Bedliner removal - JeepForum.com
post #1 of 8 Old 05-01-2010, 10:59 PM Thread Starter
kakai81
Bedliner removal
I have a cheap bedliner installed from the PO. They didn't do any prep work, just rolled or sprayed the liner on. The liner is coming up in many spots and I'm removing it as it comes up It looks like crap and it holds water under the bubbled up spots. I'm afraid it will cause rust. The paint is still good under the bedliner. Does anyone know a way to remove the old bedliner without harming the paint underneath? If not, I can put a new bedliner coat in, but I still have to remove the old one and would rather not sandblast. What will remove this old junk?
kakai81 is offline
post #2 of 8 Old 05-02-2010, 04:38 AM
gmakra
Heat and scraping is the only way and its going to be a lot of work.
gmakra is offline
post #3 of 8 Old 05-02-2010, 07:27 AM
CajunCJ
I found a grinder with a wire wheel worked the best for me and yes it's going to be a lot of work. Good luck
CajunCJ is offline
post #4 of 8 Old 05-02-2010, 07:27 AM
CrazyHorse6
1979 CJ7
Brake fluid - works real well - however that will certainly take out the paint as well. There are lots of strippers that will melt the liner into mush but none that I know of that will take out the liner and leave the paint. Good luck
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
post #5 of 8 Old 05-02-2010, 09:41 AM
nitor
I've installed several bed liners in both truck beds and in Jeep tubs. Once I got a speck of bedliner on the outside of the bed. I called the manufacturer of the brand of bedliner I was using. They said that stuff is designed to not come off. They also said they didn't know of any chemical that would remove it. I used SEM brand bedliner, SEM Products - Catalog
I've also patched several bedliners. I know a friend that works in a body shop, and I patched a couple of bedliners on trucks that were fixed in his shop. Anyway, the only way I've found to remove the stuff is to take a wire wheel on a grinder or something similar to remove it. Of course this takes the paint off. If you want to have the liner on, you need to prep it correctly, and this means make sure you rough up what's going to be under it, whether that's bare metal or scuffed up paint. If you just apply it to the existing paint, without roughing it, it has nothing to stick to. That's why the PO's job is failing.
Thanks,
Jim
nitor is offline
post #6 of 8 Old 05-02-2010, 03:00 PM Thread Starter
kakai81
I've rolled on bedliners before and done the prep work. Those came out looking good and they've lasted. I think the po just wanted to get it over with, which ends up being a pain in my butt. As for the heat idea, that's how lots of the liner has come already. Whenever the floorpan gets hot some peels up.
CrazyHorse6, do you know the name of any of those melting strippers? I would have liked to protect the goodpaint underneath, but if I can't, I'll just reinstall the bedliner the right way.
kakai81 is offline
post #7 of 8 Old 05-02-2010, 04:22 PM
83VACJ7
1982 CJ7
Go to a gourmet cooking store and see if you can find a cleaning tool for sandstone cooking trays. It should be made of plastic or teflon. They are designed to avoid scratching the pan. That with moderate heat and an A** ton of work may be the ticket
83VACJ7 is offline
post #8 of 8 Old 05-02-2010, 04:30 PM
Military Jeeper
1979 CJ5
Jasper Paint Removal is what I used to remove the 3M bedliner on my Jeep.........needless to say it will remove your paint in addition to the liner. To be VERY honest, there is NO easy way to remove bedliner aside from media blasting it out (soda, glass, sand). Good Luck.
Jason "MJ" - 79 CJ-5 | SOA/HI-STEER | 304/T18A/D20 w/3:1 TeraLow | Holley Avenger Carb | Edelbrock Performer Intake Manifold | DUI Distributor | K&N Filter | Centerforce 2 Clutch | Waggy D44's | 4.11's | ARB's | Hydroboost | HAD Shafts | 35 Toyo MT's|
Military Jeeper is offline
bedliner on exterior RobsCrawlin7 Jeep CJ Forum 18 03-18-2010 02:36 PM
Update on bedliner removal N2SPD Jeep CJ Forum 5 03-08-2009 07:51 PM
bedliner removal -check it out sail78385 Jeep CJ Forum 1 07-17-2008 09:46 PM
What do you use the bedliner for? jeepmor Jeep CJ Forum 1 10-17-2006 07:35 AM
Do It Your Self Bedliner tico Jeep CJ Forum 15 11-08-2003 01:53 PM
