Quantcast which is best dana 60 or 70 for narrowing. - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > which is best dana 60 or 70 for narrowing.
Old 05-12-2006, 10:00 AM   #1
jeepinarnie
I have found a dana 70 duelly axle from a 1978 ford camper for a cheap price,£60 about $113,as i live across the pond in UK,is it worth narrowing as I would have to narrow it to fit my cj-5 or should I save up for a rear dana 60 that i can get for £300 or $566,the dana 60 has 4.88 gears and comes from a j-20 truck,I would still need to narrow it but which one is the best.Can these axles be converted to run 5 on 5.5 with 15" wheels and disc brake conversion.Any advice is much appreciated.Thanks,BTW my jeep is a 1974 cj-5 narrow track with 360v8,t-18 trans,dana 20 transfercase,Waggy dana 44 narrowed to 57"wms to wms.Currently have dana 44 narrow track rear axle with 4.27 gears,but looking to beef it up so as not break it.
jeepinarnie is offline   Reply With Quote
Old 05-12-2006, 10:53 AM   #2
CJ51973
CJ51973's Avatar
If your narrowing I don't see why I would get the 60 over the cheaper 70. I don't think the housing is much bigger and it's stronger.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline   Reply With Quote
Old 05-13-2006, 10:35 PM   #3
401ton
I would use the 70. Most likely it is 64" wms to wms. I also wouldn't narrow it. If you need a 60 or 70 you most likely could benefit from having a wider track and a longer WB. Another way would be to leave it full 64" and run H2 Hummer wheels with more back spacing. That would make the axle seem more like 60" wms to wms.
AMC 401, Howell TBI, NP-435, Atlas 4.3, Rockcrusher 60, Shaved 14 bolt, 110" WB, Stazworks Double Beadlocks and 42's...
401ton is offline   Reply With Quote
Old 05-14-2006, 07:42 AM   #4
CJ51973
CJ51973's Avatar
It would be off the shelf axle replacement, like you'd ever break one
Old 05-14-2006, 02:10 PM   #5
John N
1981 CJ8
What size tires are you expecting to use? Either is a lot of axle, unless you're running 38"+ tires and planning on extending your wheelbase.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline   Reply With Quote
Old 05-14-2006, 03:47 PM   #6
jeepinarnie
I was looking to run 37"tyres,just want to do the jeep right and not worry about busting axles,have wasted a lot of time and money modifying over time and not getting it to how I'd like it to be.The only reason I said about narrowing the rear is to match the narrowed waggy front axle,which is 57" wms to wms.Have already flared arches to a total width of 72" but the tyres can not go past the arches as it will not pass vehicle licence tests over here.Open to possible solutions.
Old 05-14-2006, 05:57 PM   #7
John N
1981 CJ8
Dana 44s with stock axle shafts are considered 'safe' up to 35" tires. With alloy axle shafts you could run the 37s and be safe. You wouldn't loose the clearance under the diff, if that matters to you. The biggest issue with a 57" axle width in the front and 37" tires will be your turning radius, you'll be hitting your tires on the springs. You can adjust the stops out to prevent this, but that's when you loose even more turning radius.
I run a 57.5" narrowed Waggy front with 33s. I could get away with 35s, I think, but anything bigger would be in the springs. I run a Dana 44 out of a Scout II in the rear. It's 58" wide. These are fairly cheap over here.
John N
Old 05-15-2006, 11:11 AM   #8
18to80DDC
Built Not Bought
18to80DDC's Avatar
$566 is way too much for a D60 unless it comes with a locker, if you decide on a 60 shop around. I suggest going with the 70, it's stronger, and only marginaly larger in the diff casing, some of which can be shaved off for clearance.
2001 4.0L Wrangler Sport - 3.5" lift on 33's
1973 CJ5 360 - 4" lift on 35's
1982 CJ7 360 - 2" lift on 32's
1971 Series III E-type Jaguar V12 - no lift...
18to80DDC is offline   Reply With Quote
Glock Forum
