Bent/Curved Drag Link - JeepForum.com
post #1 of 15 Old 07-19-2009, 06:26 PM Thread Starter
ken78cj5
1978 CJ5
Anyone out there know where to get a curved drag link? I was hoping to stay away from a dropped pitman arm.
I used a MORE shackle reversal and am making my own tie rod, but need info for a drag link.
Ken
ken78cj5 is offline
post #2 of 15 Old 07-19-2009, 08:43 PM
gojeepin
1983 CJ7
Are you using the curved drag link to clear suspension parts? It won't do a thing for bump steer.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #3 of 15 Old 07-20-2009, 06:13 AM Thread Starter
ken78cj5
1978 CJ5
I dont think I am going to have interferance issues. I am still putting the front end together. I am trying to avoid using a dropped pitman arm.
ken78cj5 is offline
post #4 of 15 Old 07-20-2009, 06:27 AM
keith460
Jeep. There's Only One
keith460's Avatar
Do the tie rod flip instead and you won't have to use a curved tie rod or dropped pitman arm.
1984 CJ-7 Renegade
keith460 is offline
post #5 of 15 Old 07-20-2009, 07:58 AM
CJ Chet
Why didn't you flip your draglink at the same time?
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #6 of 15 Old 07-20-2009, 10:26 AM Thread Starter
ken78cj5
1978 CJ5
Drag link
I am going to flip the tie rod and drag link. I do not want to use a drop pitman arm. That is why I am looking for a bent/curved drag link.
ken78cj5 is offline
post #7 of 15 Old 07-20-2009, 06:33 PM
gojeepin
1983 CJ7
The reason to use a drop pitman arm is to correct bump steer. A tie rod flip will do the same.
A bent/curved drag link will not correct bump steer. It helps you clear suspension (or other) components.
gojeepin is offline
post #8 of 15 Old 07-20-2009, 08:02 PM
No_Bs
1977 CJ5
What is so bad about a dropped pitman?
1977 Cj5, 258, T-18, 2.46:1 Dana 20, 2.5" BDS lift, OBA, 38.5's. Chevy 60 frt, 14b Rear, Full hydro, 102"wb, full DOM cage.
No_Bs is offline
post #9 of 15 Old 07-20-2009, 08:24 PM
gojeepin
1983 CJ7
Most of them are short and don't turn your wheels as far. I had one and it took a greater distance to turn around but you know that already...
gojeepin is offline
post #10 of 15 Old 07-20-2009, 09:24 PM
jeepmaster03
1982 CJ7
No offense to anyone but dude, curved and bent drag links are for hacks. I don't care what anyone says, or how many "Z" braced drag links you see on what ever ride, it's not safe. Do the flip, the dropped pitman arm, or a hy-steer conversion, or don't do anything at all.
jeepmaster03 is offline
post #11 of 15 Old 07-20-2009, 09:38 PM
HighFive
1981 CJ5
When you flip the tie rod do you reem it out like factory or just drill it out?
[/color]
Let's go Flyer's!!!!!!
HighFive is offline
post #12 of 15 Old 07-20-2009, 11:31 PM
jeepmaster03
1982 CJ7
You ream it out to match the taper of the TRE on the end of the drag link. I opted for the Hy-steer configuration, so I have not personally done a flip. It seems to me that there would need to be some kind of insert in this setup. But, I'm not sure. Think about it...The hole from the bottom is already the same diamiter as the OD of the base of the TRE pin. The reamer takes the narrow part of the hole on top and reams it out to the same OD of the base of the TRE pin. Theoretically the hole ends up the shape of an hour glass, wide at both ends and the narrowest part in between the two. The insert would go in from the bottom and finish the taper...Anyone follow my train of thought? Seems simple but I don't have a referance for the part # on the inserts...or I could be dead wrong???
post #13 of 15 Old 07-21-2009, 06:30 AM
BillyPilgrim
1979 CJ7
You are not dead wrong, here is a thread on the different ways of doing this and the parts and websites associated.
http://www.jeepforum.com/forum/f8/tie-rod-flip-kits-one-vs-other-819739/
_____________________
79 CJ-7:
304
t18
d300 twin sticked
Locked Waggy 44's / 4:88
RE 4.5in outboarded suspension.
BillyPilgrim is offline
post #14 of 15 Old 07-21-2009, 06:29 PM Thread Starter
ken78cj5
1978 CJ5
All,
Thanks for all the replies. I am actually chaging the spindles to a D44 and using a high steer conversion. That should solve all the problems.
ken78cj5 is offline
post #15 of 15 Old 07-21-2009, 07:56 PM
jeepmaster03
1982 CJ7
FYI, the dana 30 spindles will bolt right up to the flat top knuckles (D44 & GM 10 bolt). If you keep the D30 spindles you can use the D30 hubs and bearings as well. You will need to use the disc brake mounting plate and calipers from 76-81 CJ.
Bent Drag Link... poppatello Jeep CJ Forum 8 11-29-2009 12:30 PM
Big Daddy Drag Link sgil77 Jeep CJ Forum 1 11-17-2009 05:38 PM
Drag Link Kit my73CJ Jeep CJ Forum 2 05-27-2009 08:26 PM
Bent drag link golden eagle Jeep CJ Forum 1 06-18-2006 09:51 PM
Tie rod and drag link John C Jeep CJ Forum 2 09-08-2004 03:48 PM
