Best cruising RPM - JeepForum.com
post #1 of 11 Old 04-11-2014, 09:11 AM Thread Starter
Grims
1983 CJ7
Best cruising RPM
What is the best RPM to drive at in a 258? I have a T5, 35s, 4:88 gears, and a mild comp cam. 1,500 RPM is what feels "right" for driving around town. It doesn't feel like it's lugging, and has plenty of acceleration. But, that seems really low.
Is there a sweet spot RPM that's best to keep it at?
Grims is offline
post #2 of 11 Old 04-11-2014, 10:17 AM
Mike Romain
I get by far the best gas mileage running about 2300 rpm. With my 33's and 3.31 gears, that means 3rd around town and 4th on the highway. If I go to the taller gear, I lose about 5-10 mpg easy. Got way over 20 mpg with my stock except for no computer 258 and now get a nice 25 with my 4.0 HO, still with the stock 258 BBD and ignition on it. I do have an accel coil.
Mike
Mike Romain is offline
post #3 of 11 Old 04-11-2014, 11:12 AM Thread Starter
Grims
1983 CJ7
On a 600 mile trip at highway speeds doing about 70 at probably 3k RPM (didnt have a gauge then) I got about 14.5 miles to the gallon. Which I think is pretty good being my timing was far too retarded and my carb needed a rebuild. But, I wonder if 1,500 RPM is fine at in city speeds being my gears are so low.
Grims is offline
post #4 of 11 Old 04-11-2014, 01:30 PM
Mike Romain
Double post
Mike
post #5 of 11 Old 04-11-2014, 01:31 PM
Mike Romain
I find anything under 2000 drinks gas. I need too much pedal to adjust for small changes in wind or hills. Try it for a measured distance and do a milage check. That is what I do.
Mike
post #6 of 11 Old 04-11-2014, 01:32 PM
LumpyGrits
2400-2600rpm seams to be the 4.2's 'sweet spot'.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #7 of 11 Old 04-11-2014, 01:40 PM
Tigerjeep79
1979 CJ7
65 mph gets me 2500 RPM. It seems about right, that's with 32" tires and 3:50 gears. I'm very happy with that setup.
Tigerjeep79 is offline
post #8 of 11 Old 04-11-2014, 02:02 PM Thread Starter
Grims
1983 CJ7
I'll give it a shot. like I said at 1,500 RPM I have lots of power for anything I come in contact with (hills, trees, cars, small children) But, I'll give 2k a try. just feels like I'm in too high of a gear in that area. Letting off the gas gear brakes it.
Grims is offline
post #9 of 11 Old 04-11-2014, 05:35 PM
LumpyGrits
At 1500, your lug'n it!
LG
post #10 of 11 Old 04-11-2014, 07:59 PM
243
1978 FSJ Cherokee
Peak torque appears to be 1800-2000 depending on the year model, that is where I would want to be.
I am not even close (on highway) with 32" KM2's and 3.54s:
2050 @ 55
2800 @ 75
With an overdrive I would be better off:
1550 @ 55
2104 @ 75
Dave's 78 Build
243 is online now
post #11 of 11 Old 04-11-2014, 08:04 PM
LumpyGrits
2050 @ 55
2800 @ 75
1550 @ 55
2104 @ 75
You don't want/need an OD with 3:54s!
Trust me-You want to keep the R's above 2200rpm.
I run 4:88 w/33s and a T5. it will run sweet all day at 2500-2600 rpm.
LG
