Beginner questions...general guidance needed please - JeepForum.com
post #1 of 8 Old 03-19-2012, 09:02 AM Thread Starter
smarth
1980 CJ7
Hello!
I got a few general questions, that should be fairly easy to answer by more experienced CJer's, since I am still learning here eac hday about my first Jeep.
I pretty much threw all not needed cables and wires out from under the dash. Not sure what the previous owners all added to my CJ, but there was a bunch of stuff down there. Accidently, I cut the water temp gauge. Can I just reconnect the wire? How?
Also, I got some oily fluid gathering on the passengers side in the foot area on the floor. Cannot tell where it comes from. Sloooowly drips from the dash. Any ideas?
In the 4th gear my clutch seems to disengage once I push the pedal to the metall...not in any other gear...what can this be?
Last one: I was trying to be cheap and bought a 6 cyl. radiator for my Jeep instead of the matching 4 cyl. one. I thought it was a great idea until I realized the connectors are on the wrong side. The lower hose is the problem now since I need to connect 2 hoses to be long enough. Any idea where to buy a truly long flexible one?
Thank you so much!!!!
Sebastian
smarth is offline
post #2 of 8 Old 03-19-2012, 09:10 AM
BOISERUNNER
1979 CJ7
Oil could be from a cut or cracked oil pressure guage line. What peddel is to the metal clutch or throttle?
BOISERUNNER is offline
post #3 of 8 Old 03-19-2012, 09:12 AM
WindKnot
1977 CJ7
Passenger side under the dash? If it smells sweet it's probably coolant and you have a leaking heater core.
Can't help with the others other than I'd worry about that bottom hose hitting the fan being so long.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #4 of 8 Old 03-19-2012, 09:16 AM Thread Starter
smarth
1980 CJ7
will check. i might certainly have cut that too. thanks!
smarth is offline
post #5 of 8 Old 03-19-2012, 09:17 AM Thread Starter
smarth
1980 CJ7
you're right. the fan is close to the hose...stupid mistake of mine.
it is oil so it seems. i probably cut the oil pressure line. another great move...well, that keeps me busy...
smarth is offline
post #6 of 8 Old 03-19-2012, 09:20 AM
WindKnot
1977 CJ7
Yep. If your oil pressure gauge and sender are not electric, that could do it. Bummer.
WindKnot is offline
post #7 of 8 Old 03-19-2012, 09:47 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Congrats on your first Jeep.
Originally Posted by smarth View Post
.. Accidently, I cut the water temp gauge. Can I just reconnect the wire? How?
If it is a mechanical temp gauge, then the cut line cannot be repaired because it's a very thin copper tube with alcohol in it. You will have to install a whole new gauge and wire assembly.
If it's an electrical gauge, then yes, just repair the cut in the wire. To do that, I would strip off about 3/8" of the insulation from each end, solder them together, and cover ther repair with heat shrink tube. Be sure to slide the heat shrink tube on to the wire before you make the solder repair.
Ditto what the other replies said. Use a white paper towel to soak up the fluid so you can see what color it is. If it's greenish, then it's coolant and the heater core is leaking. If it's brown or black, it's motor oil and the line to the oil pressure gauge is leaking. Those lines get brittle and will easily crack. You can replace the line with a cheap new one.
If you can't tell what the fluid is by the color (sometimes coolant will be dark if it's old), give it the smell test. Coolant will have a sweet smell. Oil smells smoky and oily. If you still can't tell, soak it up and put the paper towel in a cup of clean water. If the stuff floats to the surface, it's oil (or has oil in it).
Do the right thing and just get the correct radiator. The next owner of your Jeep will appreciate it.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #8 of 8 Old 03-19-2012, 11:29 AM Thread Starter
smarth
1980 CJ7
thanks!
thanks for all your responses! helped a lot!
smarth is offline
gauge , leak , radiator hose
General Build Questions Moab_cj5 Jeep CJ Forum 13 11-11-2011 09:29 PM
Some general rebuild questions MightyLampshade Jeep CJ Forum 11 04-15-2010 10:41 AM
General CJ-7 questions Squish Jeep CJ Forum 8 10-22-2008 10:06 PM
CJ Rebuild Ramblings / ?'s Guidance Needed cshutchinson Jeep CJ Forum 6 12-11-2006 10:47 AM
A few general questions on my CJ7 Captain Jeremy Jeep CJ Forum 2 05-01-2004 11:54 AM
