Been reading the good book of JeepHammer! - Page 6 - JeepForum.com
 1Likes
post #76 of 147 Old 01-31-2011, 06:48 PM
mvigo
mvigo's Avatar
Originally Posted by ppd1108 View Post
I had a quick question about the gauge of wire required to go from the battery negative terminal to the brass bolt or BUSS. I assume its a 10 gauge wire or something along those lines. When the 4 gauge wire is crimped into the battery terminal connector, does the 10 gauge wire get crimped into it as well or is there a special connector I have to use?
I crimped and soldered my 2 wires together...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #77 of 147 Old 10-16-2011, 11:59 AM
KJNewbs
1983 CJ7
Hoping this thread still gets a read from time to time....
I'm finally getting to this project and have a question. Has anyone used (or see a problem with using) one of the 4 threaded inserts that are already in place on the passenger side fender as the grounding bolt location? I'm not sure what was bolted in place with the factory set up, but these are not used in mine and seem like a good place.
I thought I'd get a 2.5" brass bolt, that matches this size/thread count, and thread it in from the underside, throw on a washer and bolt on the top and ground away.....
Thoughts?
-KJ Newbs / Jersey
1983 lime green CJ7 - 258 with DUI & Weber, Crane cam, 2" lift, MTs w/ BFGs
2010 2-Door, 6-Speed Black JK Sahara - Teraflex 3" Coil Lift with Front Lower and Rear Upper Flex Arms - Bilstein 5100 Shocks -JKS Front Adjustable Track Bar - Teraflex Front Knuckle Gussets - Rock Hard Oil Pan/Engine Skid - Rock Hard Transfer case skid - Rock Hard Evap relocation Kit - Poison Spyder Rocker Knockers - MBRP off-road exhaust - AEV Pintler Wheels - GoodYear MTR/K 35x12.5x17 - Detroit Track Loc Carrier up Front - Yukon 4.88 Gears - Cobra 75 CB with Cool Tech bracket - Die-Tech mirror relocation brackets
KJNewbs is offline
post #78 of 147 Old 10-16-2011, 02:14 PM
bentring
1976 CJ5
Man, threads like this are why I keep having to bring the laptop cord outside for reading sessions. Great info in here!
bentring is offline
post #79 of 147 Old 08-04-2012, 04:53 PM
lukenicwalker
1982 CJ7
Incredible information. I am new to Jeeping, especially electrical work, and I am learning so much! Thanks to everyone (especially JH) for sharing all your knowledge and experiences!!!!
ldw
lukenicwalker is offline
post #80 of 147 Old 02-08-2013, 07:29 AM
turbogus
1978 CJ5
I agree that this ought to be a sticky, not only here but in ALL automotive/marine forums. Thanks so much for your insights JeepHammer!
Question, for smaller gauge wiring (stereo, amps, lights, etc) that welding wire is not gauged down to AWG is the 'go to' over SAE nicht var?
Pardon my ignorance, over the years I've been using whatever wiring was at hand, and while failures have been at a minimum, I feel that when I'm wiring up new gear or replacing/upgrading, I'd like to stick with the idiom in the original posts.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #81 of 147 Old 02-18-2013, 11:54 AM
turbogus
1978 CJ5
Hi JeepHammer and all,
I'm sorry to bother your with this and I'm sure you're getting innundated with questions but I hope you'll have time for this one. From the thread Basic Wiring 101;
THIS IS A 'FACTORY CRIMP' Tool, A 'Cheap' version from 'Radio Shack', and it will reproduce the factor crimps on connectors with 'Tails' that dig into both the wire and the insulation.
It's REALLY handy for a guy building a harness from scratch that DOES NOT want those big, ugly, failure prone crimps from the color coded insulated terminals everyone is so fond of...
These Jaws provide that 'Factory Crimp' that we are looking for"
Despite working in a college town, this damm place is a consumer desert when it comes to things like this. I'm doing a great deal of wiring and I like the idea of 'factory style crimps' but getting the tool locally is a real challenge. I found one made by Titan (made in Taiwan) that seems a little cheesy, stopped by the Rat Shack and, being more of a phone store than the former electrical/electronics store (that was managed by a veteran Navy electrician) and the staff had no idea of what I was talking about. Would anyone have a Radio Shack pn. for those crimpers? Thanks a heap and a lift of the lynch lid.
Gus
turbogus is offline
post #82 of 147 Old 02-18-2013, 04:30 PM
turbogus
1978 CJ5
Well nutz, was hoping for anyone's response by now as there's an EBay auction for the last one of these and I think the jaws are what I'm after, I hope. Had to trip the trgger on this 'cause they were going fast and this was the en of the line. No one in this consumer desert even remotely had one even similar to this one.
turbogus is offline
post #83 of 147 Old 11-24-2013, 05:55 PM
JeepHammer
Running On Empty...
1973 CJ5
Marine, especially salt water marine, is an ENTIRELY DIFFERENT ANIMAL that automotive wiring...
