BASIC WIRING 101, Getting You Started! - Page 7 - JeepForum.com
 3Likes
post #91 of 144 Old 07-25-2013, 01:38 PM
turbogus
1978 CJ5
Hmmm never seen one of those PICO 0952A connectors before. Must be for later gear than what I'm used to working on, but then what isn't these days?
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #92 of 144 Old 07-25-2013, 02:03 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Yeah, they plug in here . Look for CLock or AC connections.
John Strenk is online now
post #93 of 144 Old 07-25-2013, 03:05 PM
2girlsAndaGuy
1979 CJ5
Just found these, better post it wile I have the info.
Pico 0952A GM Ignition Cavity Fuse Block Tap - Clear
http://www.repairconnector.com/produ...2d-Clear-.html
Other than one having a 14g wire and the other having a 16g is there any difference between these two?
http://www.repairconnector.com/produ...Always-On.html
David
2girlsAndaGuy is offline
post #94 of 144 Old 07-25-2013, 04:26 PM
John Strenk
1976 CJ5
Great catch!!!!
Yes I believe the retainer clip is in different locations.
Look at the "clock light power" and the "A/C" locations and it looks like the clip openings are different shapes
THis needs deeper investigation...Find any more?
post #95 of 144 Old 07-25-2013, 07:39 PM
2girlsAndaGuy
1979 CJ5
Those were the only two I saw, I am going to order both as I need a clean way to hook up my radio and cb. I will post up results when I get them.
David
post #96 of 144 Old 10-20-2013, 08:29 PM
243
1978 FSJ Cherokee
I hope this is the correct place to post this link, "GM ATO Style Fuse Block"
http://www.rowand.net/Shop/Tech/GMATOStyleFuseBlock.htm
Dave's 78 Build
243 is offline
post #97 of 144 Old 01-29-2014, 07:27 PM
locohosa
Wire Size Questions
Wire Size Questions
Hey folks, I am getting ready to order everything I need to Re-Kajigger my grounds and battery cables. I figured I would just use 10 gauge for all my dedicated grounds, but I went to buy 50 feet of Black 10 gauge wire and was completely sicker shocked…
What size wiring have you been using for dedicated grounds? Where did you purchase the wiring?
I had the silly thought that if right now my entire Jeep is being grounded with a single 6 gauge wire coming from the Starter to the Battery, even if my dedicated grounds were all 14 or 16 gauge it would improve the situation greatly… Is there anywhere specific I should use heavy wire? Such as headlights and alternator?
Im new at this.
1996 Dodge Ram Cummins, 5.9L, NV4500, 4x4
1955 M35A2
1984 CJ7 4.2 T176, on 33s
locohosa is offline
post #98 of 144 Old 01-30-2014, 07:25 AM
turbogus
1978 CJ5
Hmmm, when I wired up my grounds to that buss block (posted earlier) I used all 10 gauge from a small spool that I believe I got it at NAPA for reasonable last year.
turbogus is offline
post #99 of 144 Old 01-30-2014, 07:46 AM
ChrisHager
Administrator
ChrisHager's Avatar
Amazon has 100ft of Black 10GA wire for $26.50 (though a couple reviews aren't spectacular). That's about $0.27 per foot: Amazon 10GA Wire
NAPA shows $0.72/foot for a 100ft spool of Black 10GA: NAPA 10GA Wire
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #100 of 144 Old 01-30-2014, 09:20 AM
texasdave
texasdave's Avatar
1980 CJ7
http://www.waytekwire.com/products/
http://www.texasindustrialelectric.c..._terminals.asp
These two companies have some of the more difficult to find connectors to include weather proof packard connectors
texasdave is offline
post #101 of 144 Old 06-04-2014, 11:41 AM
PastorGman
JeepHammer, just wanted to say thanks for all the info you posted. I have a 74 CJ-5 which is going thru a "Painless"...lol wiring harness install and your info is going to help me a lot. Just going through it for a few minutes I probably said, "so that's what that means" so many times cause the pictures and images cleared up a lot for me. Just wanted to say thanks and to all others that contributed. Really appreciate it.
