best front axle set for 35''tires with a 300Hp engine - Page 2 - JeepForum.com
post #16 of 21 Old 07-13-2011, 08:42 PM Thread Starter
petey156
well now i dont know what to do......
petey156 is offline
post #17 of 21 Old 07-14-2011, 07:21 AM
kickingprop
Originally Posted by Jim1611 View Post
I wish the Ox WAS available for the 9".
Keep in mind that some of the Hi-9 setups actually run a reverse cut 8.8 R&P in the 3rd member. AND That OX Lockers are available for an 8.8.
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #18 of 21 Old 07-14-2011, 07:48 AM
82JeepCJ7
1982 CJ7
Its not the gears that make the axle. The OX locker works on the principal that you replace the diff cover with the locking mechanism. The 9" does not have a diff cover. If your set on running a 9" in the front, get either a electric locker or ARB.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #19 of 21 Old 07-14-2011, 07:59 AM
79jeepincj7
1979 CJ7
Originally Posted by BillyPilgrim View Post
I used a 44 out of a mid 70's waggy. Had to outboard the front shackle hangers on the frame. The tires are 36 12.50's. I think it looks nice, mind you I do not have the front flares on so it looks wider. I am not sure how the axles would hold up to those tires with 300hp though. All depends on the skinny pedal I guess.
15x8 wheels or 15x10's?
Wheel - Wreck - Wrench - Repeat!
The VIN says its a 79 CJ
79jeepincj7 is offline
post #20 of 21 Old 07-15-2011, 11:42 PM
bbc
Just for reference -
mid 70's waggy 44, narrowed 4" ( not out boarded) with 15X10's and 35's
and a rear early Bronco 9"
both 58" WMS- WMS
bbc is offline
post #21 of 21 Old 07-17-2011, 05:29 PM
BillyPilgrim
1979 CJ7
15x8
A. I think they look good sucked in a little further
B. I like the extra beed pressure you get when aired down, although with beadlocks it doesn't really matter.
_____________________
79 CJ-7:
304
t18
d300 twin sticked
Locked Waggy 44's / 4:88
RE 4.5in outboarded suspension.
BillyPilgrim is offline
axle upgrade , dana 30 , dana 44
Axle u-bolts, 1 a different size for front axle? Cutlass327 Jeep CJ Forum 6 06-05-2011 04:50 PM
40" tires, What axle for a CJ-7 cj7Sswampers Jeep CJ Forum 17 08-29-2009 11:59 PM
Front Bumper May Rub Front Tires? Hybrid Jeep Jeep CJ Forum 6 04-15-2008 10:21 AM
Narrowtrack rear axle with 2" spacers match up with a widetrack front axle? Blthomas Jeep CJ Forum 1 05-11-2007 08:25 PM
Front differential cover replacement/Front Axle mattmosman Jeep CJ Forum 2 09-18-2006 06:54 AM
