BASIC WIRING 101, Getting You Started! - Page 6 - JeepForum.com
 3Likes
post #76 of 144 Old 05-13-2013, 04:40 AM
CJ7KAHUNA
Originally Posted by kconnor123 View Post
Where is jeephammer???
X2
We need the HAMMER
CJ7KAHUNA is offline
post #77 of 144 Old 05-13-2013, 07:10 AM
billybooster2
1983 CJ8
The contour fan has two speeds using the built in resistor. If you go with two 70 a relays, you will not cook anything
billybooster2 is offline
post #78 of 144 Old 05-13-2013, 07:19 PM
TmasCJ5
1977 CJ5
hoping to get an answer on this thread. I'm working on wiring on my 1977 CJ 5, just starting to completely rewire the engine bay. How do I get the male Packard terminal out of the bulkhead to replace. I tried pulling and pushing a little but didn't want to get too carried away, does it have a locking tab like the female? I wanted to take one down to the parts stores to make sure I get the right match when I buy parts thanks guys
TmasCJ5 is offline
post #79 of 144 Old 05-14-2013, 03:36 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Little trickier. Nothing a needle nose pliers wont help. Thats how I got mine out.
John Strenk is offline
post #80 of 144 Old 05-14-2013, 03:49 AM
John Strenk
1976 CJ5
Originally Posted by turbogus View Post
I've been concerned with running that 70 amp relay so when the Ford Contour fans come on together they don't cook the relays, however I'm wiring these fans independantly with their own controllers, fuses, relays and wiring...
Therefore this eliminates the overamp issue doesn't it?
As many may have seen from my posts I've already prepared relays, sockets and wiring for that 70 amp relay but now I'm thinking it's all for naught.
Confirmed OK by another, but then since it's already been prepared nothing wrong in over engineering I think.
Only thing I can think of is that it would be better to run it off two 30 Amp fuses instead of 1 60 Amp fuse.
What is you have a 50 amp short in one circuit, it would not blow the fuse and still start a fire.
Plus the dual fuses will give you a redundantcy that in case one fan shorts out and blows the fuse, the other one can still keep you cool.
In fact run the controller power off another fused circuit.
post #81 of 144 Old 05-14-2013, 07:26 AM
turbogus
1978 CJ5
I've found working with the connectors the use a locking tab (or the receptacles that have a locking tab as Ford does) I've been using a flat and round needle file to get adequate bite when I'm probing for those tabs. It's made removal a lot easier for me.
I'm following John's wiring diagram in my twin controller setup presently (going through a wiring conundrum) while cleaning up the wiring in general on my setup.
WIth all of the relays and grounding circuits I've been using a ground block that's tied directly to the negative battery post, but by now the lines going in are getting too numerous (12 ground terminals), how have you guys attended to your numerous ground wires? is there a more elegant method?
I'd bet John and JH would know.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #82 of 144 Old 05-14-2013, 08:56 AM
aclaugh1
1982 CJ8
I'm using a grounding bus bar that I bolted to the fender, then connected that to the negative terminal and the tub with grounding strap I had laying around.
It is easy and very convenient. If you do it right (not that I did) and wire things neatly, it can look pretty sharp.
aclaugh1 is offline
post #83 of 144 Old 05-14-2013, 02:06 PM
AFRd_CJ5
1976 CJ5
Mine is essentially the same way. I have a few distribution blocks from a car audio store behind my dash. One runs all my switched power, one runs all my grounds to the battery, and another runs all my always on wires to the battery.
'76 CJ5
434 pump gas SBC with an NX/HVH plate system
th350/Coan 5,000 converter/Dana 300 tcase
Dana 30 front with 4.56's/Dana 44 rear with 4.88's
AFRd_CJ5 is offline
post #84 of 144 Old 05-14-2013, 02:32 PM
turbogus
1978 CJ5
Thanks guys, any pic's or model/part nos.?
I'm presently running one (NSI branded) that's configured like this
turbogus is offline
post #85 of 144 Old 05-21-2013, 08:52 AM
turbogus
1978 CJ5
Regained my brain and found a 20 position bus bar at Hab for Humanity for $3.00 clams, mounted it on the firewall behind battery #2. Once all the grounds are connected going to swab the works with dielectric grease.
turbogus is offline
post #86 of 144 Old 05-21-2013, 08:58 AM
John Strenk
1976 CJ5
I'm a little confused on the one on the right.
What are those horizontal lines going through the six holes.? I thought they were thread on a set screw but I can't figure out how you would tighten them. Are the a slide lock connector or something ?
post #87 of 144 Old 05-23-2013, 10:26 AM
turbogus
1978 CJ5
Hi John, hope you're doing well. Those lines are the set screws that lock the wire in place. They accomodate a flat bladed screwdriver on their top. Not my drawing.
turbogus is offline
post #88 of 144 Old 07-25-2013, 09:48 AM
John Strenk
1976 CJ5
Just found these, better post it wile I have the info.
Pico 0952A GM Ignition Cavity Fuse Block Tap - Clear
http://www.repairconnector.com/produ...2d-Clear-.html
post #89 of 144 Old 07-25-2013, 01:05 PM
Rousey72
1972 CJ5
Awesome write up! This is going to come in handy when I start rewireing. The PO claimed to be a 12 volt genius (red flag) and all the wires are an absolute mess and everything is directly wired... NO CIRCUITS?!? Needless to say I'm replacing the whole harness with a harness from EZ Wiring. Anyone ever use ez wiring before?
1972 CJ5 - AMC 304 V8 - T-15 trans
Dana 20 transfer - Dana 30 front - Dana 44 rear
Currently being taken apart, so that it can be put back together.
Rousey72 is offline
post #90 of 144 Old 07-25-2013, 01:36 PM
Joe6Pack74
Very nice write up and will save me a lot of internet time researching. Thanks.
Joe6Pack74 is offline
Contour Fan Wiring Help for Dummies-Need basic instruction Dborns Jeep CJ Forum 29 01-12-2015 07:11 AM
CJ-7 T-5 Tranny: "Basic one" VS Basic Two Group_er Jeep CJ Forum 0 10-15-2009 10:22 PM
CJ5 Wiring - Basic Help - (Rockford Illinois) Matusel3 Jeep CJ Forum 21 09-28-2009 11:58 AM
basic wiring diagram? Sedorbrian Jeep CJ Forum 9 04-12-2009 05:48 PM
Basic Wiring Question (painless?!) Floridazed Jeep CJ Forum 11 12-11-2008 10:31 AM
