Bedliner for frame paint - Page 4 - JeepForum.com
 1Likes
post #46 of 58 Old 05-28-2010, 09:43 PM
Coiz
1979 CJ7
With the POR kit, I don't think you really need the alcohol. It can't hurt but I'm not sure you need it. Once all the repairs are done to the frame just hit the flash rust with a quick wire wheel if you want to. Wash it really good with a scrubby sponge and the Marine Clean diluted 4:1 with the hottest water you can stand(I did it twice). That's 4 parts water to 1 part Marine Clean. That stuff is the best cleaner/degreaser I have ever seen! You don't need to use it at full strength. Once it is clean, rinse it off, dry it with a towel then coat and soak with the Metal Ready. Watch where the Metal Ready drips off the frame. Have a few catch pans set up to collect what drips off and return it back to the spray bottle. You have to spray it down 3-4 times to keep it wet so you can go through it fast. It is reusable and fairly expensive so it is worth it to try and collect and reuse as much as you can, IMHO. Once it has soaked for 30~45 minutes rinse it and let it dry. It will turn a golden brown color. If there is any white chalky substance anywhere just wipe it with a clean dry towel. After that you are ready to apply the paint. The Metal Ready etches the metal and leaves a zinc-phosphate coating that I don't think you would want to wash off with the denatured alcohol.
Mike
Coiz is offline
post #47 of 58 Old 05-28-2010, 10:15 PM Thread Starter
Skerr
Mike- Thanks. I will follow your directions carefully. I am a little gunshy after this whole experience! Does the Metal Ready work like Ospho? I wonder if they are the same thing??
Kerrdog
Go Fish! <*////><
Skerr is online now
post #48 of 58 Old 05-28-2010, 10:18 PM Thread Starter
Skerr
Originally Posted by Bren Gun View Post
Sorry, haven't read the whole post, but I used Rustoleum bedliner and Rusty Metal primer to finish my '53 CJ3-B's frame and it looks fine. HTH
Your frames looks better than mine! Nice, flat and smooth finish. I have heard good things about the Rustoleum materials, besides them being around forever. Have you reassembled yet? Thanks for the pics.
Kerrdog
Go Fish! <*////><
Skerr is online now
post #49 of 58 Old 05-28-2010, 10:27 PM
Coiz
1979 CJ7
They both have phosphoric acid as their main ingredient so they are obviously similar but I don't see zinc phosphate on the Ospho MSDS sheet.
Also, make sure that frame is bone dry before you apply the POR. Wait overnight after cleaning or dry it and use a hair dryer or some other portable heater.
Mike
Coiz is offline
post #50 of 58 Old 05-28-2010, 10:33 PM Thread Starter
Skerr
Good stuff! Thanks for that!!
Kerrdog
Go Fish! <*////><
Skerr is online now
post #51 of 58 Old 05-29-2010, 05:43 AM
Bren Gun
Bren Gun's Avatar
No problem, it's getting there, but is a huge basket case right now sitting around the barn. Lots to do, good luck with yours too!
'99 TJ, '03 KJ and a '53 CJ3B sitting in the barn waiting on a restoration... @
Gone, but never forgotten... 1973 DJ5C, 1964 CJ5, 1953 M38A1, 1971 Hurst Special Jeepster
Bren Gun is offline
post #52 of 58 Old 06-19-2010, 01:13 PM Thread Starter
Skerr
You know how it goes... never at the speed that you expect, and there's ALWAYS something gets in the way of JEEP WORK! I want this done! I want the axles back under it! I want the drivetrain back in the frame! I want my shop cleaned up! I want my floor space back! It has been awhile since we got the frame stripped. I still have not picked up replacement 3/16 steel to make the patches. My neighbor, who will do the welding, is sitting on "G", and waiting on "O", so it's my fault. Or call it my WIFE's fault... since I don't want to except the repsonsibility of being slow! I know you guys are saying the surface rust, or flash rust, is not a big deal, but I'm nervous! I took a wire wheel to half of the frame and had to stop... it's 100 humid degrees here... will finish it later this evening. You can see in the first pic what I am knocking off. The other pics are for your viewing pleasure... one of them showing the significant rot outlined by a Sharpie. You SURE this is nothing to worry about?? Shouldn't I spray it down with rust converter?
Please put an old man at ease!!
Kerrdog
Go Fish! <*////><
Skerr is online now
post #53 of 58 Old 07-31-2010, 10:12 AM Thread Starter
Skerr
For anyone who may be interested in following this build, specifically frame repair, it is picked up in this thread http://www.jeepforum.com/forum/f8/cl...hread-1061897/
Kerrdog
Go Fish! <*////><
Skerr is online now
post #54 of 58 Old 07-31-2010, 12:23 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Here is a link to the cheapest place I have found to buy U-pol Raptor. I have orderd 7 kits from them and get excellent shipping and service.
U-Pol Raptor Truck Bed Liner Kit - TP Tools & Equipment
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #55 of 58 Old 09-09-2010, 07:37 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Slight necropost here, but I'd POR right over that surface rust, if you haven't already.
POR stand for
Paint
Over
Rust.
They specifically state that you can and should paint right over light rust. Helps the POR "grab" better.
Pacfanweb is offline
post #56 of 58 Old 09-09-2010, 04:34 PM Thread Starter
Skerr
POR stand for
Paint
Over
Rust.
Pacfan... you're right. If I had it to do again, I would. But I second-guessed myself, out-thought it... whatever! If I EVER do another frame, I will use the POR kit through the whole process... which means the 7 will probably get it once we finish the 5.
Kerrdog
Go Fish! <*////><
Skerr is online now
post #57 of 58 Old 01-04-2017, 10:19 PM
Hankey
1979 CJ5
I know this is a really old post but damn I'm wondering how it turned out ?!?!?! Any pics or anything
Hankey is offline
post #58 of 58 Old 01-05-2017, 04:33 AM
Makanak
1982 CJ7
I think they all died from huffing acetone and MEK.
Makanak
Hankey likes this.
The more I try to pursue the easy way out the more difficult it is to reach my goal.
Makanak is offline
paint frame other than por 15 DeadPhish Jeep CJ Forum 35 02-08-2012 01:10 PM
CJ Frame Paint jayhawkclint Jeep CJ Forum 11 06-22-2007 07:17 AM
Frame Paint... collinpyle Jeep CJ Forum 5 08-22-2006 12:10 PM
Frame Paint? DaveFL Jeep CJ Forum 10 10-01-2002 04:26 PM
Frame Paint Guy Hollister Jeep CJ Forum 6 11-12-2001 03:53 PM
