Best CJ7 Rear Axle Swap - JeepForum.com
post #1 of 24 Old 10-20-2009, 09:00 PM Thread Starter
4by4junkie
1981 CJ7
Hi,
After doing research on rear disk break conversion for my CJ7 rear drums, I came to the conclusion that a axle swap was more economical.
What is the best axle to get? I want disk breaks, a stronger axle then the amc 20 and good fit.
Anyone have any suggestions? Vehicle? Year?
Thanks
4by4junkie is offline
post #2 of 24 Old 10-20-2009, 09:37 PM
Double AA
1981 CJ7
The Ford 8.8 is affordable, available with disc brakes and the strength is about on par with a D44. Keep in mind, any axle swap will cost a lot more than brakes alone when you figure in re gearing. You'll also have to weld spring mounts on the new axle.
Double AA is offline
post #3 of 24 Old 10-20-2009, 10:15 PM
jeeperman19
1984 CJ8
An 8.8 may be similar in strength to a dana 44......but it has c clips if you ever break a shaft your wheel can fall off
I'd say a 44 out of a cj or a ford9"
http://i95.photobucket.com/albums/l131/jeeperman19/carcrush-1.jpg
http://i95.photobucket.com/albums/l131/jeeperman19/rubiconmemorial.jpg
jeeperman19 is offline
post #4 of 24 Old 10-20-2009, 10:53 PM
Double AA
1981 CJ7
Both the 44 and 9" would be better choices but not as "economical" as an 8.8, which can be pick up for ~ $250.
post #5 of 24 Old 10-20-2009, 11:21 PM
jeeperman19
1984 CJ8
Originally Posted by 4by4junkie View Post
Hi,
Thanks
What is your definition of economy........what is your budget for a new rear?
post #6 of 24 Old 10-20-2009, 11:37 PM
smoothop
1978 CJ7
A Dana 60 is the only axle worth upgrading to if you are going to ditch your AMC 20....Dana 44 is not worth the swap....You could do Suzuki disc brakes with your AMC 20. An AMC 20 can be made to be as strong as a Dana 44 with some economical mods. You have to decide if you want to throw money into an almost worthless AMC 20 (resale wise) or start with a better base that will allow you to upgrade as your Jeep progresses. Personally I would go with a Dana 60 of some sort and build from there, as it will allow you more options and stronger upgrades in the future.
smoothop is offline
post #7 of 24 Old 10-20-2009, 11:45 PM
Tortured
If you are good at fabrication I would suggest looking in junk yards for Rubicon axels front and rear. I'm sure you can pick them up fairly cheap and they come standard with lockers. You will need to move the pumpkin on the front axel to the drivers side, that's where the fabrication part comes in. If I was building another jeep that is what I would do.
Tortured is offline
post #8 of 24 Old 10-21-2009, 07:39 AM
kickingprop
the c-clip issue with the 8.8 isnt that big of a deal if you are going with a disc brake 8.8....in the event of c-clip breakage you still have the caliper and rotor to hold the axle in. The 8.8 is slightly stronger than the Dana 44, they are EVERYWHERE, have good aftermarket support and come in a variety of gear ratios, often with a LSD!
But I think its more economical to just beef up the AMC20 as most any axle swap you do will be wider than your current axles and cause a noticeable offset between the front and rear axle widths.
Disc brake conversion, one piece shafts, and welding/trussing will make your AMC20 stronger than any Dana 44 (as well as c-clip 8.8's) and they will take a lot of beating.
I'd go that route
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #9 of 24 Old 10-21-2009, 08:14 AM
CSP
So has anyone considered that the 8.8 is about 8" wider than the AMC 20 that the '81 CJ in question has in it?
CSP is offline
post #10 of 24 Old 10-21-2009, 10:02 AM
kickingprop
I mentioned the width in the previous post...and yes the width difference is going to be VERY noticeable between a NT D30 and an 8.8. Thats why I recommended beeffing up the AMC20
1985 CJ7 Project
post #11 of 24 Old 10-21-2009, 10:41 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
How about that the 8.8 application that would even be an acceptable width for a CJ (the Explorer) is the wrong bolt pattern?
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #12 of 24 Old 10-21-2009, 11:02 AM Thread Starter
4by4junkie
1981 CJ7
Thanks for the great responses,
Sounds like upgrading the AMC 20 is the most economical way to go. I Definitely don't want wider axles.
Anyone have a link or some information on DB conversions or beefing up the axle upgrades for my AMC 20?
post #13 of 24 Old 10-21-2009, 11:13 AM
kickingprop
do a search on here...there are quite a few writeups on the web using 300Z rotors and suzuki calipers or something like that...
Keep in mind that when you do the upgrade to rear discs you'll need a new proportioning valve and possibly new Booster/MC setup as well. once again...quite a few threads on this already
I recommend moser 1pc axles for that part of the upgrade.
the moderator BESRK also makes Truss kits for the AMC20 that are pretty beefy as well. I know quite a few people on here have them.
1985 CJ7 Project
post #14 of 24 Old 10-21-2009, 12:50 PM
Cherokeester
Cherokeester's Avatar
1980 CJ7
"moving the pumpkin" is well beyond the average fabricator. Plus rubi axles are setup for coil springs not leaf springs. Also, you need the pumpkin on the passenger side, not drivers. And lastly they are not found exactly cheap anywhere I have seen. Not the way to go if you ask me.
1980 CJ-7 with a AMC 401, RE 4.5" Lift, 4-1 Dana 300, Holley TBI Projection, 35" Goodyear MTR's
2010 Rubicon Unlimited
1997 TJ with various enhancements
Cherokeester is offline
post #15 of 24 Old 10-21-2009, 06:11 PM
CJ7Rubicon
CJ7Rubicon's Avatar
85 cj7 with and 8.8 out of an explorer with 5x4.5 to 5 on 5.5 adapters and 15x10 wheels with 13.50 wide tires,just for reference.Its wide.
85 CJ7,Clifford equipped 258,TBI,RE4.5,35" Claws,Aussie lockers,8.8 rear.
Blue Jeep Club Member #134
CJ7Rubicon is offline
outriggers rear axle swap crazyinmaine Jeep CJ Forum 4 12-07-2009 06:08 AM
Information on Dana60 front GM14bolt rear axle swap apreciated xewpas Jeep CJ Forum 1 11-12-2008 06:00 AM
Narrowtrack rear axle with 2" spacers match up with a widetrack front axle? Blthomas Jeep CJ Forum 1 05-11-2007 08:25 PM
Rear Axle Swap Workethic Jeep CJ Forum 8 01-01-2006 07:01 PM
