Battery relocation... - JeepForum.com
post #1 of 6 Old 09-09-2009, 01:54 PM Thread Starter
PhatBasturd
PhatBasturd's Avatar
1976 CJ7
Any drawbacks/safety issues to having the battery located behind the seat on a CJ? Enclosed with a hardtop?
PO of my CJ did this with 1/0 welding cable grounded to the frame and another piece of 1/0 to the engine compartment.
PhatBasturd is offline
post #2 of 6 Old 09-09-2009, 03:02 PM
JoonHoss
2011 JK Wrangler
potential fumes from an unsealed battery, potential arc'ing it it ever comes loose( or has stuff stored/thrown across it), more difficult to jump if needed, loss of already limited interior space. longer cables offer more resistance (less power for starting)...
Hoss
"three gallons of low lead; two hot dogs and a strawberry soda..."
JoonHoss is offline
post #3 of 6 Old 09-09-2009, 03:38 PM
duffer
1955 CJ3B
I put mine in a built-up steel box which is welded to the frame and cross-member, under the floor, behind the driver's seat (should be photo in my gallery pics). It has an aluminum hold down bar, battery disconnect, and flush fitting, hinged access lid. I used 2-0 cable to the starter and a 1-0 cable to both the frame ground and bellhousing, directly behind the starter. It is vented below the floor. It has been time tested for 32 years in this location. A word of caution: you will end up with a long, unprotected positive lead that if allowed to short, will likely burn up your Jeep. I used split-loom over the top of the welding cable and all rubber-bushed (EPDM) cable clamps. The sheathing/cable does not contact ground anywhere. My winch lead connects at the starter and I have not noted any current limitations with this arrangement.
duffer is offline
post #4 of 6 Old 09-09-2009, 07:54 PM
JeepnBlake
in the glove box might work
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #5 of 6 Old 09-09-2009, 07:57 PM
5-90
5-90's Avatar
1988 XJ Cherokee
I used to do this with street/strip cars.
The only change I'd really suggest would be to use a "pass-through" post to go through the firewall, instead of drilling a hole and passing the cable. Likewise with any other bulkheads. If you can't find any, let me know (I have some.)
The battery, if being mounted in the pax area, should go into a sealed box and vented outside the vehicle! Even "sealed" "maintenance-free" batteries will still outgas when charged, and this is what can cause you the trouble (yep - even Odyssey and Optima batteries have vents in the lids. You won't lose electrolyte, but you'll still get outgassing.)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #6 of 6 Old 09-09-2009, 08:05 PM
scottymac62
1979 CJ7
Like this
Summit SUM-G1431 - Summit® Bulkhead Cable Connectors - Overview - SummitRacing.com
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
CJ7 Battery Tray... Battery Mount Rupie25 Jeep CJ Forum 7 12-20-2009 11:19 AM
Battery gauge reading low: Old battery died and still reads low with new battery jatepper Jeep CJ Forum 16 08-30-2009 03:25 PM
New Battery, New wiring... draining battery dead. HELP!!! CoyJ-5 Jeep CJ Forum 7 07-31-2009 08:54 AM
Battery being drained while car is running??? Car off, I believe battery is good! Jeap Jeep CJ Forum 2 11-09-2008 07:31 AM
Seat Relocation jksull Jeep CJ Forum 12 02-06-2008 08:08 PM
