-   -   Ball joint positioning for grease fitting. (http://www.jeepforum.com/forum/f8/ball-joint-positioning-grease-fitting-1541700/)
agear 06-26-2013 02:39 PM
597 Attachment(s)
I recently installed some ball joints. And wanted to make a reference for people who are doing theirs. Instructions tell you to install ball joints so you will be able to access the grease fittings. I did try to do this but still installed them so you can get a grease gun nozzle on the fitting because it was hitting the knuckle. So Im posting this picture showing you a reference point to install the ball joint in the right position for grease fitting access. I bought this cool needle injector grease gun tip ,which is normally used to poke through the rubber boot and grease that way. I found that it will also fit into the hole in the grease fitting but these needle injector tips are very fragile and you will bend the needle , ruining it first try , so you have to be extremely careful. I recommend buying two in case you mess 1 up. I also found another option-you can get a long grease fitting. If you're able to get the regular size one you can't grease , out then you can screw the long fitting end and you will be able to get the grease gun on it.
agear 06-26-2013 02:42 PM
597 Attachment(s)
Here we go
http://i1293.photobucket.com/albums/...psb91d52de.jpg
http://i1293.photobucket.com/albums/...ps9bf8985f.jpg
http://i1293.photobucket.com/albums/...pseb7f3960.jpg
The time now is 04:48 PM.
