Battery Drains - JeepForum.com
post #1 of 6 Old 02-22-2013, 09:16 AM Thread Starter
ColdSteel85
1982 CJ7
Battery Drains
Hey y'all. I currently own my second CJ. The newest I bought 3 weeks ago. I know battery drainage is a common problem in the CJs and both that I own/ed have had this issue. Wondering if there is a common issue that causes this or does it vary greatly from one jeep to the next? Thanks
ColdSteel85 is offline
post #2 of 6 Old 02-22-2013, 09:25 AM
waterdowg
It varies on the Jeep and the wiring. Mine does not drain, I let it sit weeks and its fine.
waterdowg is offline
post #3 of 6 Old 02-22-2013, 11:47 AM
wm69
With key off, remove neg batt cable, and put clamp on cable end, and probe on battery neg post. Light will be lit if you have a drain. If light is on, start unplugging fuses one at a time, and when the light goes out, you've found the particular circuit your drain is on. If you pull all fuses and still have a drain, try unhooking your alternator and see if it goes out. My drain was a bad diode in the alterntor that was draining the battery.
wm69 is offline
post #4 of 6 Old 02-22-2013, 11:51 AM
waterdowg
x2 on this to see if you have drain. But make sure you unplug the hood light and radio if you have one thats got a constant power. Those will alway show a drain and will lead you on a wild goose chase. Ask me how I know...
post #5 of 6 Old 02-24-2013, 05:08 AM Thread Starter
ColdSteel85
1982 CJ7
Ok thanks plan to start that journey today. In regards to constant power sources, I have a Laredo with the factory clock that still works. That should be unplugged as well before I start I assume? Thank you
post #6 of 6 Old 02-24-2013, 06:37 PM
waterdowg
Yes unplug it.
