Beefing up stock tire carrier - JeepForum.com
post #1 of 6 Old 12-06-2002, 04:37 PM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
Beefing up stock tire carrier **
Do you think that it would be safe to carry a 33x12.5 on the stock tire carrier if I were to back the tire carrier brackets up on the inside of the tub with 3/8" thick steel plate and bolt all the way through everything? I was thinking of some plate about 2"x 3" or whatever will fit.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #2 of 6 Old 12-06-2002, 06:48 PM
only in a jeep cj
Larger inside plates would be good insurance. Also check any points of freeplay. After all these years, your holes for the latch and swing pivot points should be ovaled a bit. These could be addressed by slightly larger bolts or drilling out the oval holes to slightly larges ones the accept brass bushings with the bolts going through. It's hard to explain it, but a rattling, loose rack will end up tight and like new. Some of my CJ buddies run 33 inch spares on a stock rack and it is fine unless the rear of the Jeep smacks down hard on something.....then it's rip city!
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #3 of 6 Old 12-06-2002, 09:41 PM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
Okay, thanks for the advise. I'll plate it up and check for oval holes.
post #4 of 6 Old 12-07-2002, 03:44 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
Daddy:
I never did it, I have a bumer-mounted unit, but I once got to thinking . . .
For the top two backing plates, why not make kind of an "L" bracket, so that it can also be bolted thru the top of the wheelwell? You could make it snug under the lip inside the tub, not very intrusive, I think. I like the idea of some of the weight being x-fered down onto a horizontal surface, better able to cope with the weight.
By the by, I think that the Bestop TJ tire carrier does something like this.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #5 of 6 Old 12-07-2002, 05:47 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
I have no problems carrying a 35 X 12.50 on a steel wheel on my beefed up stock carrier. I also have the whole front hub/rotor assy mounted on the carrier as well...
Steve
OldJeepguy is offline
post #6 of 6 Old 12-08-2002, 11:14 AM
Crash&Burn
I would think if the "L" bracket also tied into the 2 bolts on the roll bar you would gain quite a bit of stength..........
1979 CJ7 (YJ tub) full cage, Currie 9inch rear with Warn full float kit, detroit locker, 456 gears both ends, Lockrite in front, T 18 trans, 360, 040 over, Isky cam, 2 into 1 Flowmaster exhaust
I'm not as good as I once was....but I'm good once as I ever was.
Crash&Burn is offline
Stock CJ tire carrier xtremescootr Jeep CJ Forum 14 08-18-2009 05:37 PM
Stock CJ tire carrier on YJ tub TetanusCJ7 Jeep CJ Forum 2 06-12-2009 04:28 AM
stock rear tire carrier rficken42 Jeep CJ Forum 7 01-04-2009 02:36 PM
33" tire on Stock tire carrier??? drharkey Jeep CJ Forum 1 07-06-2006 09:16 AM
stock tire carrier strength? CJ7Rubicon Jeep CJ Forum 1 11-29-2004 07:12 PM
