Beeding the brakes on a 63 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Beeding the brakes on a 63
Premium LED Lighting by VISION X, Proudly sold at ROCKRIDGBds fox ipf 2.0 racing series shocks now available at rockEngo winches available at www.rockridge4wd.com! Free shipp
Unread 07-08-2014, 10:11 PM   #1
Unretarded
Unretarded's Avatar
1963 CJ5
Silly question....but, where do you add fluid to the brake system as there appears to be no reservoir on the master cylinder....
I plan to bleed the brakes after some work......but have been unable to locate a place to add fluid......brakes have been working fine and I figured I could hunt it down when needed......
Thanks
Jeep...the first vehicle on the moon.....next trip we are bringing the tub!
It is gunna cost more and take longer than you thought...plan ahead!
Unretarded is offline   Reply With Quote
Unread 07-09-2014, 12:40 AM   #2
Coiz
1979 CJ7
It has to be attached to, or part of, the brake master cylinder. What does your master cylinder look like, can you post a picture?
Mike
My build thread
Coiz is offline   Reply With Quote
Unread 07-09-2014, 05:29 AM   #3
hp_lovecraft
1981 CJ5
It has been years since I've worked on an early-Cj5, but the master included a small built-on reservoir. They had an odd bolt on the top that you had to remove to top-off.
My assumption is the small reservoir is due to space issues. The heater-core sits where most cars have the master/reservoir. So on the early CJ5s, the master is down low, attached to the frame.
On a related note, I've always had great success using the gravity method... but with such a low master, I wonder if thats even possible?
Edit: Here is a picture. Does yours look like this?
hp_lovecraft is offline   Reply With Quote
Unread 07-09-2014, 01:56 PM   #4
Unretarded
Unretarded's Avatar
1963 CJ5
Yes, that it is it.....can not see that from the bottom with the tub on......apparetly that is what the round plate in the drivers side floorboard I just monsterlinered over...OOoopppss.
Thanks!
Unread 07-09-2014, 08:17 PM   #5
DanStew
1963 M-38
Yup the MC is accessible through the little round plate. Get a long funnel or it will be a PAIN IN THE ARSE to get fluid in there. If you got the metal cap, clean it up, you cant get the metal ones anymore. The rebuild MC comes with plastic caps.
Dan Stewart
1963 M38a1
1991 Wrangler
DanStew is offline   Reply With Quote
