Which Is The Best Aluminum Valve Cover - JeepForum.com
post #1 of 5 Old 09-10-2007, 09:18 PM Thread Starter
dhood
Hi guys,
I am going to buy an aluminum valve cover and want to buy one where I have to do the least amount of tapping or none at all. What do you suggest? Thanks
Dave
dhood is offline
post #2 of 5 Old 09-10-2007, 10:26 PM
Bard
I don't think there is a best. I had a clifford and some no name and both worked great. As for drilling and tapping, it is just going to happen, so grin and bear it
ideally prep work is key, I clean it all down with brake kleen, I RVT'd my gasket to the cover, let it dry for a day after I measured and tapped the needed holes, and then RVT'd the gasket and set it, torqued it down and it hasn't leaked yet, knock on wood.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #3 of 5 Old 09-11-2007, 08:26 AM
JoonHoss
2011 JK Wrangler
double what Bard said!
it's not so much the cover, (though you do want a decent one) the drilling/tapping is all due to the engine block.
I went with this one, which I think is GREAT deal
http://www.baseline4x4.com/proddetai...rod=17401%2E09
and if you haven't read up on changing one, the Cliff's notes are:
slightly drill out the holes in the cover for a little wiggle room, get a bottoming tap, use whatever bolts will work (use washers if they are too long, don't overtighten), you may want to put a stud in the very back hole, and do like Bard said with the gasket, and you shoud be good to go!
Good luck
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #4 of 5 Old 09-11-2007, 08:24 PM
Houdini
Check this one out.
[URL="http://www.yourcovers.com/vc_8656.shtml"]
I've bought there Trans pan and difff cover for my Dodge. Excellent quality. I'm thinking of getting the valve cover and selling my current cast cover.
Houdini is offline
post #5 of 5 Old 09-12-2007, 12:36 PM
SuB8HaVeN
I got one off eBay and it worked OK. No matter what brand, you're going to have to tap the mounting holes on the driver side of the head. That's the hardest part...
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
Which Aluminum Valve Cover? Bwick84 Jeep CJ Forum 16 01-01-2009 03:40 PM
Aluminum valve cover on the 258 mmerlina Jeep CJ Forum 13 02-09-2008 06:24 AM
Oil cap for aluminum valve cover mmerlina Jeep CJ Forum 6 10-21-2007 12:18 PM
Aluminum Valve Cover oil cap twmattox Jeep CJ Forum 7 10-16-2007 09:32 PM
aluminum valve cover oil cap TexasCJ7 Jeep CJ Forum 3 04-15-2007 02:22 PM