With marine wiring, you have to consider the ever present danger of fuel vapors (Fire/Explosions) and the corrosive effects of salt water.
Where I closer to the ocean, and building a Jeep, The rules would be RADICALLY DIFFERENT!
UNCOATED COPPER IN SALT WATER IS DEAD IN HOURS. NO EXCEPTIONS.
Just salt air can ruin a perfectly good land locked wiring job in days.
COATED or 'TINNED' wire is MANDATORY,
So are weather proof terminals, drip loops, explosion proof junction boxes, ect.
My boat days were frustrating to say the least, since I *Thought* I had a grip on wiring...
Entirely new learning process and a STEEP LEARNING CURVE since if it fails, you are ALWAYS out to sea somewhere... Hard to 'Walk Home' from there without getting REALLY WET!
I can see why the guys that do a lot of marine wiring that LIVES use tinned wire and gold plated terminals for about everything...
SAE and AWG are the same thing, more or less,
Both SAE and AWG were both based on the Brown & Sharp scales done before there was an SAE or AWG standard.
The biggest difference in SAE is the insulation. Automotive Insulation tends to be a little more geared to temperature than longevity, and later versions tend to melt rather than burn furiously like our older CJ wiring will do.
AWG wire comes in an 'Automotive' insulation jacket, but AWG Automotive (What you buy at most parts stores) tends to be a little better insulation if it's US Made,
If it's 'China' made, or anywhere else, the wire usually won't live up to AWG or SAE standards, and it's a crap shoot on insulation.
Since they don't have to have product liability insurance in the US, they don't really care if it lives or not.
When you wire radios or what ever, DO NOT use smaller gauge wire than is in the accessory it's self.
The longer the wire run, the larger the wire needs to be to feed the accessory. Smaller gauge wire will not deliver, and long runs build up resistance, so they won't deliver even at the same size.
This usually isn't a problem in something the size of a Jeep, but a truck or bus and you can run out of current pretty easy...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #84 of 147 Old 11-24-2013, 08:46 PM
EgulAye
1980 CJ5
You can definitely see the effects of living near the ocean and in a region where the roads are chemically treated in the winter. There is a brine solution that roads are often pre-treated with. Add in the salt and calcium chloride (I think that is what they use) and sometimes a recent wiring "fix" won't last more than a week or two. This will be my first winter driving a CJ, but my experiences with every other vehicle tell the tale.
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
post #85 of 147 Old 11-24-2013, 09:50 PM
mvigo
mvigo's Avatar
JeepHammer, great to hear from you! Hope all is well...
mvigo is offline
post #86 of 147 Old 11-24-2013, 10:55 PM
mscout118
1983 CJ7
Do you think a jeep that was ordered from the factory to be used by the USFS would have dedicated grounds?
Duke
mscout118 is offline
post #87 of 147 Old 11-25-2013, 07:27 AM
turbogus
1978 CJ5
I'm thinking that anything ordered by the Gov't is low bid and with minimal options. So I'm duboius that they would've gone the extra mile on grounds. This bears out true when I was in the Marines, the base's staff car was a Ford Maveric with 3 on the tree, radio delete and a host of other spartanized MIA accutruments... and would've had milk crates for seats if they could've gotten away with it.
turbogus is offline
post #88 of 147 Old 11-25-2013, 07:30 AM
turbogus
1978 CJ5
Thanks again for your insights JH! Glad to see you're still alive! Since I've last seen you on here I've gone to larger gauge wiring where ever possible and the fan upgrade and the graft of the Ford PDB, grounding bus bar, and all of the lighting wiring have come out well on 'Black Betty', I couldn't be happier with how it all turned out. Now on to the ream main seal.......
turbogus is offline
post #89 of 147 Old 11-25-2013, 09:23 AM
JeepHammer
Running On Empty...
1973 CJ5
Glad to hear it's working for you guys...
Got the usual bunch still arguing I have no idea what I'm doing, (and they 'Invented' grounding, like Al Gore invented the internet), but it's all good!
Just glad to be alive, and FINALLY have some time to post again!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #90 of 147 Old 11-25-2013, 09:37 PM
mscout118
1983 CJ7
Size:  58.7 KBThe reason I asked is because I read the military units were ordered with dedicated grounds. So I was curious if the USFS my have ordered on the same contract bid. Can anyone see the pic well enough to identify if there are any dedicated grounds?
Duke
tfi question tolobill Jeep CJ Forum 6 06-29-2011 08:51 PM
Calling Jeephammer spk454 Jeep CJ Forum 16 06-29-2011 08:06 PM
A good one for Jeephammer... Truck633 Jeep CJ Forum 5 09-11-2009 09:10 AM
Hey Mr. Jeephammer !!! grampsalso Jeep CJ Forum 0 08-18-2009 10:16 AM
Jeephammer I have a ? for you nsargeant Jeep CJ Forum 11 05-06-2009 05:12 AM
