Baddddd and i am 100 m away - JeepForum.com
post #1 of 14 Old 09-17-2011, 05:42 PM Thread Starter
Nbonney5413
Had a motor mount break and cause a puncture in my oil filter and I'm leaking oil like a stuck pig gotta try to figure out how to fix it to get home. There is a napa here so I am gonna run up there. Any ideas?
Nbonney5413 is offline
post #2 of 14 Old 09-17-2011, 05:43 PM
davbytrace
1979 CJ7
Duct tape.
davbytrace is offline
post #3 of 14 Old 09-17-2011, 06:25 PM
JeepHammer
Running On Empty...
1973 CJ5
This is an easy one,
New oil filter, some oil and a chain/cable around the engine mount.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #4 of 14 Old 09-17-2011, 06:40 PM
Hurricane4
Are you anywhere near Steubenville, Ohio?
I am about 40 miles west of Pittsburgh, PA.
The unbelievable we can do immediately . . . the impossible just takes a little longer.
Hurricane4 is offline
post #5 of 14 Old 09-17-2011, 07:38 PM Thread Starter
Nbonney5413
I'm strapping it down and gotta get a new filter and se what happens. Towed our fireboat down for firemens weekend. In Wildwood Nj
post #6 of 14 Old 09-17-2011, 08:18 PM Thread Starter
Nbonney5413
Ok I tried to get a filter no good till tomorrow. We strapped the engine both directions I'll add the details tomorrow you guys might get a chuckle
Outta what we did. To get back from the gas station I wrapped the oil filter both directions an then wrapped it in 30foot of
Paracord very very tight. We shall are what happens tomorrow once I buy a few oil filters and we get to see in daylight
post #7 of 14 Old 09-17-2011, 08:44 PM
John N
1981 CJ8
With a bottle jack and some blocks of wood, you can lift the engine and get a new mount in there I believe...it's been a while since I had an I-6 motor in mine. You're lucky that the fan didn't eat the radiator, too; that usually happens.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #8 of 14 Old 09-17-2011, 09:00 PM Thread Starter
Nbonney5413
I'd live to pop a new mount in but all I have is a small napa and an auto zone do they carry thy kinda stuff stock? Wouldn't that be a special order?
post #9 of 14 Old 09-17-2011, 10:47 PM
KoreanKrusher
1976 CJ7
Might be a dumb question, but what is the white thing on the front of your jeep?
KoreanKrusher is offline
post #10 of 14 Old 09-17-2011, 11:00 PM
arkiemurph
Looks like a rod holder (fishing).
Murph
Love thy neighbor, but don't mow down the hedge.
arkiemurph is offline
post #11 of 14 Old 09-18-2011, 01:31 AM
Hurricane4
In my 1972 Jeep brochure it shows a yellow CJ5 with two fishing rod holders
on the chrome front bumper. I have the AMC Jeep dealer brochures from 72
through 79.
post #12 of 14 Old 09-18-2011, 03:19 AM
JeepHammer
Running On Empty...
1973 CJ5
Well, it's a lead pipe cinch you are going to find both engine mounts, and the transmission mounts are shot.
When you install those mounts, make sure the 'Torque Tab' goes on in the correct place and this *Shouldn't* happen again.
I purchased a cable bycycle lock and wrapped it around the engine/frame brackets one time to keep a muscle car working the weekend and get it back home. Worked, but wasn't pretty.
The ONLY way you could have punched a hole in the oil filter was for the ENTIRE ENGINE & TRANSMISSION to be rotating WAY OVER.
So replace BOTH SIDES, adding a cable to the drivers side wouldn't be a bad idea,
And CHANGE THOSE TRANS/TRANSFER mounts!
So wh
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #13 of 14 Old 09-18-2011, 06:53 PM Thread Starter
Nbonney5413
made it home, about 20 miles from home i hit a bump and punctured the new filter but made it home anyway. these engines are TANKS! ill add some pictures tomorrow of the whole set up and what we used maybe someone else can use the same setup some day. i know ive just decided to add 3-4 ratchet straps to the gear i carry on anytrip further then 30 minutes from home.
post #14 of 14 Old 09-18-2011, 08:05 PM
arkiemurph
Used a ratchet strap on mine about a year ago. Went through about 4-5 times for added strength? Worked pretty good! Still holding well! JK, I replaced it!
Murph
