Ball joint positioning for grease fitting. - JeepForum.com
post #1 of 2 Old 06-26-2013, 02:39 PM Thread Starter
agear
I recently installed some ball joints. And wanted to make a reference for people who are doing theirs. Instructions tell you to install ball joints so you will be able to access the grease fittings. I did try to do this but still installed them so you can get a grease gun nozzle on the fitting because it was hitting the knuckle. So Im posting this picture showing you a reference point to install the ball joint in the right position for grease fitting access. I bought this cool needle injector grease gun tip ,which is normally used to poke through the rubber boot and grease that way. I found that it will also fit into the hole in the grease fitting but these needle injector tips are very fragile and you will bend the needle , ruining it first try , so you have to be extremely careful. I recommend buying two in case you mess 1 up. I also found another option-you can get a long grease fitting. If you're able to get the regular size one you can't grease , out then you can screw the long fitting end and you will be able to get the grease gun on it.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 2 Old 06-26-2013, 02:42 PM Thread Starter
agear
Here we go
agear is offline
