Bds lift issues on 1979 cj7 - Page 3 - JeepForum.com
post #31 of 37 Old 10-15-2011, 10:00 AM
skizriz
1978 CJ7
Originally Posted by kw89425 View Post
It will change the toe if the axle is rotated it may not be extreme but it will. If you rotate the pinion up what do you think is going to happen to your toe in? I have had lifted trucks all my life i know it will change but im not here to fight about it.
Actually I see the point you are making. Changing the caster will also change the toe. Unless you have 0 toe to begin with.
Not much of a toe change, but it would change.
Take it to the extreme and rotate the axle 180, the leading edge would then be toed out.
skizriz is online now
post #32 of 37 Old 10-15-2011, 10:44 AM
kw89425
exactly. if you lift the older chevy trucks the springs have degree shims made on the spring and you have to reset the toe.
86 cj7 496 powered 465/205 ton axles 38.5 boggers
kw89425 is offline
post #33 of 37 Old 10-15-2011, 11:39 AM
lucdog
lucdog's Avatar
1980 CJ5
Nope, I'm not going to argue either.
Your Jeep sounds bada$$, BTW
BILL
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #34 of 37 Old 10-15-2011, 11:50 AM
kw89425
BILL
thanks bill
kw89425 is offline
post #35 of 37 Old 10-15-2011, 06:39 PM
bigredisb
1979 CJ7
Originally Posted by CSP View Post
Wow. It absolutely does matter.
Lets try this again. If you can't get it this time I'm at a loss because it's PAINFULLY simple.
Wow you are absolutely right. I can't believe someone would question this.
Apparently our CJ's are so old no one has ever seen one before. They are painfully simple and easy to set up.
I set my drag link position just by eyeballing the wheel position. I would say most can align toe by tape measure. My Dads tech school has a alignment rack so I checked my toe and I was only off by about a 1/16 of an inch by setting it with a tape.
1979 CJ7 aka "Christine" Build Thread:
2013 Rubicon Unlimited build thread:
bigredisb is offline
post #36 of 37 Old 10-15-2011, 10:57 PM
John Strenk
John Strenk's Avatar
1976 CJ5
I too see your point and also, isn't there something funky about shimming to keep pinion angle correct that messes with the castor also?
John Strenk is offline
post #37 of 37 Old 10-17-2011, 07:07 AM
CSP
well if the lift springs rotate the axle any it will change the toe and caster, longer shackles will change it as well.
It's not really an issue with CJ lift springs since the axle mounts dead center in the springs arch, so either end of the spring lifts the axle equally without any rotation.
Like you said though, add lift shackles and you do change the geometry, but if would have to be a very tall lift shackle to affect toe to any noticable amount.
CSP is offline
leaf spring , lift , tire rub
Shocks for a 1979 CJ7 w/ 2.5 inch lift *Thunder Jeep CJ Forum 2 09-21-2013 12:50 AM
1979 CJ5 Fuel Issues...And the Reason EthanW Jeep CJ Forum 0 08-08-2011 07:26 PM
1979 CJ% with 8 " Lift what shocks do I need kluman Jeep CJ Forum 2 07-10-2010 10:51 AM
4" Suspension LIFT???? 1979 CJ7 swamper Jeep CJ Forum 5 07-04-2007 11:03 AM
BDS 4" Suspension Lift for a 1979 CJ5 77CobraII Jeep CJ Forum 1 02-11-2003 11:34 AM
