Best Axle out there??? (Ford 9"/ Dana 44/AMC 20/OTHER) - JeepForum.com
post #1 of 5 Old 03-18-2003, 12:34 PM Thread Starter
jeepcj7
Best Axle out there??? (Ford 9"/ Dana 44/AMC 20/OTHER) What is the best axle that they have that when slightly modified would fit a CJ7 and be successful? Which is strongest? Which is cheapest? Which in most practical and economical? What do ya'll run?? THANX in advance.
jeepcj7 is offline
post #2 of 5 Old 03-18-2003, 12:41 PM
Chad Churchill
I have a modle AMC 20 with 4.56/full/and Detroit..
I would of gone with a 44 but it came with a AMC 20, so that is what I have.. if you go with a FORD 9'' or a Danna 60 you are ganna lose ground clerince. lol unless you have some 38'' BFG lol
Good luck with your axle Hunt..
'84 AMC CJ7.. 4" rancho 9000 9 way+ 1'' Tow Shacks+ 1'' BD, 9,000 warn winch, 33''BFG mudd, T176,Danna 300 with Twin shifter,44 front,20rear,4.56 with locks, 258beefed, w. fuel injected!,MSD,new white paint, all new intr., and two onbord airs. Member of TMTC, member of offroadministry, and go 4x4ing all over the U.S.A.!!!
'98 TJ... 4" Teraflex with rancho 9000 9 ways. 33" all's with solid Axles and 4.56 with locks.. Hunter green and ready to go..
Chad Churchill is offline
post #3 of 5 Old 03-18-2003, 05:55 PM
pontiac58
1980 CJ7
It really depends on your setup, if you run 31's stay stock, if you run 33's you can get away with stock and a little beefing. Get to 35's and its time to upgrade or majorly beef stock stuff. And what works for one guy wont work for you. You really have to do your homework to figure out what would be best for you. I know guys that run a stock d30, with locker and 35 swampers and dont break a thing. Me i couldnt get a ujoint in my 30 with 33 swampers and no locker. So its really hard to say what is the best for you. Only you can decide that.
pontiac58 is offline
post #4 of 5 Old 03-18-2003, 06:02 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
I run am AMC 20 w/4.56's, and Warn FF kit behind a beefy 360 with no problems - turning 35's also. A D/44 is no upgrade IMO. The 9" is a great axle but is only 1/8" larger in ring gear size than the 20.
If my AMC 20 gives me problems I'll put a D/60 in....
Steve
OldJeepguy is offline
post #5 of 5 Old 03-21-2003, 11:54 PM
rok_toy
rok_toy's Avatar
Well, the D44 has stronger tubing than the amc 20, the 9" is a great axle, but the pinion is very low( hangs up on rocks). You can beef the amc 20, but you'll still have the weak tubing.
The best upgrade, in my eyes, is the 9". If you have some money to throw around, you can get a high pinion center section!! Then you'll be set.
1986 CJ-7, 258/T5/Dana300, Dana 44's, 4.89's, ARB's, SOA, Warn8K, high-steer, 37" MTR's, onboard air( york style)...more to come!!
rok_toy is offline
Ford Dana 60 rearend 77cj5BEAST Jeep CJ Forum 9 02-23-2007 02:19 PM
Ford T-18 to a Dana 30 ncdeerejeep Jeep CJ Forum 8 11-28-2006 07:22 PM
80 Cj what front axle to match ford 9" rear? silver_2000_TJ Jeep CJ Forum 3 03-31-2005 05:42 PM
where to find the right ford 9 in and dana 44 axles for my cj7 maestro Jeep CJ Forum 5 03-16-2003 04:31 PM
