BASIC WIRING 101, Getting You Started! - Page 5 - JeepForum.com
 3Likes
post #61 of 144 Old 07-18-2012, 09:11 PM
SemperFi1371
1990 XJ Cherokee
http://www.molex.com/molex/index.jsp
http://www.knukonceptz.com/index.cfm
http://www.wiringproducts.com/conten...use_block.html
http://www.builderdepot.com/search.ihtml
http://www.repairconnector.com/
http://www.surplussales.com/index.html
http://www.oemsurplus911.com/index.html
http://www.acdelco.com/parts/wire-an...r-connections/
http://www.parts-express.com/
SemperFi1371 is offline
post #62 of 144 Old 07-18-2012, 10:08 PM
scooter18155
1983 CJ7
great thread
scooter18155 is offline
post #63 of 144 Old 07-19-2012, 06:54 AM
jdboy
Just a quick question here. I like the idea of having a battery cut off just as extra protection and a little extra theft deterrent. My question is, I have a 100amp resettable circuit breaker that I thought about using for this. Anyone have any info why or why not this may work for my project? Here's an example of a similar breaker to what I have.
http://www.powerwerx.com/fuses-circu...-bussmann.html
jdboy is offline
post #64 of 144 Old 07-19-2012, 03:38 PM
redfin188t
1982 CJ7
Am I the only one who misses the expertise and knowledgeable input that was always provided by Jeephammer?
redfin188t is offline
post #65 of 144 Old 07-19-2012, 04:04 PM
kconnor123
1978 CJ7
Where is jeephammer???
1978 CJ7 I6, 2.5" dik cepek spring lift, 0.5" shackle lift, Cooper Discoverer S/T 33's, 1.25" Wheel Spacers.
Whats Next: Wide track swap, winch, new seats, eventually a 4.0 mpi swap from a 90's cherokee or wrangler.
kconnor123 is offline
post #66 of 144 Old 09-27-2012, 08:37 AM
Orlie
hear is a link to connectors that are inside relay pigtails. I used these when I want to change the wire gauge. These fit most all the pigtail that are used for relays. The pic online is different from what they send.
http://www.repairconnector.com/unive...2-awg-50-pack/
later
Orlie
Orlie is offline
post #67 of 144 Old 02-19-2013, 02:21 PM
turbogus
1978 CJ5
I found these great rubber booties for military style battery connectors from a reseller on EBay a while back;
...for those of us that're anal about our battery connections....
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #68 of 144 Old 02-19-2013, 02:40 PM
turbogus
1978 CJ5
....and another one for those of us that're into doing the Contour/Mystique engine cooling fan swap. I have a box full of 70 amp wide blade female receptacles;
I think I trust Czech manufacture more than Chinese
Here's the disparity between 40 and 70 amp relay females;
These are used for this 70 amp relay (note the blade size);
If you have a need for one, drop me a line.
turbogus is offline
post #69 of 144 Old 02-19-2013, 02:48 PM
turbogus
1978 CJ5
With regard to that large 70 amp relay, I've taken a relay panel from a Ford F150 and am in the process of modifying it to accept the oversized receptacle also made by Hella. My progress so far;
turbogus is offline
post #70 of 144 Old 02-26-2013, 02:04 PM
turbogus
1978 CJ5
I'm on my way, I found some of that heavy wall 'gooey' heat shrink tubing at Platt Electric. The 48" of 12-6 AWG was $23.76 and the 9" of 1/0 to 8 AWG was $4.61 (I hope I didn't get burned)
I found and bought on EBay some knock off ratcheting pliers with the jaws I was looking for for $33.16. Since I'm not going into production of masses of wiring harnesses, these ought to get me through this job. Platt had a set in their catalog for $99.00 owing to a mainstream toolmaker (Klein?)
...just a little more organizing in the garage next saturday and I'm hoping to get started.
turbogus is offline
post #71 of 144 Old 03-03-2013, 08:32 AM
rsegriggy
1981 CJ7
Subscribed.
I found HD headlight sockets for CJ headlights on the shelf at Advanced Auto yesterday.
I also found adhesive line heat shrink tubing on the shelf at West Marine. Actually, they had a great array of fuse blocks, bus bars, and other misc electrical stuff. I'd suggest seeing if a store is close to you. www.westmarine.com
rsegriggy is offline
post #72 of 144 Old 03-13-2013, 04:48 PM
turbogus
1978 CJ5
I figure I can't go wrong with 3M
turbogus is offline
post #73 of 144 Old 03-19-2013, 04:51 PM
04MAX
1982 CJ7
Very handy.
04MAX is offline
post #74 of 144 Old 05-05-2013, 04:26 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Thanks to Dave (243) for sending this to me,
Thanks to Jwhore for posting this for Dave,
Thanks to John Strenk for making this!
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #75 of 144 Old 05-12-2013, 02:50 PM
turbogus
1978 CJ5
Quick relay question.....
I've been concerned with running that 70 amp relay so when the Ford Contour fans come on together they don't cook the relays, however I'm wiring these fans independantly with their own controllers, fuses, relays and wiring...
Therefore this eliminates the overamp issue doesn't it?
As many may have seen from my posts I've already prepared relays, sockets and wiring for that 70 amp relay but now I'm thinking it's all for naught.
Confirmed OK by another, but then since it's already been prepared nothing wrong in over engineering I think.
turbogus is offline
Contour Fan Wiring Help for Dummies-Need basic instruction Dborns Jeep CJ Forum 29 01-12-2015 07:11 AM
CJ-7 T-5 Tranny: "Basic one" VS Basic Two Group_er Jeep CJ Forum 0 10-15-2009 10:22 PM
CJ5 Wiring - Basic Help - (Rockford Illinois) Matusel3 Jeep CJ Forum 21 09-28-2009 11:58 AM
basic wiring diagram? Sedorbrian Jeep CJ Forum 9 04-12-2009 05:48 PM
Basic Wiring Question (painless?!) Floridazed Jeep CJ Forum 11 12-11-2008 10:31 AM
