Belt squeal - JeepForum.com
post #1 of 6 Old 03-04-2013, 11:56 AM Thread Starter
CJ7KAHUNA
Belt squeal
I have new belts on my CJ7. I havent been driving it much but now that I am starting to the belts will squeal from time to time right after start up on high speed idle. They usuallyi stop after a short distance but its annoying and embarrassing.
What causes this and whats the best remedy? Seems I remember a friend putting bar soap on the underside of his back in highschool. Not sure how smart that is
CJ7KAHUNA is offline
post #2 of 6 Old 03-04-2013, 11:59 AM
sarfu
1974 CJ5
Belt could be loose? I had the same problem, adjusted the alternator and problem went away, you can also buy a belt conditioner from the parts store.
sarfu is offline
post #3 of 6 Old 03-04-2013, 12:00 PM Thread Starter
CJ7KAHUNA
Not too loose - maybe too tight?? I'll look into this conditioner you speak of. thanks.
post #4 of 6 Old 03-04-2013, 01:18 PM
sanmiam
sanmiam's Avatar
1983 CJ7
Too tight will also cause squealing and could potentially damage bearing in your alt/PS pump. You want about a 1/2" of deflection on the belts when you press down with 1 finger on their longest unsupported run (ontop).
Building a Jeep is like playing golf, every now and then you get a good shot that makes you believe, hey I can do this!
sanmiam is offline
post #5 of 6 Old 03-04-2013, 01:28 PM
82JeepCJ7
1982 CJ7
If the belts have glazed over, they need to be replaced. Check the pulleys to make sure they are not coated in something.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #6 of 6 Old 03-04-2013, 02:08 PM
noahlon
1968 CJ5
Get a bar of canning wax at the grocery store, or a candle, and while the engine is running, CAREFULLY apply the wax on the inside of the belts. Works like a charm!!
noahlon is offline
