bent front drive saft. - Page 2 - JeepForum.com
post #16 of 24 Old 10-21-2013, 06:37 PM
WSS
WSS's Avatar
1972 CJ5
When you push up on the slip yoke, is there more than 1/2" deflection/free play?
My stock shaft wore out here and also, when the PO did the lift, he did not re-do the shaft and it was "slipped out" more than stock. I put on a tattons shaft that was mucho bigger and thicker for fairly cheap ($150)
http://www.ebay.com/itm/NEW-1310-JEE...bc0712&vxp=mtr
WSS is offline
post #17 of 24 Old 10-21-2013, 08:31 PM Thread Starter
zeronight
1982 CJ7
ooh i like that. looks much thicker.
zeronight is offline
post #18 of 24 Old 10-21-2013, 08:36 PM
Spieg8
1984 CJ8
That looks pretty stout compared to stock.
Any clearance issues with the larger diameter shaft? Did you go with a long travel slip joint or standard?
Spieg8 is offline
post #19 of 24 Old 10-21-2013, 08:44 PM
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by zeronight
i never hit over 2500rpm and i was on pavement.
If the shaft is bent as a result of this, consider yourself lucky, it could have been much worse.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #20 of 24 Old 10-21-2013, 10:25 PM
WSS
WSS's Avatar
1972 CJ5
Ya guys, definitely stronger, it gives a sense of peace for sure, I went with the long slip, it was what was offered, 7" I believe.
No clearance issues that I have noticed yet, I gave her a work put this weekend!LOL
WSS is offline
post #21 of 24 Old 10-22-2013, 09:50 PM Thread Starter
zeronight
1982 CJ7
i think im buying one Friday.
post #22 of 24 Old 10-22-2013, 10:43 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
I agree w/lucdog. You got off cheap. Could you imagine if that sucker let loose while pulling? I'm shuddering just thinking about 1/2 the shaft going through the oil pan, a chunk going into the fan...or some such catastrophe. Ya may wanna pull the front diff cover and do a little inspection. You were gonna service it w/new fluid anyway, right?
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #23 of 24 Old 10-23-2013, 06:18 AM
yahwhy
1982 CJ7
i had a strap around the bush and i had the winch cable hooked to it. i tried to use just the winch but even with the breaks on it was pulling the jeep to it so i put it in 4low and went forward for some slack and then i backed up. 3 or 4 pulls pulled the bush out. it wasent that difficult and i had no idea that this could hurt the jeep. i feel this is a weak point that i didn't know about. according to quadratech the length i need is 31.75 collapsed.
Using your winch as anchor point for pulling is also a bad thing, its hard on the brake of winch.
yahwhy is offline
post #24 of 24 Old 11-29-2013, 08:24 AM Thread Starter
zeronight
1982 CJ7
just installed it and testing it out tomorrow. thanks
