got My Fuel Gauge Working by Putting Stock Oil Gauge Back In Pog Jeep CJ Forum 4 11-09-2011 12:01 PM
TEMP GAUGE, FUEL GAUGE, AND SPEEDO HELP PlEASE cgi2099 Jeep CJ Forum 8 11-03-2009 05:49 PM
Speedo, Fuel Gauge and Temp gauge not working KYCJ7 Jeep CJ Forum 1 07-07-2008 12:41 PM
Fuel gauge, temp gauge HEADSPACEXXX Jeep CJ Forum 5 04-03-2008 05:26 AM
