battery not charging due to oil on the belt? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > battery not charging due to oil on the belt?
1976-1986 Jeep CJ7 with Stationary Vent Windows Weatherstr1978-1986 Jeep CJ7 Fuel Tank with Strap Set 15 GallonApril Savings Save 5% Off Of Jeep Product Orders
Unread 04-14-2011, 07:34 PM   #1
TJTony
been dealing with an oil leak, and i think its from under the distributor. however, my battery died today. now the volt meter isn't going past 12, even when i rev it. could it be possible that oil o0n the belt is causing it not to grip and rotate the alternator enough? volts not going up when i rev either.
1985 CJ-7 Laredo 258, 4 spd manual, Weber 32/36, Team Rush, nuttered. Still has the stock upper seat skins, full skin for rear seat, stock AMC tape deck.
TJTony is offline   Reply With Quote Quick reply to this message
Unread 04-14-2011, 07:52 PM   #2
Shiftace
1977 CJ5
Most likely your alternator/voltage regulator.
[QUOTE=gpets;10833372]...it is perfectly acceptable to take a sawzall to anything you can't figure out, that is how we all learn.[/QUOTE]
[url]http://www.funnyordie.com/articles/322261cd73/why-internet-commenters-will-eventually-end-the-world[/url]
Shiftace is offline   Reply With Quote Quick reply to this message
Unread 04-14-2011, 08:45 PM   #3
Skerr
Oil could cause your belt to slip, so if you have oil on the belt/pulley, you should clean it off and tighten it up. If that doesn't fix the problem then check your battery connections/grounds. After that... solicit "The Guys"!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 04-14-2011, 08:54 PM   #4
TJTony
yeah, i need to fix the oil leak first. hope its not the bearing.
