Besrk bumper pictures - JeepForum.com
post #1 of 9 Old 12-30-2013, 06:28 PM Thread Starter
jcalhoon84
1980 CJ5
Is anyone able to post some pictures of their Besrk bumpers specifically I'm looking for pictures of how your hi-lift jack is mounted with his bracket.
The one set of images I found and tried to duplicate has the base of the jack hitting my passenger side brake light housing.
Thanks!
jcalhoon84 is offline
post #2 of 9 Old 12-30-2013, 07:18 PM
station10fd
I've got one shot here near the end of the thread. You Might be able to zoom in enough to get what you need. If not. I'll take some closer pictures for you.
http://www.jeepforum.com/forum/f8/wi...-work-1438911/
Mike T.
station10fd is offline
post #3 of 9 Old 12-30-2013, 07:30 PM
station10fd
I just realized I'm running LED lights, maybe that's why I don't have a problem?
post #4 of 9 Old 12-30-2013, 07:35 PM Thread Starter
jcalhoon84
1980 CJ5
Thanks, yeah I'm running the stock lights. I'm close to the shop where he built it, if I don't figure it out maybe Ill swing by the shop. Currently I have it mounted with the base up. Do you think there is anything wrong with doing it that way?
post #5 of 9 Old 12-31-2013, 07:52 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Josh.. I mount mine "base up". I just slip a bolt thru the hole closest to the ratchet.. to make sure the jacking mechanism doesn't slide down.
BESRK is offline
post #6 of 9 Old 12-31-2013, 08:00 AM Thread Starter
jcalhoon84
1980 CJ5
Thanks, I was looking at the pictures you had posted in your thread and couldn't make it work.
post #7 of 9 Old 12-31-2013, 03:24 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Some of those were my old mount. It was offset more to scoot the jack up higher. The newer mounts were symmetrical to allow them to be mounted on either side of the Jeep.
BESRK is offline
post #8 of 9 Old 12-31-2013, 03:29 PM Thread Starter
jcalhoon84
1980 CJ5
Thanks again! I'll post some pictures when I take the jeep out again.
post #9 of 9 Old 01-01-2014, 02:15 PM Thread Starter
jcalhoon84
1980 CJ5
Mounted and ready for use
