Quantcast Battery Ground - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Battery Ground
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 11-16-2004, 12:35 PM   #1
tvl76
1973 CJ5
Battery Ground
I've had, and still have some electrical and gauge problems. To check for proper grounds, I temporarily connected a length of wire to my battery ground terminal and then touched the opposite end to my ground points.
The problems I was hoping to solve are still unsolved. But I did notice, that my dash and exterior lights would brighten with the ground wire direct to the battery.
Now I want to connect a permanent ground wire between my battery and a point on my firewall.
What do ya all think ? Good or bad idea ?
73 CJ5, Original Owner, Fawn Beige / Black trim, 304 bored over, 2.5" lift, 15x10 Polish Alum, BFG MudT.
tvl76 is offline   Reply With Quote
Old 11-16-2004, 12:40 PM   #2
Geer_hed
It won't hurt anything, but if your gauges brighten when you re-enforce the ground, then your dash ground is not so great. That little ground strap right below the light switch on the inside of the dash. Try adding a good ground strap to the dash and ground it out better, see if you don't get the same results.
Of course, it's possible there's a charging problem which would be particularly exaggerated by the dash illumination fluctuating. of course, the purist thing to do is clean or replace all of your grounds, but what a PITA...
[center][color=black][b]85 CJ7 / 258 / T176 / Dana 30/ AMC 20[/b][/color]
[url=http://www.geocities.com/cantwait_forviolence/]My Online Dumping Ground[/url][/center]
Geer_hed is offline   Reply With Quote
Old 11-16-2004, 12:48 PM   #3
tvl76
1973 CJ5
I was experimenting with all this, without the moter running. So how can it show a charging problem ?
Old 11-16-2004, 01:31 PM   #4
kaptainkarst
quickest way is to put a volt meter on the battery with the motor off. Note the voltage (should be between 12 and 13 volts for a charged battery)
Start the Jeep and check the voltage again. Is it higher (14 - 15 volts or so)?
78 Cj7
Fresh Paint Job
Custom Dash
82 complete rebuilt 258 bored 30 over
Holley Fuel Injection
TFI Ignition Upgrade
Headers, Flowmaster
Ford T-18 w/Novak Conversion, Dana 300
2.5" Suspension Lift w/ 2" shackle lift
33" x 12.5" x 15"
Ramsey 8000 Lb Winch with in-cab control
Custom built brush guard with crane attachment
On-board Air, On-board shower, On-board nut
Rear mounted fuse panel w/50 amp service
kaptainkarst is offline   Reply With Quote
Old 11-16-2004, 03:18 PM   #5
MudMonster
ive got a ground to my block (which also grounds to the frame) and to my firewall
"Don't be too proud of this technological terror you've constructed"
[COLOR=red][B][SIZE=3]RED JEEP CLUB MEMBER #78[/SIZE] [/B] [/COLOR]
[B][COLOR=red]BIG GUNS[/COLOR] [COLOR=white]AND[/COLOR] [COLOR=blue]JEEP[/COLOR] OWNERS OF AMERICA CLUB MEMBER #3[/B]
[B][COLOR=Red]Red[/COLOR][COLOR=Blue] Neck [/COLOR] [COLOR=Red]Jeep[/COLOR][COLOR=Blue] Club[/COLOR][COLOR=White]Member#27[/COLOR][/B]Fire Engine Red '85 CJ-7, Howell FI-258, T-176, D300, 9", Warn Internal Hubs, Wagoneer front springs, RE Wrangler's in the rear, 33" TrXus', HEI conversion, Taurus fan, no emissions junk, and some 150w daylighters
MudMonster is offline   Reply With Quote
Old 11-16-2004, 06:35 PM   #6
alabamabuddog
1981 CJ7
There should be a ground strap from the battery to the body and from the engine block to the body. This will make a big differance when its off. When mine is broken I can see the volt meter act up when the blinkers are on.
alabamabuddog is offline   Reply With Quote
Old 11-18-2004, 05:28 AM   #7
Scrambler82
Scrambler82's Avatar
1982 CJ8
GREAT IDEA to add an additional ground system or just replace the existing ground system with a new one !
Grounding has to be one of the biggest older vehicle problems there is.
Either add new ground straps at all points or run a heavy gauges fine stranded wire along on side of the vehicle, inside preferably. Add a some terminal blocks along the length of the ground wire and then connect all of your electrical grounds to these terminal blocks.
Remember that every thing electrical need a (+) positive and (-) negative ( ground) in order to work properly, so the better the path the better the electrical component will perform.
Use a small amount of Conductive Electrical Paste, you can get it at an electrical store, and add it to all of your ground connections, not too much though.
If you stick to adding ground straps, make sure you have bare metal before attaching the ground straps and use a little of the Paste on the connections.
Another thing to help with the contact is to use external tooth lock washers above and below the ground lugs.
Later,
Scrambler82
Do it right the first time !
Scrambler82 is offline   Reply With Quote
Glock Forum
