Bad to Worse to a Small Fire. Please Help - JeepForum.com
post #1 of 3 Old 06-10-2002, 06:57 PM Thread Starter
NMullens
NMullens's Avatar
Unhappy Bad to Worse to a Small Fire. Please Help
The new gas tank was put on this weekend and the Jeep didnt want to start from that point on. I put about 5 gallons in the new tank, primed the carb with some gas and turned the key. I see a glowing through the "fire" wall and think, "maybe I should stop cranking," walk to the front and there is a 258 Barbecue going on in my CJ. The header was not connected to the exhaust pipe and the end of the header was the center of the flames. Upon extinguishing the flames, some water got into the carb. Now what should I do? There is not a lot of water that made it in but I still didnt want to crank the engine. How do I get it out to avoid hydro-lock or is it enough to worry about?
Thanks for any help.
Nathan
Currently Jeepless - Previously owned 1983 SJ, 1979 CJ-7 and 1991 YJ
NMullens is offline
post #2 of 3 Old 06-10-2002, 10:48 PM
G Beasley
Post
yank your carb and hose carb cleaner through it as you move the linkage to pump any water out of the bowl .After you do this for a half can or so ,take th plugs out of your jeep and turn it over a few times .Reassemble and start it up !
G Beasley is offline
post #3 of 3 Old 06-11-2002, 02:38 PM
Boggy Bottom
Post
I wouldn't even go that far. Frankly, I would just take out the plugs, blow some starting fluid into each one, and into the carb. After a few rotations your water will pass through anyway. A '79 CJ should be able to swallow a little water and keep on goin!
Ol' Boggy Bottom
'83 & '84CJs, '51, '53, and '57 Willys Pickups
Boggy Bottom is offline
And then my day got worse.. SparkyB Jeep CJ Forum 5 01-30-2010 07:42 AM
Oil Leak in my 304 getting worse Death_Eagle_571 Jeep CJ Forum 7 12-09-2009 06:47 PM
best and worse mod? khill8469 Jeep CJ Forum 10 06-30-2008 07:13 PM
CJ 7 with a small problem (I hope it is small) TennesseeRunner Jeep CJ Forum 15 12-31-2006 04:25 PM
bad steering just got worse... NJCJ7 Jeep CJ Forum 7 05-15-2004 10:09 PM
