Bds lift issues on 1979 cj7 - JeepForum.com
post #1 of 37 Old 10-12-2011, 07:23 PM Thread Starter
Freewheeling
1979 CJ7
I just installed a bds 4" lift on my 1979 cj7. I have 33" tires and when I turn to the left my tire rubs on the front right leaf spring. No problems turning to the right. And ideas would really help. Thank you.
Freewheeling is offline
post #2 of 37 Old 10-12-2011, 07:31 PM
gojeepgo
1981 CJ7
Did you just add the tires when you did the lift? I would adjust the stops on the steering knuckle. The stops might not have been adjusted properly and you only noticed when you added the wider tires.
gojeepgo is offline
post #3 of 37 Old 10-12-2011, 07:43 PM Thread Starter
Freewheeling
1979 CJ7
New tires and new lift at the same time. Ya I noticed it turns more to the left then the right. I will give that a try. Thank you for the quick reply.
post #4 of 37 Old 10-13-2011, 06:24 AM
CSP
With the lift the distance between the pitman arm and passenger side knuckle became longer and the drag link effectively became shorter. Your steering wheel should also be off center when the tires are pointed straight ahead.
Because of this you've lost steering radius in one direction and gained it in the other. Adjust your draglink length so that the steering wheel is centered and it should fix the problem.
CSP is offline
post #5 of 37 Old 10-13-2011, 06:35 AM
frankenstienCJ
1978 CJ7
I agree with CSP. The other thing to look at is. IF the tires are wider you also might need a rim with a different back spacing. I did the same to my jeep. In the end it was either wheel spacers or new rims. I went with new rims with a different back spacing. I did adjust the the steering and the in the end it still rubbed to the left.
frankenstienCJ is offline
post #6 of 37 Old 10-13-2011, 06:48 AM Thread Starter
Freewheeling
1979 CJ7
Your correct cps. I do have more steering to one side. I'm new to this and I appreciate the info. I will give that a try. Thank you.
post #7 of 37 Old 10-13-2011, 07:12 AM
BDS-Tech
I don't know how the axle can really get off center with leaf springs and still have everything bolt together correctly, but I suppose anything is possible, it is a Jeep... Can you check to make sure the axle is centered under the Jeep? And- did you have it aligned after the lift? If not, CSP is spot on.
phone: 517-279-2135
BDS-Tech is offline
post #8 of 37 Old 10-13-2011, 08:32 AM
CSP
I'm not sure why you would think this is the case.
If the OP didn't lengthen the drag link with the lift his steering box (and thus the steering wheel) are off center. No two ways about it. With the steering box off center it runs against the internal stops in the box turning one way and has plenty of room the other way.
There shouldn't be any need for an alignment. Toe-in is the only thing that is adjustable and adding a leaf spring lift doesn't do a thing to change toe.
Once adjusted both sides will probably rub the springs. Larger diameter tires are closer to the springs than smaller tires and it's normal. Once the draglink length is corrected the steering stops on the knuckles can be adjusted.
CSP is offline
post #9 of 37 Old 10-13-2011, 08:39 AM
BDS-Tech
There shouldn't be any need for an alignment. Toe-in is the only thing that is adjustable and adding a leaf spring lift doesn't do a thing to toe.
I did not say it was the case. I said it was unlikely.
This drag link adjustment you are talking about would generally be part of an alignment. The steering box itself physically cannot be off center unless the frame is bent- the pitman arm and steering wheel can be off center, requiring a drag link adjustment- which also means that the toe would need to be adjusted. IE- An Alignment.
phone: 517-279-2135
BDS-Tech is offline
post #10 of 37 Old 10-13-2011, 08:56 AM
CSP
The pitman arm is physically connected to the steering box. If the pitman arm is off center, then the internals of the box are not centered between the range of the stops, therefore the box is off center.
I didn't mean to imply that the actual steering box as a whole had moved.
It's easy to correct this, rather than paying for an "alignment". This is doing nothing to adjust the steering angles of the front axle (toe, camber, or caster).
With the tires pointed straight ahead remove the draglink from the pitman arm. Turn the steering wheel all the way the right then all the way to the left counting the number of revolutions from one side to the other. Turn it back half the number of revolutions and the box will be internally centered as should the steering wheel. Without moving the tires or the pitman arm adjust the draglink length so that it will attach back to the pitman arm. Done.
CSP is offline
post #11 of 37 Old 10-13-2011, 09:02 AM
1980tallcj7
1980 CJ7
I think what he meant with the "steering box off center " was that the pitman arm was not pointing perfectly to the rear when the tires are pointed straight.
I say it never hurts to get an alignmnent after replacing the suspension on a vehicle ....and I'd assume adjusting the drag link would be part of the alignment.
1980 CJ7,
1980tallcj7 is offline
post #12 of 37 Old 10-13-2011, 09:20 AM
BDS-Tech
For what it's worth, 85% of the tech calls we get here result from problems that arise in Trucks and Jeeps that have not been properly aligned. Everything from post-lift death wobble to ESP issues and off center axles has been magically fixed by a date with the alignment rack.
phone: 517-279-2135
BDS-Tech is offline
post #13 of 37 Old 10-13-2011, 09:22 AM
BDS-Tech
So he shouldn't need to set the toe?
phone: 517-279-2135
BDS-Tech is offline
post #14 of 37 Old 10-13-2011, 09:42 AM
CSP
Toe doesn't change on a CJ with a suspension lift. The tie-rod is not touched when you swap springs out.
A CJ has a separate drag link and tie-rod. Each has their own holes on the passenger knuckle.
CSP is offline
post #15 of 37 Old 10-13-2011, 10:05 AM
BDS-Tech
lifting the vehicle will absolutely affect both the drag link length and the toe- You have changed the relative distance between the pitman arm and the steering knuckle, which effects both toe, and drag link length- and if you change one, the other changes.
A CJ should have an adjusting sleeve- why would you disconnect the drag link to turn it? Turning the sleeve will allow you to center the pitman arm and the steering wheel and correct the drag link length. And, I really, really, really promise that changing the drag link angle will affect toe- when you move the drag link, the knuckle that it is attached to will move in or out, depending on which way you turn it. How can you move the knuckle without affecting toe?
Even if you remove the drag link, shorten/lengthen it and put it back, the relative distance between the steering knuckle and the pitman arm will have changed, and when that changes toe changes as well.
phone: 517-279-2135
BDS-Tech is offline
leaf spring , lift , tire rub
Shocks for a 1979 CJ7 w/ 2.5 inch lift *Thunder Jeep CJ Forum 2 09-21-2013 12:50 AM
1979 CJ5 Fuel Issues...And the Reason EthanW Jeep CJ Forum 0 08-08-2011 07:26 PM
1979 CJ% with 8 " Lift what shocks do I need kluman Jeep CJ Forum 2 07-10-2010 10:51 AM
4" Suspension LIFT???? 1979 CJ7 swamper Jeep CJ Forum 5 07-04-2007 11:03 AM
BDS 4" Suspension Lift for a 1979 CJ5 77CobraII Jeep CJ Forum 1 02-11-2003 11:34 AM