PastorGman is offline
post #102 of 144 Old 09-29-2014, 07:24 AM Thread Starter
JeepHammer
Running On Empty...
1973 CJ5
Lots of wiring questions all popping up at once again, is it time for this thread to surface again?
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #103 of 144 Old 09-29-2014, 07:32 AM
turbogus
1978 CJ5
As it's been said many times before JH, I think this thread should be a sticky as I too reccomend this thread to others here and on other forums.
turbogus is offline
post #104 of 144 Old 09-29-2014, 07:58 AM
texasdave
texasdave's Avatar
1980 CJ7
It is a stickie look under electrical and it is under electrical. I brought it to Besrk attention and he was kind enough to put it in there. Now to get the clientele to use it. An excellent write up with loads of additional information.
post #105 of 144 Old 09-29-2014, 08:31 AM Thread Starter
JeepHammer
Running On Empty...
1973 CJ5
If you do this crap long enough, you find some ways that work better than factory, some short cuts, some things that keep your electrical system working...
Just trying to pass along some of that information to the guys that are just learning.
I just put down basics, it was the usual suspects that added the particulars that make it possible.
I buy in bulk. Nothing like having the crap you need at hand WHEN YOU NEED IT!
Leave it to the 'CJ Scroungers' to find sources for small quantities, odd ball sources and scour the internet & parts books for the stuff we need but can't get specifically for a 'CJ'...
They find it where it was used on something else and I can't do without them! This is a collaborative effort, all I did was get the ball rolling.
I've said it before, and I'll say it again...
Nothing like having the correct tools, and a ton of guys rooting out the parts for you!
The problem with that is, you have to go through a TON of tools (and expense!) to figure out what tools work CORRECTLY!
A head start there gets you a long way towards your objective,
But without the correct parts, connectors, terminals, ect. it's MUCH harder!
I try NOT to go into things like Induction, Electromagnetic Interference, Impedance, Resistance, ect. unless it's specific to what folks are trying to accomplish.
These BASIC wiring runs are pretty simple, and save you the brain drain/issues you have with something like 'Painless' or one of the other 'One Size Fits Nothing' full harness replacements, Along with teaching something and preparing you to deal with any issue you run into down the road.
There is a thread running over two months on a harness replacement with a 'Kit' and hundreds upon hundreds of posts trying to get the inexperienced installer up and running correctly.
By just replacing one section of the harness at a time, you learn something, you have a harness that is CUSTOM FIT to your application, works better than the original and will live a LONG time without 'Issues'...
Unless you are just in a hurry (and you usually spend more time trying to cobble together things to work than if you had done it yourself),
Or believe the 'Far Away Expert' knows what you need better than YOU, the JEEPER,
This is usually the way to go...
One wire at a time... Nothing to it that way...
Pretty soon, you will be able to sort out the circuits in your head and then you are off to the races!
Won't be long until you can 'See' the circuit in your head, know EXACTLY what wire gauge, connector/terminal, if you need solder or not, heat shrink or not, how to test and refine your harness to work best for YOUR application!
Nothing like having this stuff work for you instead of constantly fighting the factory screw ups in the harness!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
Contour Fan Wiring Help for Dummies-Need basic instruction Dborns Jeep CJ Forum 29 01-12-2015 07:11 AM
CJ-7 T-5 Tranny: "Basic one" VS Basic Two Group_er Jeep CJ Forum 0 10-15-2009 10:22 PM
CJ5 Wiring - Basic Help - (Rockford Illinois) Matusel3 Jeep CJ Forum 21 09-28-2009 11:58 AM
basic wiring diagram? Sedorbrian Jeep CJ Forum 9 04-12-2009 05:48 PM
Basic Wiring Question (painless?!) Floridazed Jeep CJ Forum 11 12-11-2008 10:31 AM
